Question about Microtek C893 18.1" Flat Panel LCD Monitor
I have the same problem!
One morning a couple of weeks ago -- after working fine since early 2002 -- it just wouldn't come on. The power switch just alternately flickers yellow(amber) and green - and nothing happens. I suspect that it may be one of three things: (1) the contact in the switch is just worn out. (2) Perhaps there's a fuse inside that fizzled. Or (3) there's a power supply of sorts inside that fizzled.
I'm reluctant to tear this thing open -- as it may involve tiny parts I cannot handle - or have no substitute for.
Up until the moment it stopped - it worked just fine for 7 years with no hint of any such problem.
If any reader knows a reasonable 'fix' - assuming there is one -- please would appreciate your letting me know at: robertrx@hotmail.com
Thanks.
  • 19,396 Answers
Hi Robert,
The monitor is on protect mode because an internal fault had been detected.
To start unplug monitor from power and from computer and test computer with different monitor to find out if it is monitor or computer fault.
If it is computer fault and no video signal , then test:
  • Video cable.
  • Video adapter on PC (sometimes integrated on motherboard)
  • Motherboard.
If it is monitor fault , then the monitor is on protection.
When on protection you keep having a flashing led on front of the monitor , and monitor turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, faulty inverter board, faulty input board, or a fault on LCD Digital Controller board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
Try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Regards
Posted on Jul 17, 2009
Stalls losing electric power
How old is the battery & have you tested it?
How is it that a month went by & your using
any vehicle that could let you down?
Why have all issues not been resolved ,as soon
as they started?
Have you checked for codes?
Have you had a professional scan tool on it
& checked data,that has to be done along with
many other checks or tests,unless it's just a battery
issue.
No one can solve any vehicle issue over the internet
There is always more to the story & you need the patient
Jul 19, 2013 | 2004 GMC Envoy
My LG portable AC Model #LP1111WXR wouldn't turn off had to unplug it. Now won't turn on.
Unplugging the unit lets the tiny computer like microprocessor reset--means problem is in the brain of the unit or its power circuit.
Jun 14, 2012 | LG 11,000 BTU PortabAir Conditioner -...
Power, DMZ, WLAN leds OFF. Ethernet, Internet are solid ON.
With the signs that you have describe about your router, this is a clear signs that the router is already bad the hardware itself and better have it replace if still under warranty if not you need to go get a new one sorry about that router is dead already.
May 02, 2010 | Linksys Wireless-G WRT54G Router
Paloma PTG-74PVN power turns off by itself
turn the water flow off and control off and hold the two arrow buttons together
then use the up arrow to get to e and the down arrow to get to 1 what do you see?
Sep 09, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
I have the same problems.
sounds like you have a blown thermal fuse.
Jun 24, 2009 | KitchenAid KUDR01TJ Dishwasher
Truly MP3 13X only showing blue backlight
same here, you just have to keep messin' with (pluging it into computer, etc.). I know it sounds strange but that's how I deal w/mine. It eventually comes back to life.
Feb 21, 2008 | Truly MP313X 1 GB MP3 Player
Microtek C893 18.1" Flat Panel LCD Monitor Logo
217 people viewed this question
Top Microtek Computers & Internet Experts
William Miller
William Miller
John Anderson
John Anderson
solver2010
Are you a Microtek Computer and Internet Expert? Answer questions, earn points and help others
