Flat Panel Televisions
Problem for Flat Panel Televisions
Generic problem for all Flat Panel Televisions
Toshiba hdmi ports not working
By chrisG on Nov 18, 2007
hey guys, thanks for your time, I have a 52lx177 regza cinema series television and am having major problems with the hdmi imputs not reading the hdmi cables at all or just for a little while and then dropping the signal entirely and me having to reset everything to get a signal just for the damn thing to do it again! I thought that it might be my direct tv hddvr box, which is why I have gone through 5 of them in the past 6 weeks, finally I decided to just keep my component cables hooked up to the tv and hddvr box instead because nothing is being brodcast in 1080 p on television anyway. Well guess what happened when I finally bought a ps3 and tried to start watching movies, THE SAME THING! Everything is fine for a very short period of time and then bam, the signal goes out and the tv says no video signal. If I turn everything off and disconnect the hdmi cable from the tv and then reconnect it I get picture again and things are fine but not for very long before the same thing happens again and again and again. I have tried over 5 different hdmi cables with both pieces of equipment so I know its not the cables. Listen, I love toshiba but if I cant get this problem fixed and soon I will never even look at their brand name ever again! I spent with warrenty almst 5,000. and to be going through this hell sickens me right now! Please help me with this, I am at the end of my patience and have lost enough time, money, sleep, and piece of mind. I thank you and look forward to talking to you very soon. chris grossnickle
Same Problem
Apr 24, 2009
-   Shiny new Toshiba 40RV52U... great picture, decent sound, HDMI input ports are a miserable failure. Anytime the HDMI signal glitches (i.e. power up a DVD player, change video stream on a TIVO box, the darn TV says "No Input Signal" and otherwise presents a black screen. Cycle power on the TV... or change video inputs... returning to the input that gave you problems and it will find itself again.
TOSHIBA... FIX THIS NOW!
-   dougshade
Dec 28, 2008
-   I have the same issue with a brand new 40" RV525U. I have HD dvd on my laptop, pluged in my HDMI cable to both units and it worked fine for a few minutes. I accidently closed the laptop and it shut off, I haven't been able to get a signal since. I tried all the troubleshooting methods in the manual to no avail. I'm thinking about taking the tv back, any ideas??-   TomRogers
Jan 04, 2008
-   I also just bought the 52lx177. Immediately I experienced the same problem, but with a comcast HD box. I also replaced the box 3 times and got new cables. Last night I went a bought a Toshiba HD DVD to see if this would work. It worked when I plugged it in and watched a full movie. This morning I turned the two on again, it played for 1.5 minutes, TV went black for ~5 seconds, and then showed "no video input". I like the TV in general, but I am taking it back to the store; was thinking about just replacing it with the same model, but now uncertain about Toshiba?-   markhill
Solution #1
posted on Jan 04, 2008
Somewhat Helpful)
markhill
Rank: Apprentice
Rating: 76%, 2 votes
I talked to Toshiba about his problem, this morning. They said they have never hear of such an issue. I told them the TV was less than 1 week old, and would hope Toshiba would do something in response to my alternative action of returning both my Toshiba HD DVD and 52LX177 for a new brand. They said all they can do is have me go to a service center for them to repair it. 1 week old TV and DVD, $4000, for repair; I don't think so. I talked to two different people a Toshiba regarding this, with the same answer. Very poor customer support, especially for a higher end product like this. I think I have no choice but to change brands.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Nov 15, 2009
Very Helpful)
Sitsiuq
Rank: Apprentice
Rating: 100%, 5 votes
It may have something to do with the resolution. I have a PS3 which works just fine with my Sharp LCD, but when I bring it to my friend's place and plug it in to his Toshiba LCD the screen stays black. It stops saying "No Signal", but it doesn't seem to understand the signal coming across.
Fortunately, I have the auto-play option on so when I pop in a game it starts it automatically. Anything that normally runs at 1080p it's just a black screen, but for the games that run at 720p it works normally.
What you could try in this case is check the device sending the signal to see if you can force it to stay at 720p (while using an alternate video connector if needed, for example RCA cables), or maybe 1080i, not sure if that will help but it might be worth a shot.
Was this helpful?
Yes
No
Solution #3
posted on Oct 19, 2009
Not Rated)
torreyaz
Rank: Apprentice
Rating: 0%, 0 votes
I had similar issues with a brand new 46" LCD (Toshiba). The layout was cable box HDMI --> 7.1 2009 Pioneer Receiver --> TV. After hours of struggling including removing the receiver from the system and going direct (cable box HDMI to TV HDMI), still no signal. Then by pure accident I got it to work. Turns out the TV liked one HDMI cable better than another. I swapped my HDMI cables from the original wiring configuration and the TV came to life no problem. Running through my receiver no problem. I'm still leary of this TV but I'm going to let it run for now as I have a 2 year warranty from Costco.
Was this helpful?
Yes
No
Solution #4
posted on Sep 02, 2009
Not Rated)
reillybrenda
Rank: Apprentice
Rating: 0%, 0 votes
when put my hdim on all i get is a blue screen the dvd does not work and if i put it in another channel the dvd works i bought hdim cable at 99 euros
Was this helpful?
Yes
No
Popular Solutions for Flat Panel Televisions
Questions and Unsolved Problems for Flat Panel Televisions
Answer
Good quality flat screen TV in China
Answer
Looking 65 LCD pls give us your view
Answer
can you use a pioneer pdp503pg without the media centre? also the power light is flashing when you... (More)
Answer
I have two light black lines going from top to bottom on my new bravia TV. It is barely a year old.... (More)
Answer
model#35s65 wont turn on and the red light just blinks
Describe your Flat Panel Televisions problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Flat Panel... Experts
Top TV Repairmen
in , TX
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Appliances Cameras Cars Computers Electronics Home Audio TV & Videos Tools
Appliances Cameras Cars Computers Electronics Home Audio TV & Video Tools
Step 2: Select a product and click on add
I can't find my product
select
Cancel
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
