I have an acer extensa 5610. DVD/CD Rom wont work or beeing seen.
My Acer Extensa 5630EZ making noise when i put in a cd or dvd.. can I solve the problem or it has a bigger problem?? Sorry for my english, I'm just learning this language..
This sounds as though the ACER unit is defective, the CD is turning around on a spindle which is either lopsided, or is bent. To save yourself the problem, replace the drive, if this is a new drive, go to ACER's website, request a work order, and send in your drive.
Feb 02, 2011 | Acer (91.48T37.003) CD-RW/DVD-ROM (Combo)...
My laptop is not detecting cd in it wht to do???????????
connect an external cd/dvd drive & see if its working or not. If yes, then you need to replace cd/dvd drive of your laptop.
Jun 16, 2010 | Acer Extensa 4620 Notebook
Extensa 4620-4963 - dvd drive has disappeared!
i have acer Extensa 5210 but the laptop is working properly but the dvd drive is not working
Apr 14, 2010 | Acer Extensa 4620 Notebook
Acer Extensa 5220 battery and CD/DVD ROM not working after unit was dropped! There seems to be no power gong to the CD/DVDROM and the battery. Need help!
Sorry you are having trouble. It sounds as if the board inside has been damaged. It sounds like a trip to the repair shop is needed here.
Apr 06, 2010 | Acer Extensa 5620 Notebook PC
My acer Extensa 5620Z DVD/CD ROM drive is detected as USB mass storage that provides internet(Modem). When I remove the internet modem, the CD ROM is not listed in My computer. When I put CD or DVD in it...
That is a Vista problem with ACER. Delete the reference in device manager and restart and let the comp reco0gnize and reinstall ...just follow the screen instructions.
There is a registry setting that needs deleting but only if this doesn't work.
Nov 03, 2009 | Acer Extensa 5620 Notebook PC
The disc drive wont burn a dvd or even play cd or
was it preinstalled or you installed it yourself ? either way sorry to tell you but drives do give out, and some times the cd-rom and dvd - rom drives the hardest to fix, but you can research http://www.geeks.com/ and find yourself a new one for around 40-50 dollars...
another thing, if you installed this drive yourself, you can pull it out and check the jumper and make sure its either cable select or slave or master, which ever you want to set it up as....
i usally put all my drives in cable select so the computer will select which drives goes first and things are juts alot easier that way....
Apr 16, 2009 | Acer Computers & Internet
Play/open dvd
If this is the DVD drive that was originally installed in this machine you should be able to go into device manager and update the drivers for the dvd-rom. The drivers should be located the driver cd's that came with the laptop.
Mar 18, 2009 | Acer Extensa 4620 Notebook
I need to install my cd/dvd-rom driver on my acer extensa 5620
Which do you have CD are not DVDs but DVDs are CDs. On the front of the CD or DVD player it should say which it is. I believe that the CD driver is already contained within the windows OS software? As far as DVD I have always gotten the software with it, usually NERO .
I see neither any  CD or DVD  drivers listed on your support web page.
http://www.acerpanam.com/synapse/forms/portal20.cfm?website=AcerPanAm.com&siteid=7117&areaid=2&formid=3394#results
Jan 08, 2009 | Acer Extensa 4620 Notebook
Looking for the Acer Extensa 4620Z service manual or instructions on how to remove my dvd/cd rom drive
manual can be found here - http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=01d95435f44ffa9941b456e44c950ef7&q=Acer+4620Z
Dec 26, 2008 | Acer Extensa 4620 Notebook
Computers & Internet Logo
132 people viewed this question
David Payne
David Payne
