Question about Texas Instruments TI-83 Plus Calculator
My calculator works fine but recently when I use it the screen is very light. I already have it on maximum darkness and sometimes it works but occasionally the screen flickers?
  • Texas Instru... Master
  • 8,064 Answers
When screen is at maximum darkness you see almost nothing.
Here how you change screen contrast (just in case another readed does not know how to do it).
To increase contrast:
1. Press [2nd] key then release it
2.Press [UpArrow] key then release it.
3. Repeated steps 1 and 2 in sequence, until contrast is dork to your taste.
To decrease contrast:
Follow the algorithm (a very big word for procedure) above substituting [DownArrow] for [UpArrow].
Hope it helps.
Posted on Sep 13, 2009
  • k24674 Sep 13, 2009
    Sorry I do not know what that dork means, nor where it came from. I cannot edit the post.
Calculator will not turn on.
Here are some steps which you can try, one might work for you.
- First thing that you have to check is the battery of the calculator, it might be low of charge already.
- Check if you have the "Reset" hole at the back of it, use a pin or a ballpen point to reset it.
- You can try to give 3-4 good tap at the back of the calculator using your palm, sometimes this gets the calculator work again.
- Also try to notice the LCD screen if you get a faint display when lighted. Sometimes this is caused by low battery charge or failing LCD screen.
Hope this helps.
May 30, 2011 | Texas Instruments TI-Nspire Graphic...
The calculator crashed two times several days ago while I was using it. It worked fine the following day, but after that the screen became very dark. So dark that I need a flash light shining at it to see....
I will address one part of the question only: I will avoid the speculations.
How to change the screen contrast
  1. (TI-Nspire with native keyboard): With the TI-Nspire keyboard in place,
  2. Press the ON button to turn calculator ON.
  3. Press and HOLD the Control key [CTRL]
  4. Press [+] to darken the screen
  5. Press [-] to lighten the screen (Your case)
  6. Stop when contrast is adequate.
  • TI-Nspire with TI84PLUS keyboard: With the TI84PLUS keyboard in place
  • Press the ON button to turn calculator ON
  • Pres the [2nd] key and RELEASE it
  • Press the [UpArrow] of the NavPad to darken
  • Press
Feb 15, 2010 | Texas Instruments TI-Nspire Graphic...
What do i do if the calculater will not turn back on ? i installed new batteries already
The most common problem in the TI calculators is not a real problem at all. When you replace batteries, the screen display may become too light and you cannot see that the calculator is already ON.
Increase the darkness of the display. Here is how to do it.
  1. Press the [2nd] key and release it.
  2. Press the UP navigational arrow and HOLD the pressure.
On the Top right corner of the screen a number is displayed (between 0 and 9). The value changes as the screen contrast changes.
When the contrast is adequate (to your liking) release the Up arrow.
Jan 04, 2010 | Texas Instruments TI-84 Plus Calculator
My texas instruments ti-86 is dark all the time, help me please
After changing the batteries the calculator is restored to factory defaults, but the screen contrast may change. The screen may be too light to see anything or., as in your case too dark.
To lighten screen
Press [2nd] key and release it.
Press and hold [DownArrow] until screen is light enough.
To darken screen
Press and hold [UpArrow] until screen is dark enough.
Hope it helps.
Thank You for using FixYa and for rating the solution.
Dec 04, 2009 | Texas Instruments TI-86 Calculator
Calculator will not turn on. I have a texas instrument calculator TI85 that will not start. Any suggestions?
The batteries may be depleted, and they need to be replaced. If abtteries are fresh and the calculator seems toi refuse to turn ON, the screen darkness must be increased before declaring that the calculator does not start. If screen is too light you won`t be able to see that calculator is already ON.
To increase the contrast.
  1. Press the [2nd] and release it.
  2. Press and HOLD the UpArrow key until you can see something on the screen.
  3. The screen may have about 10 levels of darkness
Hope it helps.
Thank you for using FixYa and for rating this solutions.
Nov 30, 2009 | Texas Instruments TI-85 Calculator
Brightness problem
try changing all electrolytic caps in the horizontal circuits
Aug 28, 2008 | Boundless Technology Tatung VM 9AF 9" CRT...
Brightness sometime too light and sometime too dark
I would say there is a problem in the horizontal / high voltage section, but I have no information on this model.
Aug 27, 2008 | Boundless Technology Tatung VM 9AF 9" CRT...
Texas Instruments TI-83 Plus Calculator Logo
130 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
