Question about Plumbing
My Kohler faucet won't go from spray to stream.
My faucet sprays fine, but it won't go to stream. In the video you will see that something popped out from under the rubber cover. Everything else works just fine. At one point you helped me fix the handle. Hope you can help with this one! Thanks
meBNme
  • 334 Answers
SOURCE: side spray has very low pressure
Disassemble the sprayer and remove the dirt and dibri gathered inside.
Reassemble.
Has the water been turned off to that faucet, or the entire home recently? If yes, it probably loosened sediment in the pipes and its clogging the sprayer.
Posted on Dec 06, 2008
arealplumber
  • 33 Answers
SOURCE: delta kitchen faucet mixed spray...diverter problem???
No a pull out sprayer problem is different.
First try this. Pull out the sprayer and remove from hose by turning nut that connects sprayer to hose. If you can get someone to help you it would be nice since the hose can go down into the faucet and might be trouble to retrieve. Look in the connection on the sprayer where the hose connects and look at the screen. If the screen is plugged or dirty clean and reinsert. If you can't clean it replace it. If this isn't working go to the next suggestion below.
In the spray head of the faucet there is a build up of deposits from use and or water hardness. Here is the link to the Delta site.
Delta Faucets
If you find you faucet model order a new spray head. Once these go bad they usually need replacing.
Hope this helps and please rate this!
Posted on Dec 09, 2008
  • 127 Answers
SOURCE: i have a ladylux kitchen faucet and the
Call Grohe customer service...they will send you a new one for free.
Posted on Oct 18, 2009
  • 3640 Answers
SOURCE: We have a fancy single
does the faucet have an aireator on the end of spigot. if so remove by turning off with pliers, and see if it is blocking the water. if it is, clean aireator and replace if necessary.
Posted on Jan 15, 2011
SOURCE: brand new kohler cruette. attached cold and hot water fine. when snapping in the pull out faucet hose it sprays all over under the sink
Hi rysenga, the problem is an omission of directions. The section 9 directions are the worst offender and left me never again to purchase a Kohler product. First, this connection for the pull out hose to the outlet fitting should have been a screw on connection. Should have been. Ok it was not, I'll get over it. But the directions never mention having to install the white plastic bushing. Not at all. Nor does it mention that the bushing should be put on the outlet first and then push the hose connection in. This omission is a huge one, but should help anyone else reading this complete the install. Find the oval lip white bushing and install this first on the body, and then just push the connector in. Done.
Posted on Nov 17, 2012
How to remove the handle on a Kohler 12176?
Simply pop off the button on top of the lever to get access to the screw that holds it in place. Fun project...
Mar 08, 2015 | Kohler K-12176-PB Fairfax Single Handle...
Kohler style k12172 fairfax when i use the side spray there is very little pressure & the hose and sprayer are new and the hose has no bends in it.
you have an other part that went bad. Inside the faucet there ins a part called a devertot that is in the body of the faucet. This little part move the water from the main spout to the hand held sprayer.
You have to remove the handle and the spout. pop it out pop a new one in and you are good to go.
Glad you came to us for help. your rating us help us know how well we have done
Tom
Sep 09, 2011 | Kohler Fort© Single Lever Handle Kitchen...
I've installed a newly purchased Kohler forte 10433-VS faucet but unable to get spray to fully engaged and seems to leave the partial spout running resulting in a in between or partial spray and spout. Is...
Sounds like the diverter is not working properly. It is located in the spout and it maybe sticking or bad. Go to link below for a installation guide with parts break down. Click on installer's and designer's bar below picture of faucet for a diagram of faucet that may help you out.
http://www.us.kohler.com/onlinecatalog/detail.jsp?from=thumb&frm=&module=Faucet+Collection+Kitchen&item=9559802&prod_num=10433&section=1&category=4&resultPage=0-711729362
May 31, 2010 | Kohler Model 10433: Fort® Single-control...
Low stream
these faucets have a single handel, and have a cartage that can be taken out and cleaned. Low water pressure is caused by minerals in the water to build up in the cartage and slow down water flow.
Mar 28, 2010 | Kohler K-10416-BN Fort½ Single Control...
K-15160 Kohler faucet switch to change single stream of water to spray is stuck. It will not return to a single large spray. How do I fix this?
they get gunked up with grease and junk, and or mineral deposits from well water---unscrew the aerator housing(underside of rounded pullout part) inspect and clean all part making sure there are no cracks in plastic junk used today...also noting correct placement of parts
Mar 13, 2010 | Kohler Model 15160L: Coralais®...
Side sprayer won't spray
THe diverter inside of the faucet is malfuncting. Remove and replace the diverter valve. It is located right under the spout assemble.
Mar 25, 2009 | Kohler K-10416-BN Fort½ Single Control...
Cannot pull out spout to replace o'ring of Kohler Faucet 10416
the pic u have up doesnt show it being a pull out u trying to fix airater?
Jan 31, 2009 | Kohler K-10416-BN Fort½ Single Control...
Plumbing Logo
141 people viewed this question
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
