Question about Moen 87530 Touch Control Single Handle Kitchen Faucet with Protoge Side Spr...
2 handled shower faucet in new manufactured home leaks bad when turned on. Water sprays from behind each handle and water was coming out underneath the shower all over the floor, seems to be getting behind the wall somehow?? Any help out there, please...
Hired a plumber
Posted on Jul 19, 2009
How to stop water getting inside a single leaver shower faucet?
quite possibly there is a broken O ring inside the faucet .
Jul 17, 2015 | Home
When water is turned on, water leaks from faucet and hot/cold water handles but when diverter is engaged the shower works fine with no leaking from the handles or faucet. I have a three handle system. Any...
Write down the type and model of faucet you have. Most hardware stores have rebuild kits for faucets.( washers, rubber o-rings and or gaskets) You will have to turn your water off and do some minor repairs.
The kits come with step by step directions.
Dec 13, 2012 | Home
Getting hot water when shower valve is first opened.
If I understand correctly, you have single handled shower faucet.
Normally there is a wait for hot water to arrive at faucet.
But now hot water is already at shower faucet.
Single handled faucets have a mixing area inside valve where hot and cold come together before going into sink.
This mixing valve can have crossover where the hot and cold can pass through to each other even when faucet handle is off. When single handle faucets get old, this can happen.
How it happens:
For example another faucet is turned on inside house, and pressure differential between hot and cold causes hot water at shower handle to pass through mixing area and into cold water line.
So if another faucet has been run, then that lets hot flow to faulty single handled shower faucet.
To confirm this is the problem: turn on other faucet and put ear against shower faucet to listen for moving water.
This condition may also signal there is a water leak.
The problem is not harmful, but will draw cold water into water heater each time, and is energy wasteful.
Replace faucet or have plumber repair problem.
Feb 19, 2011 | Price Pfister Single Lever Handle Faucet...
Only warm water from the tub/shower
You can cap the lines at the tub faucet to rule out tub faucet. It maybe mixing there.
Faucet may be bad also the safety stop will alow you to change water temp it can be tricky to adjust water temp.
May 02, 2010 | Moen 1 Handle Lever Shower Faucet With...
Water is not very hot.
First try adjusting the pressure balancing gear located right behind the handle. If you still do not have hot water I suggest to replace the cartridge.
Jan 13, 2010 | Delta & Single Handle Shower Faucet
Installed a new 88976 handle but still have a leak
replacing just the handle cannot fix the leak and common sense should tell you that.... try turning off the water to the diverter (thru access panel on opposit wall or main water valve for the home) and then replacing the stem or cartridge inside the diverter -- this is what controls water temp, pressure, and is responsible for any leaks you may have...
Aug 31, 2009 | Delta & Single Handle Shower Faucet
Shower leaks very bad when turned on. Water sprays out from behind each knob and from behind the valve plate. Then after about a minute water starts to come out from underneath the one peice shower stall....
there is a problem with the rubber washer or bushing. it may be brittle since it has not been used for a long time. remove the handle then assymbly to locate the rubber washers, the washer seals the flow of water.
Jul 17, 2009 | Washing Machines
Water comes out the shower head without the faucet lever being engaged
the whole faucet is bad it has an internal leak replace the whole thing
Jul 03, 2009 | Home
Water sprays out the diverter
Remove hot/cold button in handle, remove screw/pull off handle. Remove the two screws in the wall plate/remove plate. Use a wrench to remove the diverter assembly. Get new diverter assy and reinstall eveything. You don't need to turn off the water.
Jun 09, 2009 | Delta Faucet #RP320 Divert Assembly
Moen 87530 Touch Control Single Handle Kitchen Faucet with Protoge Side Spr... Logo
158 people viewed this question
Top Moen Plumbing Experts
john h
Donni Steen
Don Numinen
Don Numinen
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
