Question about Garden
I need to find a new fuel filler cap for a sthil HS74 hedge trimmer as mine has split any idea where i could get one from???
  • 154 Answers
Loews home imp, or husky online
Posted on Aug 03, 2009
Replace fuel line on stihl hs74
Here's the parts diagram, hope it is of some use.
May 19, 2014 | Stihl Hs74 Fuel Tank Part 4226-350-0400
Trottle cable on sthil 45z hedge trimmer too loose
The outer cable is probably not fixed in place at the bottom end. If so, instead of the control moving the inner cable and moving the air control butterfly, the outer cable is sliding down the inner cable and so no movement of the inner cable occurs. Look for a missing or loose outer cable clamp.
Jan 26, 2014 | Echo Garden
Sthil hs 81 t blades don't move
I have The same problem,after opening the gearbox cover found that one of the connecting rods bearing cage broken and needle bearings everywhere and both thrust plates damage . In order to get it fix will be as well buy a new trimmer.
Nov 16, 2013 | Stihl Garden
Poulan hedge trimmer GHT 225 it is a dash 2 How to adjust needle valves after replacing fuel lines (they are on the correct sides) the switch wires aren't pinched or broken and fuel seems to flow when...
The small green rubber thing sounds like the duckbill vent for a gas cap. Since the gas cap vent sits right over the open hole of the tank, I would check the underside of the gas cap. See if the little rubber vent is there. Normally, they will use a small clear nylon connector to hold the return line inside the tank. The small green thing sure sounds like a fuel cap vent. Here is a link to the diaphragm carburetors site with a tutorial on tuning these little carburetors. I will give you one from Zama and one from Walbro....Zama first.
http://www.zamacarb.com/tipspage.html
http://tech.flygsw.org/walbro_tuneup.htm
Jun 08, 2011 | Poulan Ght225 25cc Gas Hedge Trimmer
Hedge trimmer put away for winter. will run but not stay running. put in new diaframs for carb . same results. i am questioning the gas cap now. is it possible that it can cause a problem with keeping this...
YES, this system relys on pressure and the ionic nature of gasonline to pull the fuel through the system. If the gas cap is off or damaged where a seal is no longer possible, try taping it up with duct tape and see if that helps
Jun 03, 2010 | Weedeater Excalibur Gas Hedge 22" Trimmer...
I have an tht200 hedge trimmer that has been sitting a long time. Added fresh fuel and tried to start but will not fire at all. Any ideas?
give it a tune up ... check the mag, probably have to rebuild the carb ... new plug ... You must get it to spark.
Oct 08, 2009 | Tanaka Hedge Trimmers: 20" Dual - Sided...
What is the fuel mixture on the ryobi cs30 weed eater?
Mine says 50:1 on the gas cap. It's a 2006 CS30. Model #RY30120.
2.6 oz of 2cycle oil to i gallon of 89 octane fuel is what i use and have no problems
Jun 30, 2009 | Ryobi Three Trimmer Combo
What ratio of oil do you reccomend for the
Depending on the age of the McCulloch cutter it could be 25:1 32:1 or on rare occasions 50:1.
Regardless you can't go wrong with 32:1. This ratio can be used in ANY 2 cycle engine with great results.
Jun 23, 2009 | Garden
How to put new fuel hose into fuel tank on jonsered hedge trimmer The hole is smaller than hose
You will need to split the fuel line for about 2 jnches and push it through the hole then reach in the tank with needle nose pliers and pull it through.Then cut off fuel line square and install filter.
Mar 14, 2009 | Garden
Garden Logo
67 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
