Question about HP OfficeJet 7410 All-In-One InkJet Printer
HP 7410 all in one
Set as default printer in control panel but will not print
with message displayed "door open" but all printer doors
appear to be closed.
thank you
  • 731 Answers
You may try this solution if the printer can make copies,it has resolved many driver related issues.
1.Right click on mycomputer, ->properties ->hardware ->Device manager - >Scrol down to "Universal serial bus controllers", click on + sign.
2.look for USB composite Device and uninstall it by right clicking. We have to make sure the USB composite Device is for your Printer.To check that, Right click on USB composite Device and then properties, there look in location it should say "HP officejet 7400".
3.Reboot the PC.
Posted on Feb 09, 2008
How to reset printer setting
Turn off the HP LaserJet 2840.
Press and hold down the "Enter" and "*" keys on the printer's control panel, and turn the printer back on.
Hold the "Enter" and "*" keys until you see the "Permanent Storage Init" message on the device control panel. Release the two keys to perform the NVRAM initialization. The NVRAM initialization takes just a few seconds, and the "Permanent Storage Init" message remains on the printer's display until the initialization is complete.
Ensure that the "Ready" message on the printer's control panel is visible. You can now connect the printer to your computer and print your documents. If the "Ready" message is not displayed and your printer is still stuck in a loop, turn off the printer and contact HP customer support (see Resources).
  • To reset an HP 2840 from your computer, open the HP Toolbox program, click "Device Settings," click "Service," click "Restore" in the Resets section and then click "OK" to confirm the action and restore the printer to its factory defaults.
Sep 26, 2013 | HP LaserJet 2840 Printer
Document feeder door open
The doc feeder is the one on top, there's a sensor in the hinge at the rear. If the tab is broken from the top cover, you need to fold a piece of paper and put it inside the horse shoe shaped sensor to get past the error.
Nov 12, 2009 | HP OfficeJet 7410 All-In-One InkJet...
HP colorjet 2605dn displays ''door open'' error message and light
On the memory controller board (the unit inside the printer which each toner unit makes contact with. If you open the front door and remove each toner,you will see a row of 4 contacts plus 4 leds and 4 receivers, encased in a metal casing/guard), there is a small white actuator, just to the left of the black toner,which is coupled to the scanner shutter lever.
If this is not correctly coupled, it will result in the "door open" message. The white actuator should spring back out towards the front of the printer when you press with a small flat blade srewdriver and release.
I had to remove top cover, rear plate, lhs covern High voltage psu and the memory controller board. I made sure the shutter lever and the actuator were set correctly and reassmbled.
Door open message was resolved.
Oct 06, 2009 | HP Office Equipment & Supplies
I can not print, the error is: LANG=ENGLISH, please help
Changing the Control Panel Display Language
The default control panel display language is set for English.
Supported languages are: English, French, German, Italian,
Spanish, Finnish, Danish, Dutch, Swedish, Norwegian, Turkish,
Polish, and Portuguese. Follow these instructions to change the
display language.
1 Switch OFF the printer.
2 Press and hold Select while switching the printer ON until
SELECT LANGUAGE appears in the display.
3 After the power-on self test, LANG=ENGLISH appears. Press
[Value+/-] until the desired language appears in the display.
4 Press [Select] to save your choice. An asterisk (*)appears next
to the language to indicate it is now the default.
5 Press [Go]. The On Line indicator is lit, and display messages
are now in the language you selected.
Sep 21, 2009 | HP LaserJet 4 plus Printer
HP 7410 printer displays error ''remove and check colour cartridge
I think that spring must have gotten loose that holds the cartridge in place, right hand side, put it back where it belongs, might want to compare with the other, black cartridge side.  Good Luck!
May 13, 2009 | HP OfficeJet 7410 All-In-One InkJet...
I haven't the manual for this printer color laserJet 2600n series,
HP Color LaserJet 2600n Printer - Installing Print Cartridges When a print cartridge approaches the end of useful life, the control panel displays a message recommending that to order a replacement. The printer can continue to print using the current print cartridge until the control panel displays a message instructing to replace the cartridge. The printer uses four colors and has a different print cartridge for each color: black (K), cyan (C), magenta (M), and yellow (Y). Replace a print cartridge when the printer control panel displays one of the following messages: Replace yellow cartridge, Replace magenta cartridge, Replace cyan cartridge, Replace black cartridge. The control panel display also indicates the color that should be replaced (unless a genuine HP cartridge is not currently installed). Change the print cartridge
  1. Turn off the printer.
  2. Open the front door. c00315320.gif CAUTION: Do not place anything on the transfer belt (ETB), which is located on the inside of the front door.
  4. Remove the new print cartridge from the bag. Place the used print cartridge in the bag for recycling. c00315322.gif
  5. Grasp both sides of the print cartridge by the blue handles and distribute the toner by gently rocking the print cartridge from front to back. CAUTION: Do not touch the shutter or the surface of the roller. c00315323.gif
  6. Remove the orange shipping locks and the orange shipping tape from the new print cartridge. Discard the shipping tape and shipping locks according to local regulations. c00315324.gif
  7. Align the print cartridge with the tracks inside the printer, and using the handles, insert the print cartridge until it is firmly seated. c00315325.gif
  9. Turn on the printer. After a short time, the control panel should display Ready.
    NOTE: If a cartridge is in the wrong slot or is the wrong type for the printer, the control panel will display one of the following messages: Incorrect yellow, Incorrect magenta, Incorrect cyan, Incorrect black.
  10. Installation is complete. Place the used print cartridge in the box in which the new cartridge arrived. See the enclosed recycling guide for recycling instructions.
  11. If a non-HP print cartridge is in the printer, check the printer control panel for further instructions.
    NOTE: When replacing or changing a black print cartridge, a cleaning page will automatically print. This helps prevent speckles on the front or back of printed documents. A cleaning page can also be generated using the control panel or the HP Toolbox.
Nov 03, 2008 | HP Color LaserJet 2600n Printer
HP 7410 Printer Error
Is the printer highlighted? Is it set as a default printer?
Oct 16, 2007 | HP OfficeJet 7410 All-In-One InkJet...
HP OFFICEJET 7410 "NO SCAN OPTION" the HP Director/Solution Center on scan menu and go to destination list tab 3. on the left side u will find a list of available destinations , move them all to the right side (front panel destination list) and save and then try to scan again , IT MAY WORK
Jan 01, 2007 | HP OfficeJet 7410 All-In-One InkJet...
HP OfficeJet 7410 All-In-One InkJet Printer Logo
43 people viewed this question
Ben Johnson
