Chasis intruder is a warning that your CPU has been opened by someone it is normally used to warn you against unautorized BIOS or SYSTEM PASSWORD removal There is a switch in your casing that detects this.
Leave this setting to enabled (recomemded)
Thanx and i hope this info is helpfull Please dont forget to rate this solution
Chassis intruder is a sercurity measure to alert in case if some one is openning the Desktop PC cabinet / case. a switch will be attached to cabinet / case in such a way, if you open this switch will be triggered and will raise an allert or record this allert in the BIOS setting long. This switch will be connected to the intruder allert connector in the motherboard
Switch is connected to motherboard
switch is placed strategically in the chassis so it will release if you remove shields offf your cabinet.
I have two laptops on one laptop when i plug my pinnacle movie maker into the usb the green light on...
(More)
I have two laptops on one laptop when i plug my pinnacle movie maker into the usb the green light on the pinnacle turns on but when i plug it into my newer laptop it doesnt turn on ??
Cuando enciendo la computadora , me sale una pantalla az?l con el c?digo p4p8oos-x . No entiendo...
(More)
Cuando enciendo la computadora , me sale una pantalla az?l con el c?digo p4p8oos-x . No entiendo mucho de computadora y no s? qu? significa, solo s? que es algo referente a la tarjeta madre. Pueden decirme de qu? se trata? Gracias
