BENCH PRO Model JS-2102 Compound Miter Saw
Some manufactures will have a set screw also. Look for a small bolt in the rear of the saw which is made to stop it at zero degrees. If someone has spun it in to much that will keep the saw from reaching zero. However, if it is stuck in that position you will need to clean the track but also make sure there isn't another screw locking it into its current position.
Check base groove for debris / damage
SOURCE: top plate filing angle for a MoCulloch Pro Mac
this all depends on the chain that you have on it. a person can buy any angle chain for most saws. you will need to figure out what chain you have to see the right angle. sorry i can't help more.
SOURCE: Rented Makita LS 1011 Manual.
You can get the manual on the link below. Just scrool down to Product Details then click on manual.
http://www.amazon.com/Makita-LS1011N-10-Inch-Slide-Compound/dp/B0000223I8
Good Luck Please rate 4 thumbs up and please leave a Testimonial
SOURCE: I have an Hitachi NT65ma2
The nailgun uses 15 gauge nails up to 2 1/2 inches long:
http://www.hitachipowertools.ca/en/Products?cat=29&pid=74&tab=spec
it needs to be dismantled
cleaned and lubed ?
any mech knows this find one and
GET ER DONE!
or as many do wd40 the snarf out of it.
the maker does not exist or is in China'
gee, who sold it new,Harbor Fright?
or alibaba.com
no hits all even on makers name,
so that is super bad that, and parts, not sold.
