Question about Foxconn NF4K8AC-RS-1.0 Motherboard
No display on monitor
Sir, i have:
foxconn nf4k8ac rs mobo
amd athlon 3000+
ati x1600 sapphire graphics card(discrete, thers no onboard g card ).
512 hynix pci 3200 ddr ram.
it was working fine earlier(for 3 years) but now it doesnot give me display(my lcd & crt monitor goes to power saving mode).
have chkd monitor,graphics card, harddisk, ram on other system and they are absolutely fine.
all the fans are working.led working fine.harddisk whirring.
there was no beep frm motherboard wen i tried to boot widout any ram sticks.
have not chkd the processor wid oder system, although the fans are proper..
i had left my system on for 10- 15 hrs, wen i came back i saw no display on monitor even after reboots.
next day there was display, but only at 2 hours interval between reboots
i.e. if i had shut down n rebooted immediately there was no display, but if i tried rebooting at interval of 2 hr it was showing up.
next day on there was no display at all.
still dunno wats the problem (processor , mobo, bios?)
Please help me out ....
    President:
  • 627 Answers
This lead to cpu overheating problem
clean your cpu fan and put some thermal grease between the fan and cpu
Posted on Jul 17, 2009
2 Suggested Answers
Damilare
  • 358 Answers
SOURCE: no display
After all your troubleshooting, I think this is likely to be as a result of your processor over-heating, maybe because of your environment, or because the fan is not cooling the processor properly again. Therefore my suggestion would be for you to unscrew your system (If you can do it by yourself), and try to clean, or better still replace your processor fan.
If you cant do it by yourself, you can easily get a technician to do it for you. This solution is actually if your processor is not yet burnt.
But if your processor is burnt, then you might have to change it to a new compatible one. but before changing it, try to test the motherboard with another working, compatible processor first, just to be more sure.
Then always make sure that your PC is in a well ventilated, cool environment and that the environment is free from dusts.
Hope this helps you out.
Posted on Jul 15, 2009
Sir! i have winfast NF4K8AC motherboard with Vga display card 128 MB DDR (ROHS Compliant Lead - Free). It was working 6 month smoothly but now I am having problem with display .I have checked the same Vga...
the drivers might not be installed correctly you might have to uninstall the graphics card restart your computer then reinstall the graphics card and its drivers
If your computer came with a motherboard disc the drivers could be on it
Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers
hope this helps
Aug 16, 2011 | Foxconn NF4K8AC-RS-1.0 Motherboard
Sapphire 100293-2GL RADEON HD 5570 2GB DDR3 PCI Express 2 0 x16 HDCP Ready CrossFireX Support Video Video Card Logo Problem with the Sapphire 100293-2GL RADEON HD 5570 2GB DDR3 PCI Express 2 0 x16 HDCP...
I'm not sure I follow all of waht you are doing and /or did however, this card requires a minimum 400w power supply so, make sure you have the power. It may or may not be a factor. These cards can be tricky sometimes and I will start by saying, the install should have gone in this order: Install the card, boot your system and insert your CD. Start by downloading all drivers and "utilities" from CD. You will not get all the bells and whistles taht come with the card unless you get them from the CD or, possibly from Sapphire, and reboot. Check in "programs and features" and device manager to make sure you see your device. Once you have done this, you can then upgarde your drivers from respective sites, AMD, Sapphire, etc. You definately have to unisatall all prior software that has anything to do with ATI/AMD prior to installing new software.You can do a custom uninstall and install here. At his point, I would go into "programs and features" and unistall all ATI/AMD software and start over. Any software from existing cards as well. You also need to reboot after each unistall or install. Where are you getting this 1250 from? Is it from the CD? This is alot to swallow and if I am missing something let me know. I can help you with the upgrade of the VGA driver nut, lets see if this works and, taht I am on the right track. Contact me at "add a comment".
Dave
May 30, 2011 | Computers & Internet
Trying to install ATI FireMV 2400 256mb pci-e card. I have a new pc with asus m4a78lt-m motherboard, athlon x4 645 3.1ghz processor, 3gb ram, windows 7 32 bit os, 500w psu Card installed in pcie x1...
First off all reset the bios to default setting and restart the system. After restarting the system please go to your bios in the graphics segment and select auto option for card selection.
once done save all setting connect your monitor cable to your monitor and restart the system.
hope this will solve your problem.
Apr 14, 2011 | ATI FireMV 2400 PCI Video Card
My monitor screen turned green..
Please check the VGA cable properly its working fine if any brokage then replace with goods one,if still same situation then your display setting has been changed from operating system .go to desktop /right click/properties/setting/advanced/select graphics card/graphics properties/color correction/and select all adnd apply it.
Nov 20, 2009 | ATI RADEON X1650 Graphic Card
No display
Jul 15, 2009 | Foxconn NF4K8AC-RS-1.0 Motherboard
I have no idea in overclocking my PC
Download AMD Overdrive here
It is a powerful all-in-one overclocking, monitoring, and testing utility designed for users of motherboards with AMD 700-series chipsets.
Mar 11, 2009 | MSI 6600GT 128M VIVO/TV/DVI OVERCLOCKING...
Duel Monitor Problem
first thing first ensure that you have the latest ATI radeon X1600 pro driver and software installed else you won't be able to get the desired options for dual display under settings coz it will be working with generic drivers.
To download the latest driver and software click here
Then please click the following link :
ATI Radeon X1600 PRO How to
On this link click on the option
  • "Guides, Walkthroughs and "How to's"
Then opt for
  • "How do I use dual displays or TV/HDTV out? "
Just follow the instructions.
Feb 19, 2009 | ATI RADEON X1650 Pro, (512 MB) PCI...
Lost driver
ATI display driver
Here is ATI multi driver: Click to Download
From AMD: "This is he ATI Radeon Catalyst Display Driver version 7.10 For WindowsXP/MCE, released by Advanced Micro Devices(AMD). This release updatesthe AMD Display Driver to version 8.401, supports all Radeon Desktopproducts(ATI Radeon9550/9600/9700/9800/X300/X550/X600/X700/X800/X850/X1300/X1600/X1650/X1800/X1900/X1950/HD2400/HD 2600/HD 2900 XT). This unified driver has been further enhancedto provide the highest level of power, and reliability."
Jul 29, 2008 | ATI RADEON HD 2400 PRO Graphic Card
Compatible Processors
Can only support Processor: Socket 939 for AMD Athlon™ 64 and 64 FX processors
Please don't rate me Inappropriate if you don't like my solution or rate me SOLVED if you accept the reality. Thanks
Nov 22, 2007 | Foxconn NF4K8AC-RS-1.0 Motherboard
Video card troubles
Hi, with my own Foxconn mobo [661FX7MI] I had to run the installation disk that came with the motherboard and reinstall the AGP driver. Then run the AGP card driver [ATI]  disk.
Regards mistyman
Oct 20, 2007 | Foxconn 760GXK8MC-RS Motherboard
Foxconn NF4K8AC-RS-1.0 Motherboard Logo
302 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
