Question about Whirlpool Calypso GVW9959K Top Load Washer
L5 show in display and won't work in calypso washer
  • 32 Answers
Ss13679,
I believe your code is actually 'LS'. This codes shows up when the controller cannot detect the lid switch opening and closing properly. This error code may also be used if there is a diagreement between the motor and machine controllers on the state of the lid switch. The control should not allow the unit to run in this condition. This code will also appear if you press the start key while the lid is open. Open the lid or press STOP/CANCEL to clear the display.
Your lid switch may be bad. Click here for some help. Also it looks lik this: click here
Hope this helps. Please give me a vote!
-samson39
Posted on Jul 24, 2009
Calypso washer won't drain
It sounds like you may have something stuck in the pump...try and locate the pump(normaly at the bottom of machine)and unscrew the cover...be aware that the machine may still have water in it....once you unscrew the cover,have a look and a feel inside...there may be a coin or other object stoppint the pump from turning...remove any foreighn object...replace the screw on cover and try to drain the water again....this should solve your problem.
Jan 17, 2013 | Whirlpool Calypso GVW9959K Top Load Washer
My calypso GVW9959KQ2 displays L5
its probably LS not L5 code,which is a lid switch failure and this will result in a machine that will fill and possibly agitate,but wont spin out.replace lid safety switch located underneath top of units outer case
Aug 01, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
Calypso has unbalanced "L5" message
LS is a "Lid Switch Error"
The control should flash this error code if it cannot detect the lid switch opening and closing properly. This error code may also be used if there is a disagreement between the motor and machine controllers on the stat if the lid switch. The control should not allow the unit to run in this condition.
This code will also appear if the user presses the START key while the lid is open.
Open the lid or press STOP/CANCEL to clear the display. If opening the lid or pressing STOP/CANCEL does not clear it, unplug your washer for 5 minutes.
Here is a link to a PDF manual for it also.
Calypso Manual
Nov 21, 2010 | Kenmore Washing Machines
I have a l5 code what does that mean
L5 means it cannot sense the lid open or closed.
Lid switch is likely bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 26, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
I HAVE A L 5 ERROR CODE ON MY WASHER AND IT WILL NOT WORK WE HAD THE WATER PUMP REPLACED BUT IT STILL HAVE THE SAME MESSAGE ITS A CALYPSO WHIRLPOOL
This error code may also be used if there is a disagreement between the motor and machine controllers on the state of the lid switch. The control should not allow the unit to run in this condition. This code will also appear if the user presses the START key while the lid is open. Open the lid or press STOP/CANCEL to clear the display.
What is L5 code on whirlpool calypso model #GVW9959KQ0?
Aug 02, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
The washer stops working and the light flashes L5
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!
Jun 24, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
L5 flashing on my calypso washer
The error code is actually a LS not L5, it stands for a lid switch error, it could be a bad lid switch or you may have forgotten you had a previous load in and went to rewash and went and started the machine without opening the lid which automatically throws an LS error.so check the lid switch .hope helps p-ls appreciate by rating as fixyaa
Feb 05, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
L S or L5 error code on Calypso top load washer (Color - grey)
LS Lid Switch Error The control should flash this error code if it cannot detect the lid switch opening and closing properly. This error code may also be used if there is a disagreement between the motor and machine controllers on the stat if the lid switch. The control should not allow the unit to run in this condition.
Dec 06, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool calypso washer
Code LS=Lid Switch. I had the same problem and found that if you pressed down firmly on the lid when closing I would not get the LS code. An uneven load will sometimes cause enough vibration to the lid to stop the washer and display the LS code again. Just lift lid and press down firmly again and start. Eventually I will open it up and adjust the switch.
Mar 08, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
224 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
