Question about HP OfficeJet 7310 All-In-One InkJet Printer
Error:Oxafed265be the printer buttons are all flushing,and the printer screen displays the above message Error:Oxafed265be
    President:
  • HP Master
  • 1,447 Answers
It is the probem printer cartridge not active print
Posted on Jul 17, 2009
How to enter service mode in canon ipf605
Ansewer
Enter the Service mode following the procedure below.
1) Turn off the printer.
2) Turn on the printer while holding down the [Paper Source] button and [Information] button.
* Keep pressing the above buttons until "Initializing" appears on the display.
3) "S" is displayed in the upper right corner of the display showing the version.
4) After display of "Online", pressing the [Menu] button displays the SERVICE MODE top menu and the MESSAGE LED flashes.
Aug 05, 2014 | Canon imagePROGRAF IPF605 InkJet Plotter...
Printer hp c6280: error message "oxc18a0401" what
Please perform the following steps SWITCH ON THe PRINTER.ONCE THEERROR COMES in the display screen DO THE FOLLOWING Press and hold the * key.
Press the # key and release both keys.
Display should say Enter Special KeyCombo
Press and release the button one by one in sequence the 1, 2 and 3 buttons.
display screen says "support" R0631M.
Press and release the right arrow button until the display says System Configuration Menu.
then Press and release the OK button.
Display should say Hardware failurestatus. If not there already, ArrowKey over to Hardware failure status
Press and release the OK button..Display should say Hardware failure status: Clear. Press OK to clear.
Press and release the OK Button. Message changes to Hardware failure statusCleared. Press Cancel to continue.
Press and release the CANCEL button as many times as necessary, so that, eitherthe Welcome to Photosmart Express screen appears, or, the Ink System Failurescreen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
Using the Power Button, turn the unit OFF and unplug the power cable fromback of the printer and wall outlet.
Wait 30 seconds for the power to get discharged and then plug the power cableinto the wall outlet first and then into the back of the printerTurn the unit on. The printer may display message USEPOWER BUTTON TO SHUTDOWN THE PRINTER followed by PRESS OK TO CONTINUE. PressOK. The Printer will start the ONE TIME INK INITIALIZATION PROCESS. Allow thisprocess to complete and do not interrupt. Once the initialization process iscomplete, the printer will print out a Diagnostic Page.
Aug 01, 2011 | HP Photosmart C6280 Printer
What does error Oxc05d0281 mean
This error message means" ink system failure " and to resolve this issue please follow these troubleshooting steps:
Unplug the printer and wait 30 seconds for power to discharge.
2. Plug in the printer.
3. Hold the CANCEL and OK buttons simultaneously, and keep them depressed while you hit the ON button. This resets the printer.
4. When the printer turns on, if you still get the error message, it's OK. Then perform the steps listed
1?Press and hold the “*” key
2?Press the “#” key and release both keys,Display should say “Enter Special Key Combo”
3?Press and release in sequence the “1”, “2” and “3” buttons
4?Press and release the right arrow button until the display says “System Configuration Menu”.
5?Press and release the “OK” button.
6?Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure
7?Press and release the “OK” button.
8?Display should say “Hardware failure status: Clear. Press OK to clear”.
9?Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
10?Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
11?Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
12?Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
13?Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK. The Printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
After you perform the steps listed above, when you are at the step at the end where you are pressing the cancel button until you get to the WELCOME screen, if at some point you see a message, “Inproper shutdown, hit OK”, go ahead and hit OK and the Welcome screen should appear.
One thing that is nice about this method is that it doesn't use up all your ink doing a recalibration.
The error message should not pop up so try to print a self test Press Setup menu on the All-in-One then scroll using the arrow key and select Print Report then select Self Test Report.
all the best
Jun 04, 2010 | HP Photosmart 3210 Printer
Cannot print, scan or copy. Continue to receive
Solution
  1. Remove and then reinsert the cartridge indicated in the error message.
  2. If the error is still displayed, clean the contacts. Click here to see how.
  3. If the error message is Error. Remove and Check Black or Photo Cartridge , the following steps may help:
    1. Remove both cartridges, lower the latches, and close the printer access door.
    2. Turn off the unit by pressing the On button on the front panel. Wait for the printer to completely shut down.
    3. Turn the printer back on by pressing the On button.
    4. When the message display reads Insert Print Cartridges , open the access door and replace the cartridges.
  4. If neither of the steps above fixed the problem, either the cartridge or the printer is faulty.5. Replace Cartridge.Please rate my response!!!Thanks,SF
Jan 28, 2010 | HP PSC 2410 All-In-One InkJet Printer
Printer won't print. Check printer error message
To clear error messages displayed on the LCD or if the printer is not functioning as expected, it may be necessary to simultaneously press Stop/Reset and ON/OFF buttons.
  1. With the printer powered on, press and hold down the <Stop/Reset> button then press the ON/OFF button.
  2. Once the printer is powered off, hold down <Stop/Reset> and then press <ON/OFF>.
Dec 13, 2009 | Canon PIXMA MP530 All-In-One InkJet...
When display "84 replace Photoconductor" appears, and we put aq new photoconductor into the printer, the same error message above comes back, and we can get by this point.
Turn printer off. Press and hold the right arrow and checkmark. While holding, turn printer on. Hold button combination until small clock appears on the screen. Once menu comes up, select the Reset PC count. That will fix your issue.
Oct 30, 2009 | Lexmark E350d Laser Printer
Error 0xc18a0301
Error: 0xc18a0301 fix from HP tech support:
Let us perform some steps to isolate the issue and find a fix for it.
Please perform the following steps and let me know the message that will be displayed on the printer.
A. - Press and hold the “*” key.
B. - Press the “#” key and release both keys.
C. - Press and release in sequence the “1”, “2” and “3” buttons.
Screen says "support" R0631M
Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK. The Printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
Is the error message still being displayed on the printer?
Print a self test page to check the functionality of the printer.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 21, 2009 | HP Photosmart C5180 All-In-One InkJet...
Error message shows up on printer screen oxc18a0101
Found this link that tells you how to reset the printer.
http://www.fixyourownprinter.com/forums/printer/39471
Excerpt on resetting the printer from the post linked to above:
These are from the link above:
Reset the system by holding down the OK, Cancel, Black, and Color buttons down at the same time and turn the 3310 off. Keep holding the buttons down until the printer shuts off and then turn it back on.
Apr 05, 2009 | HP Photosmart 3310 All-In-One InkJet...
60.40 Error Message on HP Laserjet 5025 MFP printer
OK I had the hp error code some problem and here is the conversation I had with the tech...
James Cowan: HP error code 0xc18a0001
Earnest: I will assist you in this regard. I understand that a error code with 0xc18a0001 with "Ink System failure" is displayed on the front panel of the All-In-One printer. Am I correct?
James Cowan: Correct
Earnest: May I have the model number of All-In-One you are using?
James Cowan: c6250
Earnest: Please let me know the room temperature in which printer is replaced
James Cowan: 67 degrees F
Earnest:: OK. Please perform the below steps on the front panel of the printer to resolve the issue
James Cowan: OK
Earnest:: Press and hold the "left arrow" key. Press the "Setup" key and release both keys, display should say "Enter Special Key Combo". Press and release the "OK" button
Earnest: Please ignore the above steps
James Cowan: OK yes nothing seemed to do anything
Earnest: Please perform the below steps on the front panel of the printer. Press and Hold the "Print Photos" & "Red Eye Removal" buttons. Release both buttons. Display should say"Enter Special Key Combo". Press and release in sequence"Red Eye Removal", "Print Photos", "Red Eye Removal"
Earnest: Display should say "Support" and display the FW rev (something like R0616R)
James Cowan: COxxFN0723BR
Earnest: OK. Press and release the right arrow button until the display says "System Configuration Menu"
James Cowan: OK
Earnest: Press and release the "OK" button
James Cowan: OK and it says hardware failure status
Earnest: Display should say "Hardware failure status: Clear. Press OK to clear". Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue". Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. Please do not try to print at this stage
James Cowan: OK
Earnest: Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet. Let me know once you are done with the above steps
James Cowan: OK its unplugged
Earnest: Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer. Turn the unit on. The printer may display message "Use POWER button to shutdown the printer" followed by "Press OK to continue". Press OK
James Cowan: OK
Earnest: Let me know the message displaying on the front panel of the printer
James Cowan: printer preparation occuring - do not interrupt
Earnest: OK
James Cowan: OK its done
Earnest: Let us print a self test page from the printer now
James Cowan: OK deal
Earnest: 1) Load letter, A4, or legal unused plain, white paper into the input tray
2) Make sure that the printer is on and loaded with unused plain, white paper
3) Press Setup. The Setup menu appears
4) Press the down arrow button to select Tools and then press OK
5) Press the down arrow button to select Self-test Report , and press OK. The self-test report prints
James Cowan: OK printing
Earnest: OK, please check whether all the colors pritned perfectly on the test page
James Cowan: Perfect
Earnest: Great... Cheers!!!
James Cowan: Thank you very much
Earnest: Now you can continue using the printer.
Feb 22, 2009 | HP Office Equipment & Supplies
Scanner Error Power Turn off than on
If you are get that error message than unplug the power cord, and than press Poun and Number 6 Keys together on the keypab of the printer. While these keys are pressed and hold, than at the same time plugged in the power cord and dont release the two buttons.
After say 30 second you will get a new message on the screen of the printer.
All of the above steps actually reset the printer. I hope this will work.
Regards,
Lalit
Aug 27, 2008 | HP OfficeJet 7410 All-In-One InkJet...
HP OfficeJet 7310 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
