Question about Acer Aspire One Netbook 8.9" Notebook
Dear sirs:I am looking for this spare
I am looking for this spare part:
Flat Flex Ribbon Cable- 0,5mm Pitch, 40 - Conductor
Logo: GREATLAND E304015 RU AWM 20624 80C 60V vW-1
This part belongs to the Acer Aspire One ZG5 (AOA 110) notebook
Can you please help me?
Thanks in advance
Manuel Pastor
Right half part of screen is darker than left part
Look at the screen controller board in the TV. It's the one that has two flat multi conductor flat ribbon cables leading to the screen.
Jan 08, 2014 | TCL L32HDM11 32 Class Widescreen LCD HDTV...
Want to connect 40 pin LCD ribbon cable to the 15 pin D type VGA
VGA pinout?
Not a prob,
http://pinouts.ru/Video/VGA15_pinout.shtml
Pinout of that 40 wire LCD ribbon cable in your hand?
Dunno
Each manufacturer is different.
IF, you find the pinout of JUST THAT LCD cable you have, LET ME KNOW.
Post back in a Comment, or click on Reply at the end of this solution.
Regards,
joecoolvette
May 12, 2013 | Computers & Internet
Vertical lines left half of screen
You might be advised to look on EBAY for someone junking one for the parts----I do MFR. warranty work and from most makers it is nearly impossible to get replacement ribbon cables for sets....you sound smart so are aware issue could be inside the display panel as well....
Jun 09, 2012 | Samsung LN46A550 LCD TV
I replaced the top screen of my DS Lite. I had trouble getting the ribbon through the hole Nr the hinge, I had to role it up and pass it through. Eventually I got it to pass through but then couldn't...
*sigh* -facepalm- Clare, consider this a lesson in electronics component replacement. If you're talking about one of those goldish-orange ribbon cables, then you need a new replacement screen. There actually is a small chance you may need a new DS as well. NEVER, EVER, EVER, EVER force one of those cables. For that matter, never force ANYTHING while repairing small electronics. My friend learned this the hard way. If you look closely at those cables (actually called flex cables), you'll notice that its slightly textured. That's because these flex cables contain multiple conductors. Once your flex cable is "crumpled" that means that some of the conductors inside the cable have either snapped on the microscopic level or malfunctioned in some other way. (I don't think i have to explain what a HOLE through the cable would mean.) Those things are designed to be flat, and REMAIN flat; they are even installed flat, so if you had to "roll it up," as you say, then that means one of two things: You don't have the hand-eye coordination/dexterity necessary to repair things of that size (which i'm going to assume that you DO have), or that you were installing it incorrectly. I'm assuming the latter. I have replaced multiple DS screens, and not once have i ever had to pass it through a hole of any sort. Now, if you are talking about those recievers on the mainboard where you have to flip a small hinge up to remove/ install the cable, thats totally different. The end of the cable goes into the reciever, and stops there. It does NOT go all the way through. Once the cable goes in as far as possible, flip the hinge back down so that the mechanism can "lock" the cable in place.Give it a light tug to make sure its locked in. Don't pull too hard. It should be good to go afterwards. Remember to buy a replacement screen. The one you just bought is totaled. If you have any questions, feel free to shoot me an email at edchen111@gmail.com. Just make sure to include pictures if you do send me an email. I can provide better assistance if you do. Good luck.
Mar 17, 2011 | Video Game Consoles & Games
What is conductor cable?
Thank you for your question.
The conductor cable is the "flat ribbon cable" that connects the Hard Drive to the Motherboard on IDE devices.
Kind regards
May 31, 2010 | Seagate U6 (ST340810A) 40 GB Hard Drive
I have a cut ribbon cable that goes from the chassis mounted LCD driver board to the LCD interface board. I think that I can handle the fine pitch soldering (or have it done for me) but I cannot find the...
Hmmm. You have picked a hard one. If you mean the flex cable that is ultrasonically welded to the glass LCD screen, you will be out of luck.
Best to call Samsung service centers to see if you can round up a broken screen.
Mar 29, 2010 | Samsung LN-S4051D 40 in. LCD Television
How do i install a used hard drive into an eMachines T2341? The hard drive still has information on it. do i set it as master, slave, or cable select? hard drive is an IBM 10.1 gb
There are two possible solutions depending on how your desktop is setup.
#1 install the 2nd hard drive and put jumper to CABLE SELECT. When you start the computer it should now appear in the bios as a SLAVE or 2nd hard drive. If not go to #2 below
#2 Turn system off again and change jumper on 2nd hard drive to SLAVE.
Now when your computer restarts it will appear in your bios correctly as the 2nd drive/SLAVE.
Do not make it "MASTER" or you will be trying to boot up to this drive and it may not work as you planned.
FYI: "Cable Select" means the hard drive determines which one is Master and which one is Slave by where it is on the data cable.
Good Luck
Dec 30, 2009 | Computers & Internet
Flat cable
http://www.specialty-cables.com/flat-flexible-cables.html
E-mail them. They have Flat Flex Ribbon Cables, from 0,5mm to 2,5mm pitch, and 3 to 40 conductors - so they have the cable you are looking for. Please rate me :)
Jul 21, 2009 | Acer Computers & Internet
Installed a new Optical Drive and require assistance in the wiring
What kind of optical drive? Is this a CD, DVD?, Blue ray,
or an opto-ferro-magnetic floppy?
Generally:
1) External drive:
a) just power it up and connect it to the PC using an USB
or firewire (1394) cable. If it is USB, make sure your PC
is set up for USB-2 which is astronomically faster.
b) The windows operating system should automatically
detect it and install the low level device drivers.
Then you can run the installation driver CD that came
with the drive.
2) Internal drive:
a) Shut down Windows from the START menu,
chose shut down the system, NOT restart.
b) When it finishes shutting down, turn of the
power at the back (!) of the PC and unplug
the power cord.
Now turn the power switch back on for a few
with the cord unplugged, then shut it off again.
This will drain any internal capacitors inside the
power supply to make sure you don't fry anything
while you poke around.
c) Open up the computer case and look to see where
the other hard drives are installed and physically
mount the new optical drive inside the case.
d) Locate a spare power cable coming from the power
supply (Black, Red and Yellow wires) and hook it
into the back of the drive.
It should only fit one way, but there are several
different kinds of connectors, depending on the
drive type, so you may need an adapter cable.
i) Large 4 pin connector = Red, Yellow, Black, Black
ii) Miniature -//- = -//-
iii) SATA power cable = Small black hooked beastie.
Also make sure the power supply can handle
the extra current, this depends on the other stuff
such as drives and video card you already have in
the machine.
If your power supply is less than 600W on a modern
machine, now may be the time to upgrade it.
I have two video cards, 8 hard drives and a DVD,
so I had to upgrade to a 1000W to prevent my
system from randomly crashing during boot up,
when everything spins up for a self-test.
e) Once the power is connected, you need to connect
the data cable, which comes in a least 3 different
types:
IDE or PATA = Parallel ATA ribbon cable
SATA = Serial ATA cable, small flat cable with a red,
blue or orange jacket, and small black
hooked connectors at each end.
Note that these are a different size and
shape from the SATA power cables.
SCSI = pronounce scuzzi, no longer common.
One end of this data cable connects to the back of the
optical drive, the other to the motherboard, but this is
where it gets more complicated, because the mother
boards are fussy about which slot you plug them into.
You need to follow your motherboard manual here (HP) !
For SATA cables, you have to make sure that the motherboard
can handle them, older motherboards cannot, requiring an
adapter card. Also many of the new motherboards offer
multiple drive configurations such as RAID.
RAID = Redundant Array of Independent Drives:
RAID 0 = STRIPE for high speed at the cost of security
RAID 1 = MIRROR for data redundancy at the cost of $ cost
RAID 01 = Stripe of mirrors
RAID 10 = Mirror of stripes
RAID 5 = Stripe with parity compromise
etc...
Anyway, the problem is that on these mother boards some
of the SATA connectors are general purpose (which is what
you need), while others are not (i.e dedicated RAID),
and you may have to change jumpers on the board
or BIOS settings to get it to work right.
Also if the optical drive is to be bootable, then it sould
be connected to SATA1 or SATA2, but that again depends
on the motherboard and the BIOS boot sequence settings.
With the older style IDE or PATA drives, which includes most
optical drives (since SATA is fairly recent), most motherboards
provide two separate IDE ports, each of which can handle a
pair of drives for a total of four.
IDE1, Master = Drive 0
IDE1, Slave = Drive 1
IDE2, Master = Drive 2
IDE2, Master = Drive 3
Each pair of drives shares a single ribbon cable.
Older cables have 40 conductors,
Newer cables have 80 conductors for UDMA.
While the end connectors are the same, only 40 conductors,
the 80 conductor cables have interlaced grounding, which
allows them to transfer data at a higher speed.
Older optical drives used the 40 conductor, newer ones
use the 80 conductor, but there is no harm done using
the 80. If the ribbon cable came with the optical dive,
you can use it if you are plugging it into a separate IDE
port, BUT
Never use a 40 conductor ribbon cable if it is shared between
the optical and the hard drive, because this will slow down
the hard drive to the lower UDMA speed.
Now about the Master Slave thing:
1) Each PATA=IDE port can only handle one master/ slave pair.
2) You must never connect two MASTERS or two SLAVES
to the same cable.
3) The boot hard drive must be a MASTER on IDE1
for most systems, unless the BIOS has a way
remapping them.
4) When a hard drive and an optical drive share the same
IDE port and cable, the hard drive should be the MASTER,
for maximum speed, optical drives are often slower.
5) IDE hard drives and optical drives use a set of
jumpers near the IDE connector to determine if they
act as a MASTER or a SLAVE. This should be set before
you install them, because it is very hard to get at the
jumpers afterwards:
MASTER this forces the drive to act as a MASTER
SLAVE this forces the drive to act as a SLAVE
CABLE SELECT special color coded ribbon cables
(80 conductor) must be used to make this work.
These now come with most new motherboards.
The blue connector at the far end of the cable, away from
the other two goes into the motherboard.
The black connector at the opposite end (near the gray one)
goes into the MASTER drive.
The gray connector in the middle goes to the SLAVE drive.
(both drives should be setup as CABLE SELECT for this to
work)
When connecting the ribbon cable to the IDE drive, make sure
the PIN 1, the marked side of the ribbon goes near the power
connector. On the mother board, the marked of the ribbon
connector goes into PIN 1. The connector should be keyed
to only fit one way, but don't count on it.
Hope this get you started,
Martin
BTW please rate my answers.
Jun 14, 2008 | Computers & Internet
Acer Aspire One Netbook 8.9" Notebook Logo
215 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
