Question about HTC Touch Diamond Smartphone
My HTC Diamond keeps on giving warning, "Device will turn off", checked the power setting, the option for turn off device is not selected. Not sure why this warning keeps on coming every after 5 min
  • HTC Expert
  • 246 Answers
Reset your phone once and try it
Posted on Jul 17, 2009
I went cleaning my htc p5500 screen with a dap clothes and rub it up and down now the touchscreen isnt working,jus would like to know if i reboot it will the touchscreen work?
FOLLOW this steps and fix it. God bless you
  1. Hard Reset
    • 1
      Pull out the stylus from the back of the HTC Touch Diamond or the side of the HTC Touch Pro.
    • 2
      Using one hand, press and hold the volume down button on the left side of the device, the power button on the top of the device and the circular button on the face of the device. It is generally easiest to hold the volume down button with your thumb, have your palm over the LCD, press the power button with your index finger and the circular button with your pinky.
    • Sponsored Links
    • 3
      Continue to hold the buttons down while you turn the device over to access the back side. Use the stylus to press the "Reset" button, located near the end of the stylus cavity on the Diamond, and by the port on the bottom of the device on the Touch Pro. Release the "Reset" button, but do not stop holding the volume down, power and circular buttons.
    • 4
      Turn the HTC Diamond over and watch the LCD. When a message appears saying that this operation will delete your data, release the three buttons. Press the volume up button to complete the hard reset.
    Clear Storage
    • 5
      Slide your finger to the right along the bottom of the LCD until the "Settings" option appears. Tap "All Settings" on the device.
    • 6
      Tap the "System" tab on the screen and then tap "Clear Storage"
    • 7
      Select the drop-down box and choose "Clear Storage Only." Type "1234" into the text box confirming that you do want to delete your information and then press "Yes."
Jul 25, 2013 | HTC Touch Dual P5500 Smartphone
I have got an htc touch diamond phone and i want to use internet on it and also want to connect to my pc but i dont have a software/hardware or cd. i have installed active sync. on my pc but the device...
if you have installed active sysnc then the device should connect. If it doesnt i would check in my computer to see if it is showing as connecte. Also when you connect the usb lead to the phone it should pop up a selection on the phone to how you want to connect make sure you choose active sync. the screen only appears for a few seconds then it will connect with the last selected option
Mar 13, 2011 | HTC Touch Diamond Smartphone
How to snchronize htc diamond touch with windows 7?
First, download Windows Mobile Device Center from Microsoft ( Google it) and install it in Windows 7
Secondly, plug the HTC diamond touch with USB connection and wait for the windows update search the driver of HTC Diamond Touch.(This will take a while)
Then It will ready to go.
Hope this help you.
Feb 06, 2011 | HTC Touch Diamond Smartphone
Hi my htc touch diamond restarts randomly few times a day. can anyone help
try updating your software to 1.93 rom, i was having the same issues when i was on 1.37 and my partner was on 1.35 updated and not had the issue since!
update site - http://www.htc.com/www/supportdownload.aspx?p_id=133&cat=2&dl_id=2
also if that doesnt work try doing a soft and/or hard reset -
Performing a soft reset
Perform a soft (normal) reset to clear all active program memory and shut down all active programs. This is useful when your device is running slower than normal, or a program is not performing properly. If a soft reset is performed when programs are running, unsaved work is lost.
To perform a soft reset
1. Pull out the stylus, then remove the back cover.
2. Use the stylus tip to press the RESET button (red) located at the opening of the stylus bay. Your device restarts and displays the Home screen.
HTC Touch Diamond 2 hard reset
Performing a hard reset
If a normal reset does not solve a system problem, you can perform a hard (full) reset. After a hard reset, the device is restored to its default settings-the way it was when you first purchased it and turned it on. You will lose any programs you installed, data you entered, and settings you customized on your device, and only Windows Mobile® software and other pre-installed programs will remain.
Warning! Your device will be set back to factory default settings. Make sure that any additional installed programs and/or user data have been backed up before you perform a hard reset.
Important If Encrypt files when placed on a storage card is enabled, backup all files from the storage card before using Clear Storage, hard reset, or updating the operating system. Otherwise you will no longer be able to access the encrypted files on the storage card. Use ActiveSync or Windows Mobile Device Center to transfer files between your storage card and computer. After the procedure, copy your files back to the storage card.
To perform a Diamond 2 hard reset
1. With the device turned off, press and hold the VOLUME UP and VOLUME DOWN buttons, then briefly press the POWER button.
2. Continue pressing the VOLUME UP and VOLUME DOWN buttons until you see this message on the screen:
3. Release the VOLUME UP and VOLUME DOWN buttons.
4. Press the VOLUME UP button to perform the hard reset, or press any other button to cancel the reset.
Dec 29, 2010 | HTC Touch Diamond Smartphone
I have the Original Jabra Stone Bluetooth Headset and I need to know to connect it with my phone with is an HTC Desire.
I'm not familiar with the HTC desire, but most cell phones are much the same when it comes to connecting a bluetooth device, you would go into your settings looking for bluetooth device, some phones it's under options, you want to make sure bluetooth is turned on, discover, or discoverable is turned on, then select search for new devices. Make sure the Jabra is on before performing the last step. It should discover the device then it will ask you for an access code, which is usually 0000 (four zeros). Keep smiling. :)
Oct 14, 2010 | Cell Phones
I forgot my password and i want a new number please delete my password it should bea1b2c3 but it said its incorrect what should i do write back
The only way I know to bypass the password request riytube is hard resetting your device. You, most probably, know that a hard reset sets your phone to its factory defaults, thus deleting all your personal data, as well as the applications you have installed. To hard reset your device, firstly, turn it off. Then, press and hold the ENTER key. Whilst keeping this key pressed, briefly press the POWER button. Release the ENTER key when a warning screen comes up. Then, press the VOLUME UP button to hard reset your device, or any other key to cancel the hard reset procedure.
Hope you are able to have your device fully functional again.
Cheers!
Carlos
Apr 24, 2010 | HTC Touch Diamond Smartphone
HTC Touch Diamond - Powers up and down while plugged in
from a power off device.
press and hold the center joystick button, and the volume down buttons.
dont leave those two!
and now power on the device. wait for a gray screen asking you to make a clean boot. press the volUP or volDOWN button and after about 5 minutes your device will make an hard reset (clean boot) and will restore it to factory settings.
good luck!
Aug 29, 2009 | HTC Touch Diamond Smartphone
Change language ,send pictures via bluetooth on touch diamond 2
In order to send pictures from your phone to other devices via Bluetooth, the following steps should be taken:
• Access your phones picture library
• View the picture you want to send
• Hit the menu button
• Select “Copy” from the menu list
• Chose “Bluetooth”
• Hit “Yes” when it asks you if you want to temporarily turn on Bluetooth
• Select “Look For Devices”
• Once your phone finds the device and lists its name, you select that device name
• The receiving device is then prompted to accept/reject my file
• Once accepted, the picture is sent (takes about two seconds)
Jun 21, 2009 | HTC Touch Diamond Smartphone
System not working
just hard reset ur device
press both call and end key at once and then press power button at the upside of PDA for like 5 sec u will b egiven a menu to reset remove the card and reset the device then see if it helps
Feb 03, 2009 | HTC Touch Diamond Smartphone
Can't sync contact and calender items to outlook 2007
First off, please don't give me a bad rating, as I don't have Vista, and this is simply a guess..
Secondly, Look around in the settings in WDMC, maybe there is a setting to copy contacts on device onto outlook on the PC. Don't bother looking in outlook since the device usually sync with Activesync/WDMC, which does the rest it self.
Jan 07, 2009 | HTC Touch Diamond Smartphone
HTC Touch Diamond Smartphone Logo
147 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
