Question about Fuji FinePix V10 Digital Camera
I left my camera on and the battery run out. I have charged up the battery but have no camera memory at all what can I do?
So sorry to have bothered you but had the battery in the wrong way
Thanks anyway
Posted on Jul 21, 2009
I am having a problem with the Samsung Galaxy light holding a charge. Are other people complaining about it too.
if the battery will not charge there are possible explanations
that you recharge the battery before it is run completely down and now it has a memory level that it will not charge past
the light or camera is being used excessively
the unit is left switched on when not in use
trry replacing the battery with a new one
Feb 11, 2015 | Samsung Galaxy Tab 7.7 P6810 16GB Wi-Fi...
Hi, I have a sony handycam hdr-cx160 with I bought a np-fv70 battery and my problem is that my camera turn off after I spend some time used it, Like 2 or 5 minutes. it is charged, the camera recognize the...
Hi luismasramir ,
Seems to be the case where the battery is not fully recharged , Please follow the below steps :-
  1. Please make sure that you charge your battery fully , till the time you see an indicator for the battery being fully charged , or may be you see an icon in the display screen with the charge status.
  2. As far the 6.30 hr duration that you have mentioned, this duration reflects the time that you have left for total recording space on your disk or memory card depending on your current source for recording.
  3. The above duration is not to be confused with the battery usage time.
Hope his helps ...:)
May 11, 2011 | Sony Handycam HDR-CX160 Camcorder
Won't work
Are you sure the battery is charged ? i have seen many Casios that do not recharge fully if the camera is left for long periods with the battery flat - the battery goes below the 'float' level and the charger does not work. See if you can borrow another battery or use a generic charger that does not look at the battery level. A good camera shop should be able to help.
Jun 09, 2010 | Casio Exilim EXZ75 Digital Camera
BATTERY DOES NOT CHARGE Received a "Vivitar T328" camera yesterday. Inserted the supplied battery and a new memory card into the camera and connected the camera via "USB" cable to the supplied charger....
How old is the battery? If the battery is refurbished or old it might just not charge anymore.
Also, do you have a separate charger for the battery? Many cameras do and that is how they charge, not when the battery is still in the camera.
Apr 09, 2010 | Vivitar ViviCam T328 Digital Camera
My camara quickly runs out of battery
Here are the steps for the low power problem: 1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher). 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera 3. Turn on your camera without the memory card. (If it works then it?s your memory card that is faulty)
Jan 21, 2010 | Kodak EasyShare CX7530 Digital Camera
I have a Z730 Kodak Easy Share. I was told by a
True. Camera batteries, along with cell phone batteries, have something called a memory. What's best to do is initially when you get it to run it until it won't turn on the first time, charge it up fully and run it to empty again, and on the third time it should have developed a battery memory to last that long. By putting it on the dock too early you are setting the lower limit of the battery and when it says empty there could still be up to 15% left on your battery. Good luck and I hope you have fun with your new camera!
Dec 02, 2009 | Cell Phones
Place my camera on the charging unit and it starts to charge by indication of the green lights and then in second the lights turn red and it stops charging. I have purchsed a new battery and the same thing...
Run the battery all the way down until completely dead and then try recharging. Nickel metal hydride (NiMH) batteries don't develop a "memory" quite like the old nickel cadmium (Ni Cad) batteries
OR
Try taking out the memory card. I had the same problem, but for some reason I had the memory card out and the green lights returned and my camera charges correctly now
OR
Had the same problem, and like mahav said, it was an issue with how my battery was arranged in the camera itself. Adjust the battery, and hopefullyy that will work.
OR
This happened to me. The cause was the battery did not fit into the case, This led to poor connection of the battery. After I fixed the loose battery , it worked perfectly till today.
Thanks
Have a nice day.
Apr 23, 2009 | Kodak EasyShare Z760 Digital Camera
Kodak EasyShare Z760 won't charge.
The problem might be that the battery has developed memory and won't charge further. My first battery used to do that, but then I read that you shouldn't leave the camera on the dock all the time nor keep the battery fully charged all the time because of the problem of developing memory. You might try running the battery completely down by taking pictures until it shuts down. Sometimes when my battery is low the dock won't charge (but goes straight to the red light), but when I run it completely down when I put it on the dock it charges properly. I hope this information helps. :-)
Jan 30, 2009 | Kodak EasyShare Z760 Digital Camera
Battery charge
I called Kodak last night, they told me to turn the camera off, then remove the batteries and the memory card then wait ten seconds then reinstall both. Then turn the camera back on.... IT WORKED~ try it!!
Dec 01, 2007 | Kodak EasyShare CX7530 Digital Camera
Can't use chargeable batteries
If your camera doesn't work with NiMH, then it's most likely that you have either one or more bad atteries, or your camera is defective. p. 6 from the user guide: "..Ni-MH batteries left unused in storage for long periods can become ?deactivated?. Also,repeatedly charging Ni-MH batteries that are only partially discharged can cause them to suffer from the ?memory effect?. Ni-MH batteries that are ?deactivated? or affected by ?memory? suffer from the problem of only providing power for a short time after being charged. To prevent this problem, discharge and recharge them several times using the camera?s ?Discharging rechargeable batteries? function. By repeating this cycle several times, the temporary reduction in performance caused by ?memory? or ?deactivation? can be remedied and the batteries can be restored to their original performance levels. ..." Sorry i cant help you more..
Dec 23, 2005 | Fuji FinePix A310 Digital Camera
Fuji FinePix V10 Digital Camera Logo
108 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
