Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
Error code F09 for HE3T Kenmore waher
I get the error F09 in the last 30- minutes of a normal wash cycle.
In the manual, error F4-F16 are mentioned as electrical problems. What does F09 mean?
  • 7 Answers
Re: Error code F09 for HE3T Kenmore waher
Shannabug is right on the money. I had the same problem a few days ago. F09 came up - I hit pause twice - since there was water still in the drum I did a spin and drain.
Right below the kickboard there are three torqux screws - now's a good time to get a Torqux folding key set. Once removed - give the side of the kick board a rap on the side - sometimes you may have to use an object to hit it with - it'll fall right off.
On the bottom, dead center is a white cylinder facing you with a screw cap. This is the filter/catch basket - to the right of that is your pump.
Before you screw off the cap, make sure you have lots of paper towels - I had a shop-vac - as I loosened the cap I had the vacuum **** up the water that was coming out - I removed the filter and there was two pencils in there - apparently my son never emptied his pocket. I put the shop vac into the filter chamber and started sucking up anything else that may have been there.
When you put the cap back on, ensure the little notch on top of the cap is facing up, and screw it back on securely. Put the kick board back on - and you're ready to go.
If you continue to have a problem you can clean out the drain tube with a shop-vac - and/or purchase a new pump - but now you see where it is, and how easy it is to change it - you can now save yourself a few hundred dollars by changing it yourself!
IMPORTANT - BEFORE YOU DO THIS UNPLUG THE SYSTEM. This will make sure no injuries, and while you are doing the filter, the computer is getting to reboot itself.
Posted on Dec 20, 2009
F09 is the water pump. It usually means something is clogging it. Take the front cover off of the washer and the water pump is located right in the middle front. Unscrew the cover to the pump and make sure there is nothing clogging it. I just had this issue and found a quarter, a nickel and a button. Since I removed the items there has not been a problem.
Posted on Apr 01, 2008
I get F9 from time to time. It is either because the load is too large and the weight of it wet triggers the error. I have gotten it when I put in already wet cloths. My main problem when F9 error occurs is that my water hose has gotten bent or kinked either right where it comes out of the machine or where it drains into the wall.
Posted on Apr 10, 2008
Thanks for the answers.
Here is what we did. Washed twice with no cloths in the machine - some debris came out during the rinse cycle. No more F09 after that.
Posted on Apr 11, 2008
0 characters
3 Points
Why is My Kenmore he washer is throwing the codes f9 and e1... what do these mean?
I have the manual for the Kenwood HE3t. It says nothing about e1, but for F4 thru F16 it says to press PAUSE/CANCEL twice to cancel the cycle then start again. If the problem remains try asking at, press the "Repair Help" tab.
Apr 29, 2014 | Kenmore HE2 Plus Front Load Washer
F02 and F09 - valid for Whirlpool Duet front load washer, HE3, HE3T Kenmore,...
This tip is valid for valid for Whirlpool Duet front load washer, HE3, HE3T Kenmore,Fagor, amd more washers built by Whirlpool group.
F02 means that there is a drain problem, and F09 is overflow condition. When you get both error , it is usually because of a faulty pressure switch. Better testing the drain system as described below , before replacing the pressure switch..
To start try clearing the error by disconnecting the power cord or tripping the circuit breaker for five minutes. If you can clear the error, then the problem was just temporary.
The drain pump must be accessed as the drain hose is probably clogged. Also drain pump must be tested and eventually replaced.
If you get the error , but there is no water inside, and drain system is working correctly, then test and eventually replace the water level pressure switch, that determines when to start/stop fillng and drain.
If the drain lines are not clogged, the drain pump can be tested by reading ohms at solenoid (contacts on valve), and by energizing the pump directly.
If the pump is fine, then test the pressure switch by jumping its contacts, and advancing cycle to drain to avoid overfilling.
If you get both the codes, the cause is usually the pressure switch
Since one of the codes is overfilling, check if the inlet valve is opening and closing during the cycle, by observing if water starts and stops flowing into the machine, or by reading volts at inlet valve or at electronic control contacts. If the valve stays open or leaks with no volts from timer, then the valve is faulty. If timer is opening the valve while draining, then the timer board is probably faulty.
If water and sensor are OK, then it can be a problem with wiring or control board. Electronic control board causing this error is not common.
Test all other parts first.
You can find parts and diagrams by entering model number here.
Test and repair must be done by a trained person. Call the phone number listed on the user manual if you need to contact a qualified technician.
on Mar 25, 2010 | Washing Machines
HF error flashes, then after 7 min. drains machine, but won,t go in wash cycle
Kenmore HE3T front loading washing machine. About every 2 minutes the cycle stops and flashes an "f" then an "h" on the display over and over again. **
That error code can be the result of no water detected entering machine after 30 seconds or pressure switch (water level control) activation not detected after 8 minutes of filling.
If there is no water in the machine at the time, make sure that both water taps are turned on, check for kinked fill hoses or plugged sediment screens in them and verify the water fill valve operation.
If there is water in the unit, verify drain pump and water pressure switch are operating properly, the pressure switch hose is in good condition and properly connected to the pressure switch. Also, make sure the water is not siphoning out of the machine prematurely due to an improperly installed drain hose
That error might also be caused by too much suds in the wash water like can result from using non-HE detergents
Nov 29, 2010 | Kenmore HE3T Washer
HE3t Washer Problem -
Clean out the drain pump, if this doesn't resolve it then replace the drain pump,this will resolve you issue.f09 means slow drain or no drain.
Oct 30, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
My kenmore fron loader gets stuck in the wash cycle then reads erroe F09 and sometimes F11
"F09" is an Overflow Condition error, while "F11" is a Serial Communications error. The following two links explain both error codes and how to troubleshoot:
Read through both links and follow the advice given. Both these error codes can be a bit tricky to diagnose as they both have multiple causes. I would begin by looking at those items that are common to both. The Central Control Unit (CCU) seems to be a logical place to start. Check all the wire harness connections to make sure they are connected properly. I would recommend you pull each plug one at a time and reseat them. Make sure you UNPLUG the washer while doing this and leave the unit unplugged for at least 30 minutes. This will reset the CCU and clear any erroneous error codes. If resetting the CCU does not help, or if you don't find either of these links helpful, please post back and let me know. I hope you find this information helpful.
Jun 23, 2009 | Kenmore Elite 45986 Front Load Washer
F02 is long drain.
Just because it came up doesn't mean there's a problem, it simply means there was a failure during the cycle, if it returns on a regular basis, you have a problem.
F02 error could be caused by the over use of soap, you need to make sure your using 2 tablespoons of HE soap, 1/4 cap at the most.
Over sudsing, could cause the water pump to run longer, the pump is designed for 15 min duty cycle which means, 15 minutes on to 45 minutes off. The computer may sense too much soap, and continue to pump. HE soap will cure that, along with SUD error, possible F09 (overflow condition), you may also notice the timing is wrong, HE soap works well in these machines and F/l washer go hand in hand
if the F02 returns the remove the 3 torx screws from the bottom kick panel, and remove the kick panel, right there in the middle you will see a big round handle, turn it and then slide it out, have some towels ready, there will be some water in there, and check to see if you have any thing in there that will slow water flow, tooth picks and other "floating" items may jam the impeller.
Apr 01, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore Elite he3t model 11045972404
Nov 22, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Whirlpool Duet
your main processing board is having an communitcation error. if you have taking the kickplate off the tech sheets or on the right or let hand wall and will tell you how to enter the diagnostic phases
Jun 01, 2008 | Washing Machines
What does a F09 error mean?
Since Sears doesn't manufacture its own equipment I need a product code number to access the specific features of your appliance. Email me with that info and I can find what the error codes are.
Sep 09, 2007 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Error Code for Kenmore HE3
The "F" variables (F4-F16) are for electrical problems. You should select Pause/Cancel twice then select Drain/Spin if there is excessive water in the washer. Re-select cycle and press start. According to the manual, if the problem remains, call for service.
Dec 27, 2006 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
3,170 people viewed this question
Richard Roth
Richard Roth
Jesus  Colon
Jesus Colon
Level 1 Expert
Fred Sops
