Shower leaks very bad when turned on. Water sprays out from behind each knob and from behind the valve plate. Then after about a minute water starts to come out from underneath the one peice shower stall. This is a new manufactured home that sat for over a year with no occupants, the shower has never been used before now. Water is somehow getting behind wall and coming out from under shower. I posted this in the wrong area the first time. Please Help....
    Sergeant:
  • 347 Answers
There is a problem with the rubber washer or bushing. it may be brittle since it has not been used for a long time. remove the handle then assymbly to locate the rubber washers, the washer seals the flow of water.
Posted on Jul 17, 2009
Water leak behind shower wall when i turn on hot and cold water
If it only happens when you turn the water to the shower on, it must be a problem with the piping after the valve. Take the shower arm out and wrap it with Teflon, it could be as simple as leaking threads. It could also be a leaking/poorly soldered copper fitting, or even a defect in the enclosure itself.
Feb 27, 2014 | Home
My shower has stopped working. The water in the faucet still works but in order to turn my shower on, I need to pull a knob up and turn the middle valve to start the shower. When I do this, the shower does...
mcdevito75 here, sounds like the valve is faulty and needs replacement. Contact a plumber or handy man, your local newspaper ads can help.
Jun 13, 2010 | Home
I a leak under my tub, think it's from the shower, it doesn't leak with a full tub of water or ewhen you empty the tub, but when you're in the shower a flow of water comes out under the shower piping side...
Check out the faucet plate mounted on tub side for a good seal. Water can leak down this plate causing it to look like the valve is leaking.
When you are in the shower it splash's water against the valve and water will run down behind it. Check the tub spout and if you have tile check the chaulked joint where tub and wall meet.
Jun 02, 2010 | Plumbing
The faucet leaks, behind the wall when the shower
The most common reason for basement leakage is from the seal at the drain or the seal behind the overflow. With the overflow, the water trickles down after bouncing off your body and back onto the tub. This possibility MUST be eliminated first before determining the next step, Turn on the cold water and fill the tub and let the water go into the overflow for about 5 minutes. This will simulate someone in and using the shower. Check for leaks in the basement.
This test, as simple as it is, will also implicate bad plumbing connections at the valve itself behind the wall as well as eliminate backsplash from the showerer bouncing back onto your control valve(s).
If you have a leakage, wait a day and, with the drain open, turn on the hot/cold valve(s). and waste some water for another 5 minute test. This test eliminates the overflow as a suspect, and with the drain open almost always eliminates the drain as well. Hey..in plumbing there are no perfect answers.
If you still have leakage and no one is showering you have pretty well isolated the valve or connections to the valve. If you don't have leakage, it points to water bouncing off the body and onto the control valve(s) at which point resealing would be in order.
You can get leakage also if the caulking around the tub where the tub meets the wall has gone south. Stamped out steel tubs (common in rental apartments) have open corners so if the wall-to tub caulking is poor then the shower bounce off the body will easily trickle to the basement. This is not an issue with cast iron or fiberglass/plastic tubs.
If these tests truely point to the valve(s), repost your ? and refer to the drain tests completed, and supply as much information as you can about the brand and age of your valve(s)
Jun 02, 2010 | Moen & One Handle Tub & Shower Faucet
Leaking form shower facet also leaking from
id say your tub spout or shower pipe is leaking and running down behind remove both and replace teflon tape see if it stops
Mar 14, 2010 | Home
The all in one tub/shower faucet constantly flows. What can I do to fix this problem? Now I am a woman, so please make it simple.
Go to home Depot or loew and buy the seat replacement kit for your model of faucett. Your going to have to break out the tools (Philipps Screwdriver and a larger adjustable wrench) The remove the shower knob cover with a knife to access the mounting screw. Remove the screw and then the knob. (STOP!) Go turn off the water for the residence now! Then come back and remove the nut holding the faucett in place. The whole assy will with a little effort will come straigth out at you. Moen isnotorious for having to remove a plate from the bottom of the valve. NOTE the position of that plate and then remove it. Remove all of the seat seals one at a time and replace them with the new ones you purchased. Reinstall the NEW lower plate in the same position you removed the old one. Reinsert the assy back into the valve body. Tighten the retaining nut. Reinstall knob and secure with screw. Replace knob cover. Turn on the water NOW. Enjoy the non-leaking faucett.
Jan 21, 2010 | Moen & One Handle Tub & Shower Faucet
I just installed body sprays in my shower. Two on one side and two on the other. I went to the basement to turn the water back on. I came back to the shower and one side of body sprays are running, the...
If the sprays are on individual controls for the sides you MAY have a stuck pressure balancing valve or mor likely the service stop valves MAY be closed. These are small screwdriver controlled valves usually behind the escutcheon of the control valve. They turn CCW to open.
Nov 19, 2009 | Grohe Home
Water sprays out the diverter
Remove hot/cold button in handle, remove screw/pull off handle. Remove the two screws in the wall plate/remove plate. Use a wrench to remove the diverter assembly. Get new diverter assy and reinstall eveything. You don't need to turn off the water.
Jun 09, 2009 | Delta Faucet #RP320 Divert Assembly
Water leak outside valve
You have a leak where the back plate goes up to the wall OR there is a gasket missing from the trim installation. If this is a tile shower i would suspect the first and use clear tub/tile chaulking to seal around the edge of the plate paying close attention to the grout lines.
Phil
Dec 09, 2008 | Rohl A2400 Country Bath TRIM ONLY PRESSURE...
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
