Question about ConnectGear 4 Port Video Splitter 250mhz, 1920 X 1440, Metal (CG25VS4) KVM Switch
Capasitor the capasitor on the board blew up it is right behind the power inlet can I get another capasitor and replace it?
  • 205 Answers
Re: capasitor
You can try, but it may have blown due to some other problem. If you see what type/value it was give it a try. If it physically blew up I would wear safety glasses before you power up the new one if you're going to have the case open.
Posted on Nov 18, 2007
0 characters
3 Points
I have an insect killer model no. Z27886-BS the bulb is blowen where can i get a replacement bulb for this item?
Yes it is! Lloytron F4T5BL 4 Watt on Amazon or Ebay 5 pound approx. There are other makes of higher waltage
May 14, 2014 | KVM Switches
Eurobox 9700 plus
Could you please give more information??have you checked all your connections ? are the cables in the correct inlets.//
Sep 26, 2013 | KVM Switches
How do i switch from pc to pc using the key board keys??
Hit scroll lock twice and priess the left or right arrow.
Jul 17, 2010 | Inland 08216 2-port KVM Switch
My remote works sometimes and then does not work anymore....
This could be caused by bad, worn, corroded battery terminals, The main circuit board could be faulty or bad capacitors or other electronical components, or the buttons are worn down. Either way, I do beleve you are better off getting a replacement remote cheap. Universal or Original Replacement.
Dec 11, 2009 | KVM Switches
Tripp Lite KVM monitor light doesn't come on anymore .....
The switch may be the problem but it also may be the monitors internal power supply. To check you can open the case by the little switch and remove the plunger ( the little pin that moves up and down) If you get a picture back then the switch is the problem and you will have to bend the flat spring up to give it a little more movement. I would be if the monitor is about 2-3 years old that the problem is in the power supply board. After a few years many LCD monitors have issues with the power boards blowing capacitors. It happens on desktop monitors and rack mount units too. If you have an external power adapter for the monitor check the voltage output and replace if it is not steady. If the power supply is internal to the monitor then you will need to open the case and check the capacitors for heat damage. Check our site at: for pictures of what to look for. Replace any that look like the pictures and you should be back going again. The values that you will need are going to be marked on the sides of the bad caps. Be sure to use a high temp replacement or the problem will be back in a month or two. If yo don't want to do the repair yourself we do offer a repair service of the monitor for $40 plus return shipping. If you have any questions just let me know.
I hope this helps, if so please rate our solution.
Corporate Computer
Sep 22, 2009 | Tripp Lite Lite 16-Port 1U Rackmount...
AP5201 KVM was working; after power down, moving rack, setting up again -- no keyboard action. Got the right plugs in the right ports. Powered down as the manual says and powered back up. Tried different...
If other keyboards and mice won't work, it sounds like your KVM bought the farm. Does it have any power lights that come on? is it plugged into a live outlet? Are they PS2 ports or USB? PS2 ports don't like power surges. Is the device plugged into a UPS? Does the UPS have power or is is tripped? In a server room?
Aug 22, 2009 | APC RackMount (AP5201) (DHAP5201) 8-port...
Codes for chorus mmds (EUROVOX)
These are only for boxes that work with Chorus digita MMDS not cable
hit menu
go to system information
hit ok
type 1969
go to navigation
bring up provider
if you are with chorus then
the codes are: PROVIDER ID 5E 01
key data: CE 19 23 87 80 61 74 90
key data: 62 FA 09 F3 CE 05 F4 79
make sure your provider name at the top is reading CHORUS if not go to the provider id and right arrow until 5E 01 appears and when you have changed the codes store and exit you should be laughing!!!
best of luck HAPPY CHRISTMAS!
00:CE 19 2E 87 80 61 74 90
01:62 FA D9 F3 CE 05 FA 79
Dec 20, 2008 | StarView SV211K 2-port KVM...
1. Start pressing F8 right after you reboot...
2. Then select Safe Mode from the list of choices..
3. Use System Restore to go back to a date previous to the one you did you upgrade..
Start > All Programs > Accessories > System Tools > System Restore
Best of luck!
Dec 25, 2007 | KVM Switches
ConnectGear 4 Port Video Splitter 250mhz, 1920 X 1440, Metal (CG25VS4) KVM Switch Logo
Top ConnectGear KVM Switches Experts
Peter Parker
Peter Parker
Are you a ConnectGear KVM Switch Expert? Answer questions, earn points and help others
