When you open it from the outside? If this is the case, try putting your key in the drivers door and turning it, whether it is locked or not. I have seen many people who keep their key fob in their pocket have all kinds of issues. So, don't keep your key fob in your pocket. If it is doing it from the inside after driving, that's a different story. It all depends on the specific conditions, if you would like to elaborate.
I’m happy to assist further over the phone at https://www.6ya.com/expert/kim_3202917d7c587455
SOURCE: how do you disable the alarm on a mercedes benz 300E 1987
Use your door key and unlock your drivers door ... that is what disables the alarm system. Make sure that the battery is rehooked... because i'm sure you took the battery loose when you couldn't get the alarm to turn off.
SOURCE: How to remove outside door handle and door lock of
take the door panel off and look for nuts to remove door handle.as for the lock it may be a u.clip.pull it down
SOURCE: how do i disable alarm system????
under the rf floor board in the front you will see a false panel after removing carpet. remove false panel by loosening 10 mm plastic nuts your alarm module is 1 of the 2 modules on that false floor-it should have a 820 number in the part number-if it is not obvious call parts dept. and cross reference numbers-unplug module and you won't have worry about that annoying alarm anymore-hopefully i have been helpful
SOURCE: security system on 87' mercedes benz. just bought
under the passenger side false floor in front footwell is the alarm module. Pull the carpet up and remove the 2 10mm bolts from the false floor. There are 2 control units on the backside of the floor. One of them is the alarm module. unplug it and you won,t have an alarm any more. good luck
SOURCE: How do I remove the door panel on a 1995 Mercedes
pull off rear mirror panel, pull off electric seat adjuster knobs, pull off plastic around door handles. Unbolt top of handle. Pull out light at bottom of door. Unscrew plastic stiker plate and remove. Unscrew lock knob to remove. Then your ready to wiggle and pull the panel up and off, be careful of the area around the door handle, you may even want to pry that area out before you begin.
