Question about Motorola Mobility ROKR E6 Smartphone
Sim card or sim card slot problem
I AM USING motorola E6. My mobile fall down and asking for no simcard. mobile working properly except sim card. i think sim card software problem or simcard slot problem. it is asking for all simcards as mentioned above. so give me the correct suggestion to do.
  • 246 Answers
Up the all legs of Sim tray with screw driver
Posted on Jul 17, 2009
Why gt s5570 doesnt showing simcard and always ask to insert simcard
Check whether the SIM CARD slot is working properly by insearting a different sim card if doesn't work then your sim card slot is corrupted...
May 26, 2014 | Samsung Galaxy GT-S5570
Insert sim
What is your mobile model?To insert simcard,the following conditions should be satisfied....
1)The mobile should be unlocked to accept the sim card
2)The mobile should have the sim slot (most CDMA phones do not have that provision)
3)The simcard size should be supported by mobile phone.
Now,if your mobile is locked with a particular network then you need to unlock it.For that you can either approach the respective network provider or third party unlocking services like Simpleunlocking.com or unBBlock.com (This is specifically for Blackberry phones) and unlock your mobile.Once your mobile is unlocked the sim slot will either be in the side or above or below the battery depending on your mobile model.If you search in Google you probably will get a more clear idea about where your sim slot is located.Once you find the sim slot remove the sim card and note down the position; replace it with the old sim card(it should support the phone sim size specification).
Jul 12, 2013 | Cell Phones
How to insert sim card to motorola A955
sorry to interrupt... Any one can upload the simcard hole?
Mar 20, 2012 | Cell Phones
How to install sim card
For most of the phone,sim card will be install at the back of your mobile phone. These are the steps on how to: 1. Turn off your mobile phone. 2. Remove the back case gently. 3. Remove the battery as well. 4. Theres instruction at the back of your phone on where to place the simcard and on how to insert it. 5. Make sure you properly inserted the sim card so you wont recieve offline mode error. 6. Plug back the battery. 7. Return the back cover. 8. Turn on your phone,then your good to go. remember that there are some phones wherein the simcard slot is on the side part of the phone. for this kind of phones,all you have to do is just lift the cover of the simcard slot then slowly insert the sim properly then turn on the phone and your good to go.
Dec 05, 2011 | Samsung Cell Phones
I have a boostmobile simcard and i want to put the tmobile simcard inside the sidekick slide.but when i do it ask me for a special code is there a special code for me to start using it?
you actually need to unlock your phone to use the simcard not just a code. boost mobile and tmobile run and different networks to its not as simple as putting in a different sim card.
Mar 25, 2011 | Cell Phones
My motorola L7 is not reading the sim card. I have had this for a long time with not problems. Can anyone help solve
should be dirt deposited over the sim card or the simcard slot. try cleaning with white petrol or unleaded petrol.
also try with other simcards.
if you have white petrol, use a ink puller and just apply 3 to 4 drops of it over the sim slot and dry it for 15 to 20 minutes. do this twice or thrice, this might work if dirt is sedimented over the slot
Jan 11, 2011 | Motorola Mobility L6 Cellular Phone
SIM CARD NOT DETECTED
Please wipe the SIM slot clean... As well as the SIM.. This might sound odd, you may also try charging the phone for a while.. It works on me anyway
May 16, 2009 | Motorola Mobility MOTOROKR E6
No simcard eventhough simcard inserted in MOTOROLA ROCKER E6
first remove the sim card and then switch on the phone... then choose antenna on... after a few seconds you will see emergancy only on your screen ... turn off your mobile and insert the sim and switch it on again ... this solved my problem ... but this is not working on my cell now.. does anybody have a solution?
Sep 26, 2008 | Motorola Mobility ROKR E6 Smartphone
Switching sim cards
one simcard can only be used in one phone at a time. the phone needs to be turned off to remove the sim card so nope...
Sep 04, 2008 | Motorola Mobility ROKR E6 Smartphone
Motorola Mobility ROKR E6 Smartphone Logo
180 people viewed this question
Top Motorola Mobility Computers & Internet Experts
David Payne
David Payne
 Paul Flint
Paul Flint
Level 1 Expert
Unlockingcom
Are you a Motorola Mobility Computer and Internet Expert? Answer questions, earn points and help others
