Question about Thetford Porta Potti
The vent valve leeks do i need a new seal or what ?
  • 32 Answers
I would say that you should get a new seal, that should get the job done.
Posted on Aug 03, 2009
Fuel leek from the carbs overflow
Hi, Neil and the usual suspects are:
1. Damaged or restricted fuel tank venting system.
2. Loose float bowl screws.
3. Damaged float bowl o-ring.
4. improper fuel level in the float bowl.
5. Worn or dirty inlet valve or seat.
6. Damaged or leaking float assembly.
7. Particle contamination in inlet fitting cavity.
Good luck and have nice a day.
Nov 02, 2015 | Motorcycles
My 91 honda prelude is leeking oil and its smokes when hot but cant figure out where its leeking from
easiest way is to get the dye and poor it into your engine. Then with the dye light you will be able to track the source. On those years the most likely spot was the intake manifold gasket and valve cover gasket. You also could have a blown head gasket that only blew on a oil intake side, doesnt mean that you would over heat
Mar 03, 2015 | Honda Cars & Trucks
Hi have mac allister water leeking out off trigger
the seal in the plunger valve of your wand is bad or possibly it froze and cracked...either way to work on it far exceeds the cost of a new one so you will just save yourself time and money by buying a new wand at a local dealership...good luck
Oct 22, 2014 | Karcher K2.26 Electric Power Washer
Mercuryoutboardmotor oil leeking from vent
if you mean the water intake on gearbox then the oil seal bellow the impellor housing has failed and needs replacing b4 the gearbox siezes due to water gettin in and not enough oil in it !
Dec 22, 2012 | Seloc Mercury Outboard Engine Repair...
I have a leek in my car, its the passenger side at the bottom
If your running an air conditioner, then your cannister is leaking. If it happens when it rains, then you have a leaky seal on door or defrost vent.
Jun 18, 2012 | 1998 Volkswagen Golf
Spark plugs keep oiling up..not always the same one, goes well after cleaning, but only lasts a day.
I would recommend doing a compression test to see if your rings don't have any leek by.And it could also be leaking valve guide seals.
Mar 02, 2011 | 1987 Mercedes-Benz 300-Class
Brand new Hiyachi DH24PC3 leaking oil from chuck on first use while using hammer only chisel application - is this due to overheating ?
Hi, these impact drills need greese to function properly and some modles leek more than others. As its new you could ask for a new seal, as this is what is allowing the oil to leek. Hope this helps
Jul 05, 2010 | Hitachi 3/4", Variable Speed Reservible,...
Wind seems to leek into my truck
Yes, replace/glue an new set of seals to all your doors.
Mar 30, 2010 | 1999 Chevrolet Silverado 1500
Coolant leak , changed hoses all 3 on chev cavalier 1994 2.2l. belt is loose,leak below water pump
check the gasket first u may get lucky if not bearing or seal going or gone
Jan 17, 2010 | 1994 Chevrolet Cavalier
Steam coming out of floating valve on handle.
No. if the steam is coming out, the vent valve is not seated on the vent and pressure won't build up. Either remove the plastic cover from the vent valve or slide it up enough so that the valve seals on the vent. If you remove the plastic cap, you will need to manually tilt the valve to "quick-vent" the cooker. Watch out for steam burns! Should work fine after that. You need to unplug the cooker and re-plug it to reset the "E4" error message.
Jan 16, 2010 | Wolfgang Puck 5-Quart Electronic Pressure...
Thetford Porta Potti  Logo
118 people viewed this question
Top Thetford Camping, Backpacking & Hiking Experts
Fredrik Str?hle
Fredrik Str?hle
Level 1 Expert
Tony
Tom Chichester
Are you a Thetford Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
