Question about Lenovo 3000 N200 Notebook - Intel Celeron M 530 1.73GHz - 15.4" WXGA - 512MB DDR2 SDRAM - 80GB - Com... PC Notebook
How do i switch the mic off - Lenovo 3000 N200 Notebook - Intel Celeron M 530 1.73GHz - 15.4" WXGA - 512MB DDR2 SDRAM - 80GB - Com... PC Notebook
  • Quratulain Habib
    Quratulain Habib May 11, 2010
    Can you please give your OS detail? Is this on Mac, Windows or Linux? also give version. Thanks.
  • 1,511 Answers
Double Click on the Speaker icon in the Tray (Bottom right Corner)
Then a dialogue box will appear, Click on the "options" > then "Properties"
Another dialogue-box will appear (You will see few radio buttons)
Like;
(o) Playback
(o) Recording
(o) Other
Click "Recording" > (and check the "microphone", better check everything) > OK
Now mute the "Recording" bar (Better mute every bar), (it will appear on the main 1st dialogue-box)
If Helpful, Kindly Rank.
Posted on Jul 17, 2009
How can I switch the mic input from the built-in mics to XLR input?
on the left side of the unit there is a small switch , , set this switch to MIc , or if using a condenser mic set to phantom-mic this gives the mic power , but I will caution you to watch you units power ind as with that setting you battery will drain down quicker than usuall , you will get best results with balanced mic's as the other types will introduce noise (thumping sound) into the recording also try to keep cord lengths down to less than 15 feet as this will introduce noise into recording as well
Mar 17, 2016 | Tascam DR-40 Portable Digital Recorder
I need to wire a silver salute mic to a cobra 142 gtl 5 pin what color wire goes towhat mic pin
dont go by colors.. go by what wires are on the switch and mic element.. mics can be rewired and no one told you the colors could have changed FYI..
Pin #1 ~ Audio
Pin #2 ~ Shield
Pin #3 ~ Receive
Pin #4 ~ Switch Wire
Pin #5 ~ Transmit
always go by connections not color of the wire. that way you learn and you can do any mic. to any radio.
Nov 30, 2013 | Radio Communications
Headphones are working and mic is not working
The mics are of two types: electrostatic(cheap and modern) and old-stiled "dynamic". Old souncards were automatically switching to the mics type. Modern soundcards have to be switched manually.
In "sound properties" you first must check in that mic is turned on, mic volume in max and in all menues avd buttons find something like "mic amplifier boost"and turn it on. It's only non-standart mic tuning option in standart systems. All other problems in defects. Soundcards can be verifyed by so:
(with maximal speaker and mic volume) many times plug in and plug out any reacheable mics and headphones to the mic connection nest (hole), and listen(or recording) resulting scratches. If scratches or other related sounds are abscend(only noise), soundcard is bad. The mic problem may be in "jack left-right interconnection". This useful thing may hang some improper cards. Also that cards often cannot work with dynamic type. And they very sensitive to a manufacturer, and model of mic.
Problem may be also in configuring multimode speaker nests in 5_1(7.1) cards like REALTEC - the mic nest may be switched to the speaker output mode. Open Realtec's control center(in control panel or quicklaunch icon) and check in mic nest to "mic mode" or switch mode from 5.1 to stereo speakers.
May 17, 2011 | Computers & Internet
What is the switch for on the Phantom power unit at the end of my AKG C747?
Hi,the switch for the phantom power on the microphone is to activation of the mic.Without the phantom being activated, the mic will not work.
It can only be activated with a mixer console that has a phantom activation on it. After connecting the mic to the mixer,activate the phantompoweronthe mixer and switch on the phantom power on the mic,and problem solved.
Note: Mic will not work if no phantom activated on the mixer.
Oct 20, 2010 | AKG C747 Professional Microphone
It comes on but not receiving
One of 2 reasons. First is common. Your mic or mic jack may be bad. The way the radio works, is the mic switch switched from receive and transmit. When the mic is not keyed then the switch is actually on receive, and when you key it, you switch it to transmit. So if there is something wrong with your mic, or it is not plugged in, the radio will not be in receive mode.
The next problem if a new mic doesn't solve the problem is...
there is an issue with your antenna or feed system. Make sure coax is good. Use an ohm tester. Make sure its not shorted.
Next make sure the antenna is good and tuned properly.
You may need to replace one or both.
Jan 27, 2010 | Radio Communications
Where in the circuit is Mic On/Off switch located? In other words, what components are between the mic and the Mic switch?
The switch is between the Mic element and the output connector.
Depending on the type of microphone will determin how the switch is wired.
Jan 15, 2010 | Telex WT-55 Belt Pack Transmitter (066)...
Mics plugged into the xlr module don't seem to
mics have any on off switches? look for a switch labeled internal external mic. Could be in the menu.
Larry
Jul 27, 2009 | Sony HVR-A1U Camcorder
Panasonic dvx1000a has no audio input, for xlr connector, the switch line mic is in mic pos. and the external mic not work in that camera.
You have to switch the CH1 and CH2 switches inside the lcd display to input 1 or input 2 to control the xlr inputs. If these switches are in int (L) and int(R) position, then you are adjusting the audio on the CH1 ad CH2 dials below the lcd viewer on the outside of the lcd for the on camera mic. Only use line setting on the front of the camera when you are receiving an audio feed at line level from an audio board. If you set the camera to mic setting, and you are receiving a line level audio signal, you will blow out the audio 0 way too loud, if you are receiving a mic signal and your switch is set to line, you will not be able to hear the mic with the audio Ch1 and ch2 all the way up.
May 17, 2009 | Panasonic AG-DVX100A Mini DV Digital...
Motorola maratrac mobile radio A7 control head problems
Hello scooter 34 1,
Are you able to get a new mic for your radio? Because I really think the problem is in the mic. Here is a test buy a cheap replacement mic that can be used with your unit and swap it out with your current mic. 9 time out of 10 this will solve the problem. If not the problem may be with the sensor switch inside of the unit itself, the sensor switch detects when the mic is activated, it avoids the galvanic response of the metallic switch in the mic. The switch could have malfunctioned. However I repeat, that I believe the mic has malfunctioned.
I hope this helps,
Shuttle83
Oct 29, 2008 | Radio Communications
Shure wireless UHF microphone
Make sure the microphone and the receiver are still broadcasting/receiving on the same channel.
Check that all of the appropriate connections are right from the receiver to the mixing board are connected as well.
I hope this helps!
God Bless you!
Oct 17, 2008 | Dual Pro2- WM795V Channel VHF Wireless...
Lenovo 3000 N200 Notebook - Intel Celeron M 530 1.73GHz - 15.4" WXGA - 512MB DDR2 SDRAM - 80GB - Com... PC Notebook Logo
88 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
