Question about Dell Optiplex GX270
Resolution cannot be changed from 640 x 480 I need a new driver
    President:
  • 1,383 Answers
You can downlaod new driver from here then change screen resolution to 1024*768 then apply and ok.
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=PLX_PNT_CEL_GX270&os=WW1&osl=en&catid=&impid=
Posted on Jul 17, 2009
4 Suggested Answers
  • 4 Answers
SOURCE: Cant change screen resolution
Need More info like model # of machine. Sounds like you have lost the correct video card drivers
Posted on Oct 31, 2007
mansnes
  • 50 Answers
SOURCE: resolutions on monitor dell 17" flat screen
Download the video drivers from Dell.
Posted on Mar 04, 2008
kevin000
  • 1847 Answers
SOURCE: how to install screen resolution drivers?
You can change the screen resolution by going into Display Properties (right click desktop), settings.
If you are not able to drag the slider, you need to reinstall the video driver.
Let me know if you have any difficulty
Thanks
Kevin
Posted on Jul 13, 2009
Change the resolution on my Samsung B2030 LCD Monitor
1600X900 is a higher resolution than that of 1280X1024. Therefore 1600X900 is a better resolution. If you would like to run at the lower resolution simply right click your desktop screen and click properties. Then on the settings tab use the slider bar to adjust the resolution. Lower to the left and higher to the right. If the desired resolution is unavailable then you could try downloading and installing the latest drivers for your graphics card installed in your computer.
Your card will either be AMD/ATI Radeon or Nvidia. You will need the model number of the graphics card, the latest drivers may increase resolution support for your card.
Also look on the bottom right hand side of your screen for an Nvidia Control Panel logo in green. Right click it and select the option to "change screen resolution" This may provide you with additional resolution options.
Take care!
damnor01
Nov 02, 2011 | Samsung B2030 LCD Monitor
Hello, i got my new graphic card (ASUS EAH6850 Direct CU 1GB/D5) and i placed it in my pc and got all cables on the right place. the screen works, does everything but resolution isnt good and i cant...
First if you haven't done so, you need to install all the drivers that came with the new video card. when you first install a video card only some bare bones basic drivers are used to access and make the video card function. Those drivers will make the video seem jumpy and have low resolution.
Once that is completed and your computer is restarted, you might need to change your resolution. to do that, here is the easiest way:
Find a spot of your computer desktop without icons and right click. there should be a menu that pops up. In windows xp you need to select the menu item that says properties and click the tabs of the new window you have up until you see resolution. In windows 7 it says screen resoultion. Change the slider bar until you find it right one for you.
If you set it to high not to worry, don't hit anything for 15 seconds after you change it and will revert automatically.
Apr 21, 2011 | Computers & Internet
I recently installed a series of drivers for my Vaio VGN-TZ17GN running XP and while all others work fine, the video driver has reset the display resolution from the original 1366x768 to 1024x768 and...
If you're using the newest driver, it should support the physical display's maximum resolution. If your old display driver worked fine, roll back to it. If you can't, then you need to contact Sony to find out where to get the proper driver.
Mar 27, 2011 | Computers & Internet
When the monitor is turned on it appears to work - the "acer" name comes up and then the words "no signal". As soon as no signal comes on the sceen it goes to black and the light turns...
You might have one of several problems.
Your monitor might require a driver for your computer/graphics card in order to show up.
Your monitor's input might be slightly damaged.
Or your graphics card might not have the proper drivers in order to display on that kind of monitor.
I would go online and make sure your drivers are up to date for your graphics card first, then inspect your monitor to make sure no pins from the cable have broken into the input, and then make sure that your monitor is compatible with/without drivers to your graphics card.
Mar 16, 2011 | Acer LCD Monitor X223W
Frequency out of range
First of all press F8 key several times before window boots and then select last known good configuration otherwise go in safemode and then set the screen resolution to minimum.
Jul 28, 2010 | Gateway 838GM (RB838GM) PC Desktop
Al1716 monitor plugged unable to change resolution.
You need to set the PC resolution to the native resolution of this ACER monitor, which is 1280x1024 @ 60Hz.
Mar 10, 2010 | Acer AL1716 F Monitor
How to change input timing without a monitor
you will not able to do it without a monitor. you'll need to get another montior in order to change the settings on computer. you need to change the resolution on that computer. sounds like the resolution is either too big or too small that it will not display it.
Oct 17, 2009 | Computers & Internet
Screen resolution will not change since new computer has benn installed
check if your video card driver is installed properly. you need the driver installed before you can change your display resolution.
to check if driver is installed on WinXP (let me know if you are using diff. OS:
right click My Computer - Properties - Hardware - Device Manager
click the + sign on Display adapters. if you don't see your video card brand and model, you need to install your video card driver.
Apr 25, 2009 | Computers & Internet
Text is to large on aol or any site
You need to change display resolution.
Follow instructions here if you have Windows XP: Windows XP: Change your monitor resolution
Here for Vista : Windows Vista – Personalisation of the Display Properties
If changing resolution does not work, that means that you have to reinstall video drivers, in this case submit a new question on fixya giving details on computer make and model.
Oct 23, 2008 | HP Compaq V75A (White) 17" Monitor
Changing Screem Res to 1024x720
Hi LSmitten,
So your brother has laptop, and you can't change the screen resolution, I will take a guess that most likely the screen resolution right now is 800x600 or 640x480 which most games won't work with. The most likely culprit why you are not able to adjust the video resolution is that he hasn't installed the video driver of the laptop yet. You should install the video card driver for your laptop in other for you to change the resolution of your desktop. I suggest that you download the latest video driver from the computer manufacturer's website.
Also if he is using a older laptop, the LCD screen on a laptop has a set maximum resolution that you can use only. Older model laptops can only go as high as 800x600 upto 1024x768. Most of the new laptop nowadays have a minimum LCD panel of 1280x800 widescreen. Check the PC manual to see the max resolution the LCD can handle.
Hope this helps!
Peace! :)
Oct 20, 2008 | Computers & Internet
Dell Optiplex GX270  Logo
125 people viewed this question
Alun Cox
