Question about RCA HD61LPW42 61" Rear Projection HDTV
The exact same problem
I have a DLP that is exactly the same model with the exact same problem. I replaced the bulb a 1 1/2 years ago and it worked like a dream. A few months ago the dark left corner started small and has grown to over half way down on the side to a 1/5 of the way across the top.
  • 668 Answers
I can only think the Optical Block is causing the problem. There would be no other thing to block the light except something within the Optical Block itself.
Posted on Jul 18, 2009
Takes to long to come on
Maybe a ballast problem. DLP are famous for bad lamps and housing. You must make sure the lamp is a good and exact model replacement. Generic ones that are so called guaranteed to be exact replaments are often not and need to be sent back. And google for ballast replacement and find out how others are handling it.
Feb 06, 2015 | Samsung Televison & Video
The Temperature light comes on after replacing bulb.
I am experiencing the exact same problem. hope someone comes on worn a solution. projector worked fine before replacement - all fans have been cleaned and are working properly. ..
Mar 31, 2014 | Mitsubishi HC3800 1080p Home Theater DLP...
SAMSUNG DLP SLIM 50" AFTER I TURN IT OFF IT WONT TURN BACK ON TILL 30 TO 50 MINS LATER THE THREE LIGHTS IN THE FRONT BLINK. iT ACTS LIKE ITS GONA TURN ON BUT IT DOESNT IT JUST MAKES THE NOISE AND FLASHING...
Chris,
I had the same problem. I bought my tv at Best Buy and my warranty included a new bulb for the lamp. They only last about 2 yrs or so depending on how much you watch the tv. You can also buy replacement bulbs online that don't cost too much. BUT, you will need to replace every couple of years. The things you listed are exactly what happens when the bulb goes out. Hope this helps!
Sep 14, 2010 | Samsung 50" Slim-Depth DLP HDTV
MUST READ THIS I have a rca 61" hdtv purchased in 2004 with a 5 year extended warranty (thankfully) and have had nothing but problems with it. it is the worst thing i have ever bought.exactly 13 months...
All DLP TVS are lemons really.Most the Convergence ICS,they use on the board held the picture together will alway die about 1 year or 1 1/2 year all way need it replace.The bulb have life spans but never reaches alway dies before than.
Apr 01, 2010 | RCA HD61LPW42 61" Rear Projection HDTV
Samsung Dlp completely shuts off and then all three lights flash
Sounds more like the TV is overheating. The lamp cooling fan may be seized or not spinning fast enough. If the TV gets hot enough to trip the thermal, it could rupture the lamp.
Sep 09, 2009 | Samsung DLP HL-P5663W 56" TV
Replacement color wheel for samsung 50'
I am having the exact same issue with the exact same TV. They no longer make that color wheel, so I am looking for a replacement part as well.
I am looking at the 01103A as well from here:
http://www.partstore.com/Part/Samsung/Samsung/BP9601103A/New.aspx?ModelMfgName=Samsung&ModelBrandName=Samsung&ModelNumber=HLR5078W
I think I might just order it, and if it doesn't work just return it.
Jan 15, 2009 | Samsung Televison & Video
3 blinking lights - Samsung DLP
Remove your new bulb and examine the connector carefully. The inexpensive replacement bulbs tend to arc and ruin your $700 ballast; sad to say. If everything looks good, make sure the interlock switch on the bulb cover opening is engaging. It won't fire up if it thinks that door is open.
Dec 27, 2008 | Samsung Televison & Video
I have a viore monitor ipt46dl30 which just went black but we can still hear the voice.. help?
I'm in the process of ordering a replacement bulb for a friends set right now. The information below is exactly what's needed to get the correct bulb for this DLP television.
TV Make: Viore
TV Model: IPT46DL30 (Confirmed to be on TV label)
Bulb/Lamp Model: SHP70 (This number is right at the top of the bulb/lamp, where the wires connect)
Housing Model: 140-1027 (This is also known as the Ballast which houses the bulb/lamp)
Now, I've managed to locate the bulb/lamp from a few different sites. Unfortunately, there doesn't appear to be a reputable manufacturer making aftermarket bulbs for this DLP model. The original bulb type is all we have to look forward to. The cheapest price that I've found so far is $120.00. I have also found these particular bulbs for as high as $295.00. Needless to say, I'm going with the former.
http://www.replacementlightbulbs.com/lampshp70.html - $120.00 (Buying)
http://purelandsupply.com/140-1027-Bulb-Akai-DLP-TV-Lamps.html - $277.90 (Too much)
http://www.encompassparts.com/products/?140-1027 - $295.00 (Too much & very skeptical)
Mar 31, 2008 | Televison & Video
Samsung 61" DLP 3 Blinking lights.
all 3 lights blinking means lamp has a fault the service manual says replace the lamp. If you need the service training manual for that model let me know and I will post the link as the training manual has excellent trouble shooting breakdowns for that model DLP
Mar 26, 2008 | Samsung HLN617W 61" Rear Projection HDTV
RCA HD61LPW42 61" Rear Projection HDTV Logo
254 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
