Question about Microsoft Xbox 360 Console
When power unit is connected to xbox 360 console, console wont power up
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 144 Answers
First, check to see if the charger lights up. If it does, then it could be a cord connection issue or it could be a system malfunction. If it does not light up, I hate to say it, but you're going to need to get a new charger.
Hope this helps.
Sincerely, CBR2009
Posted on Jul 18, 2009
My xbox 360 is now showing flashing 1 red light on and off
These steps are taken from the support site as always, it's the first website where you should look.
Solution 1: Disconnect and reconnect cables
Here's how:
  1. Turn off your Xbox 360 console.
  2. Unplug all memory units, controllers, and accessories from your console.
  3. Unplug everything from the back of your console, including power and video cables.
    Don't remove the hard drive.
  1. Reconnect your console's power supply.
  2. Reconnect each accessory one at a time, starting with a controller.
  3. After you've reconnected every accessory, turn the console on.
Solution 2: Remove the hard drive
To see whether the problem involves the original Xbox 360 Hard Drive, temporarily remove the hard disk drive. Here's how.
Note Not all Xbox 360 consoles include a hard drive. If your Xbox 360 console doesn't have a hard drive, to go Solution 3.
  1. Turn off the console.
  2. Locate the hard drive on the top of the console (or on the left side, depending on how the console is oriented).
  • Press the release button on the hard drive.
  • Lift the hard drive away from the console.
hdseparating.jpg If these steps resolve the issue, reattach the hard drive to verify that the error occurs only when your Xbox 360 Hard Drive is connected.
Solution 3: Disconnect memory units or USB flash drives
Here's how:
  2. Unplug any memory units or USB flash drives attached to your console.
  3. Turn on the console.
If these steps resolve the problem, reattach the memory unit or USB flash drive to make sure the error occurs only when it's connected. If this is true, order a replacement memory unit or use another USB flash drive.
Solution 4: Request a repair
If the previous steps don't resolve the single flashing red light issue, there are no additional troubleshooting steps. Your original Xbox 360 console must be repaired at our service center. Start the repair process online.
Jan 09, 2015 | Microsoft Xbox 360 Console
My xbox 360 will turn on but the lil green circle wont light up and controller wont connect?
Your xbox 360 may not actually be on if there's no green light and your controller won't connect. If pressing the power button doesn't turn on the console/green light doesn't come on then your motherboard may be bad.
Jan 14, 2013 | Microsoft Xbox 360 Console
How can I flash my xbox 360? it wont recognize the new dvd rom drive.
Disconnect all cables from the Xbox 360 and remove the faceplate from the front of the console. Lift the plastic tabs on the outer shell and remove the plastic casing from the machine. Unscrew the Torx size 7 screws and lift open the metal cover. Unplug both the power and SATA cables from the rear of the DVD drive and lift it out of the console. Replace it with the new DVD drive, and connect the power cable to the unit. Connect your SATA cable to the DVD drive and a free SATA port on your computer.Turn on your computer and open a web browser. Download JungleFlasher and run the program. As of September 2010, JungleFlasher is the most stable and up-to-date flashing program for Xbox 360, and it is also the only program capable of flashing Xbox 360 drives from within Windows (earlier programs used MS-DOS). Click "Flash .BIN to DVD" in the program's main menu and select your Xbox 360's DVD drive. The program will flash the new DVD drive for use with your Xbox 360 console.Turn off the computer once the flashing process is complete and disconnect your SATA cable from the DVD drive and your PC. Reconnect the Xbox 360 SATA cable to the new DVD drive, then close the metal cover on the console. Rescrew the Torx size 7 screws and replace the outer plastic shell on the Xbox 360. Return the faceplate to its original position then reconnect all external cables and accessories to the console. Power on the Xbox 360 and the replacement DVD drive will function normally.
Feb 27, 2011 | Video Game Consoles & Games
My sons xbox 360 wont turn on
Check the power supply unit, if the light is green or orange and still doesn't power on, try pressing the eject button on the xbox it should turn on if you do, if the power supply is red then you should contact xbox support.
Oct 21, 2010 | Microsoft Xbox 360 Console
1 red light on xbox 369
hi, here follows a possible solution from Microsoft support:
One light on the ring of light around the power button on your Xbox 360 console flashes red.
You might also see the following error message on your television screen or monitor: System Error. Contact Xbox Customer Support. This message is followed by an error code in the format of "Exx," where xx is a two-digit number.
Note If you see error code "E74" on your screen, click the following article number to view the article in the Microsoft Knowledge Base: 941377 E74 error appears when you use your Xbox 360 console Back to the top
CAUSE A single flashing light might indicate a hardware failure on your Xbox 360 console. Back to the top
THINGS TO TRY Step 1: Disconnect and reconnect all cables a. Turn off your Xbox 360 console. b. Unplug all memory units, controllers, and accessories from your console. c. Unplug everything from the back of your console, including power and video cables. d. Unplug your power supply from the wall, and then unplug the short cord from the power brick. e. Plug everything back in. Make sure that you make all connections firmly.
f. Turn on your console. If the problem still occurs, go to step 2. Back to the top
Step 2: Remove the hard drive To see whether the problem involves the Xbox 360 Hard Drive, temporarily remove the hard disk unit. If your Xbox 360 console does not have a hard disk, go to step 3. To remove the Xbox 360 Hard Drive, follow these steps: a. Turn off the console. b. Locate the hard disk on your console.
c. Press the release button on the hard disk, and then lift the hard disk from the console.
d. Turn on your console. If these steps resolve the issue, reattach the hard disk to verify that the error occurs only when your Xbox 360 Hard Drive is connected. If this is true, contact Xbox customer support to order a replacement hard disk. To contact Xbox customer support, visit the following Web site: http://www.xbox.com/support/contact If this does not resolve your issue, go to step 3. Back to the top
Step 3: Disconnect any memory units a. Turn off your Xbox 360console. b. Unplug any memory units attached to your console. c. Turn on the console. If these steps resolve the issue, reattach the memory units to verify that the error occurs only when a memory unit is connected. If this is true, contact Xbox Customer Support to order a replacement memory unit. To contact Xbox Customer Support, visit the following Web site: http://www.xbox.com/support/contact If this does not resolve your issue, go to step 4. Back to the top
Step 4: Request a repair If the previous steps do not resolve your single flashing light issue, there are no additional troubleshooting steps and your Xbox 360 console must be repaired at our service center. https://myservice.xbox.com/it-it/Pages/welcome.aspx
Jul 31, 2010 | Microsoft Xbox 360 Console
Xbox 360 Console: what do i do if my xbox 360 wont connect with my c...
all you do is hold in the little button on the top of the controller
May 17, 2010 | Microsoft Xbox 360 Console
Xbox controller
need more info if its just the controller that wont turn on get a new one or replace batteries if it wont connect to consol theres a small button at the top press this along with an equillyh sized button on the consoll beside the power button gold th controller toward the power button for a few seconds
May 15, 2010 | Microsoft Xbox 360 Console
Xbox wont turn on its pluged in and getting power to the unite but wont turn on
What color is lit on the power unit? Is it red, yellow, or green? Are you using a wireless controller to turn it on or the actual button on the XBOX? If you're using the wireless, make sure it's plugged in to the unit and controller. If not, replace batteries in controller and see if that works. If still nothing make sure you have a good connection between the power unit and the XBOX.
Dec 06, 2009 | Microsoft Xbox 360 Console
My controller and xbox wont connect
To connect the controller to your Xbox 360 console, follow these steps:
  1. Press and hold the Xbox Guide button until the controller turns on. The Xbox Guide button is the round button with the green "X" near the center of the controller.
  2. Make sure that your Xbox 360 console is turned on. If your Xbox 360 console is not turned on, press the power button. The power button is the large round button on your Xbox 360 console.
  3. On the Xbox 360 console, press and release the Connect button. The Connect button is the small round button on the Xbox 360 console.
  4. On the controller, press and release the Connect button. The Connect button is the small button on the front edge of the controller, between the left bumper button and the charging port.
  5. After the Ring of Light spins and flashes one time on the controller and on the console, the controller is connected. The quadrant on the Ring of Light that remains lit indicates the position in which the controller is connected.
Aug 28, 2009 | Microsoft Xbox 360 Wireless Controller
My xbox 360 and wireless controller will sync but then it wont show that they are connected and even though i turned on my console by using the button on the console it just shows the green light turn on...
  2. Make sure that your Xbox 360 console2_bing.gif is turned on. If your Xbox 360 console is not turned on, press the power button. The power button is the large round button on your Xbox 360 console2_bing.gif.
  5. After the Ring2_bing.gif of Light spins and flashes one time on the controller and on the console, the controller is connected. The quadrant on the Ring of Light that remains lit indicates the position in which the controller is connected.
Aug 15, 2009 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
