Question about Logitech 9312160403 Mouse
Multipul clicks per key press - Logitech 9312160403 Mouse
  • 118 Answers
Simple test-- go to the mouse icon in the control panel set the double click speed to fast, if the problem persists contact logitech. if the problem stops then uninstall setpoint and download the latest version.
Posted on Jul 17, 2009
Bizhub 211 reset
1-Turn the machine ON. 2-Press "Utility" button on front panel. 3-Now press these buttons "stop+0+0+stop+0+1" it means press stop button, then press 0,again 0, then again press stop button, then press 0, and 1. 4-service mode will appear on LCD screen. 5-Now with the help of arrow keys go to the last option.which is "Clear Data". (6) Now select "Memory Clear", clear the memory by clicking "Yes" or "OK" button. Wait for a while, a new code will appear on screen. Now again go to the service mode and go "ADJUST" option and with the help of arrow key select "Model setting" option and press "OK/YES" button. Now in the model setting menu select "16" which is the copy per minute speed of your photocopier machine. Select this option and press "OK/YES" . Now restart the machine.
Nov 25, 2013 | Dishwashers
I have a 1994 wrangler.must crank starter multipul times for fuel to reach fuel rail on 2.4 or 2.5 4 cyl.Once finally starts will run great all day and start.Next day starts hard again.I replaced fuel
replace the fuel pump,the check valve that holds pressure on the fuel is in the fuel pump.The fuel in the lines is draining back into the tank
Dec 10, 2017 | 1994 Jeep Wrangler
Ux355l copyer , when i press copy button to make a copy it say press wrong key, can u help me.
I tend to think that you are pressing wrongly. Place the document to be copied facing down on the fax document side and then press COPY/HELP key1 Load the document(s) face down.
(Maximum of 10 pages.)
The display will show:
READY TO SEND
• Set the resolution and/or contrast if RECEPTION
MODE
desired. (The default setting for
copying is SUPER FINE.).
2 Press the COPY/HELP key.
COPY/HELP
COPY MODE
START KEY: SINGLE
COPY KEY: MULTI
? If you are only making one copy of the original (or of each original)
and don't want to make a reduction or enlargement setting, press the
START/MEMORY key twice. Copying will begin.
and want to make an enlargement or reduction setting, press the
START/MEMORY key and go to Step 5.
3 Press the COPY key (MULTI ) if you
want to make multiple copies of each COPY/HELP
original.
ENTER # (01-99)
4 Enter the number of copies per
original (if the number is less than 10, 0 3
enter a "0" before the number).
Example: Three
copies per original
COPY RATIO
Originals
BC
A
MULTI COPY
AA BB CC
A B C
You can get its manual here.
Jan 08, 2011 | Sharp Office Equipment & Supplies
How can i lock my keyboard on my laptop?
http://www.100dof.com/kidkeylock.html
download and install it.
Double-click on kkl (kid-key-lock) icon in system tray. Configure mouse & keyboard as per your wish. (my suggestion, dont change any passwords)
To undo it, just type kklquit.
For next use, start kkl (All Programs - kkl), type kklsetup.
Windows also gives you a way to lock keyboard.
Press Windows+U.
Go to "Make the keyboard easier to use"
Check "Turn on filter keys"
Apply
Keyboard is locked. All you get is beeps when you type.
To undo this, double click the new clock-icon in system tray.
Uncheck Filter Keys.
Hope my solution helps you.
Nov 15, 2010 | Computers & Internet
How do i set the clock? l have clicked on clock and tried entering numbers but nothing happens
Enter into BIOS
  • Enter the CMOS setup.
  • system setup screen see the date and time
  • Using your arow key on the keyboard navigate to the date and change the date. Once highlighted on the month, day, or year, press your arrow key / your page up / page down keys to change the date.
Using Msdos command
  • Press Control + r key togather
  • type cmd
  • on the black screen type date
  • press enter. It will be showing the current date and also asking you to put the new date in the format mm-dd-yy,
  • type new one as per format
  • press enter
For time
type cmd
on the black screen type time
press enter. It will be asking for new time,enter new time and close the black box.
GOOD LUCK!!
Sep 24, 2010 | Computers & Internet
Computer won't start correctly
From scratch, start PC, press F8 key on keyboard repeatedly (about two times per second) until you get to a screen that shows a list of startup options. With the arrow keys on keyboard choose "SAFE MODE" press enter and allow PC to boot fully. If you are given an option to use "SYSTEM RESTORE" as it boots choose it, and follow the instructions to recover your pc to an time when it worked properly. If you dont get this option go to START then RUN and type MSCONFIG.EXE and hit the enter key. Go to TOOLS look for SYSTEM RESTORE highlight it and click on LAUNCH. then follow the instructions from there.
Aug 12, 2010 | Gateway Computers & Internet
Solid state water chiller thermotek T252P-4 , how do I adjust cooling rate per minute
That's the gradient setting. Press the output temp key until gradient appears, then use the up and down keys to change the setting. The change rate is in degs C per hour.
May 11, 2010 | Computers & Internet
Cant delete maeeages by multipul
when you're in your inbox go to the menu and click "mark/unmark", then tick the box that comes up at the top. you can then use the menu to delete all your messages
Apr 21, 2009 | LG KU990 Viewty
Faxing mass phone numbers
press function- fax/email sttings- thats where you will find group dials and program keys
Nov 13, 2007 | Panasonic Workio DP-2330 Printer
Logitech 9312160403 Mouse Logo
42 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
