No other noticeable conditions...except for the fact that i do not have the remote.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Testimonial: "Ok...I did what you said, and the indicator light in its off, or "at rest" position is solid red....as soon as I push the power button, I get 4 blue flashes, then a short pause, then 2 more blue flashes, then it goes back to solid red. So if I am understanding you correctly, I am looking for a trouble code 42, correct? I will try and google the code 42, for my model and brand tv...if this works, I cant thank you enough. Incidentally, I am an electrician, but an industrial wireman. High voltage end of the spectrum...lots of powerhouses etc...I am totally ignorant at the low voltage level. I do own many Fluke multimeters and was gonna try and find the specs on the tv and try testing output voltages and what not. I am sure glad you were here today! I had no idea that you television would tell you whats wrong, like a vehicle will. Thank you so very much for educating me on this. I owe you one, brother!"
Start with the headset powered on. Press and hold down
the call control button while also rotating the multi function dial
upward (away from the light) until the indicator light on the headset
starts flashing red then green. When prompted for passkey, enter
0000.
For the Plantronics M1000 (discontinued):
Hit and hold the volume/mute switch in until the indication light starts blinking.
For the Plantronics M1500 & A500 adapter
(discontinued): Turn the headset on and the adapter off. On the headset
push in and hold the mute/volume dial until the indicator light begins
to flash. On the adapter press and hold the blue power button for 10
seconds. The light on the adapter will flash once after 3 seconds-
continue to hold the power button for another-7 seconds until the
light flashes red. If the pairing is successful, the headset will
sound a tone and both the headset and adapter lights will turn off.
For both the Plantronics M1000/M1500 (discontinued):
If you remove the battery cover from the headset and then remove the
battery itself. On the Green PC board itself there will be a letter
followed by 4 numbers. These 4 numbers are your personal PIN code.
You can also use the Plantronics Bluetooth Pairing Guide
