Question about Canon Rebel XT / EOS 350D Digital Camera
Power problem at first, my problem was the error 99 and i waited a couple of months not repairing it and now i have this problem which is when i use my camera it's working fine with no-flash mode and then when i use it again after a while ( say couple of hours) the camera doesnt turn on and i need to charge the battery again!! PS:i have bought my camera before 11 months!! please help.
    Novelist:
  • 164 Answers
Per the symptoms that you describe, it seems that one of the two internal printed board circuit parts have a defective component that is draining out the battery current.
If you have only 11 months with it, I strongly recommend you to contact Canon and make valid the factory warranty.
The reason of it is that will require professional repair service for it, and it will be expensive if you wait and the camera is out of warranty.
Good luck and best regards,
Posted on Jul 18, 2009
Error 0xc05d0082
Remove cartridges,switch off the printer, dis connect usb cable & power cable.. wait couple of minutes..powering it wait till message appears for consumables.. install consumables., install usb cable.. check...for message.. Remove CMOS battery mounted on formatter wait for couple of minutes, power it then check..
Jan 31, 2012 | HP Photosmart C6100 All-In-One Printer
Canon MX320 Printer getting code error 5200 Please Help !!!
Please reset the printer
1. Turn off your printer
2. Press and hold the STOP/RESET button
3. Press and hold Power ON button
4. While holding the Power ON button, release the STOP/RESET button
5. While holding still the Power ON button, press twice the STOP/RESET button
6. Release the Power ON button
7. Wait until it display an "idle" message. It will take about a minute.
8. When "idle" appear, open the top cover to expose the cartridges.
9. Lift up the cover for cartridge holder and take out both the black and color cartridges
10. Return the cover of cartridge holder and turn off the printer
11. Return the top cover and turn on the printer again
12. After the printer initialize, return the cartridges.
1. Press and Hold the STOP/RESET button and wait until it self restart.
2. Release the STOP/RESET button the the printer is restarting.
3. Wait for a few seconds
Oct 07, 2010 | Canon PIXMA MX320 Color USB InkJet Printer
Error 77 message
The 77 error is caused by a fuser temperature sensor. The following steps can be used to possibly reset the Intellifax 4100 77 error.
1. Unplug machine then wait 15-20 minutes.
2. Hold down menu key. Plug in machine.
3. Release menu key at maintenance message.
4. press 91 then set button
5. press 99 then set button
6. Machine will warm up.
7. Press Reports key, then press 1. This will test if the machine can
print.
If these steps do not reset the error the thermal fuse would have to be replaced by a repair technician.
Jul 22, 2010 | Brother IntelliFAX 4100 Laser Fax
Printer repair brother mfc 8840dn
To Clear the error follow the procedure
1:) Turn Off the printer
2:) Hold down the menu option on the front panel and turn on the power while the menu button is still pressed
3:) Release button after 5 seconds (after the Please Wait message)
4:) If error still occurs Press 91
5:) If it still ocurs press 99
This should clear the error.
May 07, 2010 | Office Equipment & Supplies
InFocus IN72 shuts off after 20 min.
internal error. if the lamp looks ok and it doesn't have many hours on it, it might be the power supply. the capacitors dry out and do not supply sufficient voltage. the in72s do have that problem.
Aug 27, 2009 | InFocus IN72 Multimedia Projector
Playstation has a yellow light blinking and have a game inside won't come off
yellow usually means a sytem error. Try to power the system of, wait a couple of minutes and turn it back on and try to eject the game as soon as you turn it on. then when the yellow light is gone try to play your game again. good luck!
Mar 10, 2009 | Sony Playstation 3 (PS3) Console
Error e74
99% of E74 error caused by the GPU. you can fix them like the way you fix the 3 red light issue. you can get the repair kit for like $10. I got my from the site below.
Xbox360 Repair kit
Dec 10, 2008 | Microsoft Xbox 360 Console
Canon 1000D
I have the same problem with my 1 month old EOS 1000D.
I tried cleaning the lens contacts, but the problem was not solved.
ERR 99 is a generic error. I think this is a common message for a lot of malfunctions.
Try the following steps.
1. Remove the lens and try some clicks.
If you still have the problem then it may not be the fault with lens or contacts.<go for step -2>
If u still have, you have to get it repaired by professionals.
2. Remove the memmory card and try some clicks..(without Card)
Hopefuly u will find it working...
Format your Memmory card & reinstate.
For me the 2nd option worked...(for now !!)
Aug 22, 2008 | Canon EOS Digital Rebel XS / 1000D IS...
Error 99
Trouble shooting Error 99
1. Solution: Remove and replace the battery.
Power the camera off
  1. Remove the battery.
  2. Wait 15 seconds.
  3. Replace the battery.
  4. Power the camera on.
2. Clean the lens contacts.
Clean the lens contects on the rear portion of the lens with a clean pencil eraser.
  • Mount the lens on the camera.
  • Take a picture.
If the error persists, the camera and/or lens may need be serviced by a qualified Canon Service Technician.
3. Remove the 3rd party accessory.
Please remove the 3rd party accessory and replace it with genuine Canon Accessory.
4. Solution: Remove third party lens and try with Canon EF or EF-S lens.
Remove third party lens and try with Canon EF or EF-S lens This link will bring you to the camera page on Canon's website: More trouble shooting, drivers and downloads http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=215&modelid=11154#DownloadDetailAct Best of luck. Could you please rate this advice. Thanks so much!
Mar 27, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Kodak Easyshare 5300, fatal error 3812
That's an error with the ink. Try updating the firmware on the printer. Here is the link to the latest firmware from the Kodak website.
http://www.kodak.com/global/en/service/downloads/dln_ekn033540.jhtml?pq-path=9106
Dec 25, 2007 | Kodak EASYSHARE 5300 All-In-One InkJet...
Canon Rebel XT / EOS 350D Digital Camera Logo
91 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
