I realise this is a late response, however Gosh no, do check the max towing weight of your model. we have a 2007 Grand Picasso 1.6 diesel and it is very light and while great as a vehicle not so much as a towing vehicle. I check the max tow weight as 1500kg braked
the 625 max loaded is around 1800kg so the car would be grossly overweight.
SOURCE: Hi, I'm thinking of fitting
fitting rear flaps is a simple job depending on the kit you buy......you may find the rear window gets dirtier with flaps fitted,due to spray being finer.(citroen is the same a puegeot)
SOURCE: how SERVICE LIGHT RESET for
Regards,
Tony
Testimonial: "thanks for your help"
SOURCE: citroen c4 picasso vtr+ 1600hdi what does the
no idea to be honest ,when i get another one in for service i will have a look but normally yellow wires are to denote the airbag system
SOURCE: c4 wont start after overfilling with fuel
Never heard of this one before thats for sure ,try working the hand pump under the bonnet and see what happens
SOURCE: How to remove plastic covers over brake lights citroen c4 grand picasso vtr
They're glued together, you would have to break them to get them off.
