SOURCE: ciruit or block diagram of pioneer home theater system
The (schematic) circuit diagram is included in the service manual. A downloadable pdf copy is available here.
Hope this be of help. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
SOURCE: Hook-up Diagram for Samsung HT-Q70 Home Theater System
try to download the user manual here http://www.samsung.com/us/support/download/supportDown.do?group=audiovideo&group_cd=&type=hometheater&type_cd=03030000&subtype=hometheatersystems&subtype_cd=03030100&model_nm=HT-Q70&dType=D&mType=&model_cd=&menu=download&menuLink=/support/download/supportDown.do&prd_ia_cd=03030100&disp_nm=HT-Q70&isEqualsY= let us know. thanks.
The T300 uses a 2.5A fuse.
To replace the fuse:
1. Unplug the AC cord from the AC power source,
then remove the AC power cord from the speaker's
power connector.
2. Remove the fuse cap with a small, flat blade screwdriver
(see diagram 2).
3. Remove the fuse from the fuse cap
(see diagram 3).
4. Replace the fuse inside fuse cap with another metric
5X20mm size fuse
5. Replace the fuse inside the cap, replace the fuse
and cap in the power connector (see diagram 5).
6. Connect the AC power cord to the speaker and
raise it upright.
7. Connect the power cord to an AC power outlet
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Yamaha-HTR-5230-Receivers-manual/id/319dj893/t/2/
