Question about Brother Office Equipment & Supplies
Displaying shut back door - Brother Office Equipment & Supplies
    New Friend:
  • 116 Answers
Which model?
Posted on Jul 18, 2009
My GE stainless steel 1100 watt microwave starts beeping out of the blue and the display panel shuts off and when I open the door it resets itself and then starts to beep when I close the door again.
Try removing the power cord for about a minute, push all the touch pad 'buttons' and then plug it back in. If this doesn't work it sounds like you may have a bad door interlock switch or a bad PCM .. Good luck !
Feb 11, 2015 | GE XL1800 1100 Watts Microwave Oven
Microwave will not run a cook cycle. Touchpad functions until door is opened or start button is pressed. When door is opened display goes dark. When door shuts display lights all characters and then says...
BEFORE DOING ANYTHING DISCONNECT OVEN FROM POWER. I do NOT recommend doing repair by yourself, if you NOT are really very familiar with electric repair, or have at least basic training in electric device repair and maintenance.
"When door is opened display goes dark. When door shuts display lights all characters and then says "touch clock"."
Obviously, by opening door, oven gets disconnected form power line.
This is mostly caused by loose connections on wiring socket, and can be anywhere inside. Check security micro switch on door latch. This switch normally disables only running the oven when door is open, for security reasons. In your case, it seems that opening door disconnects oven from input power. Sometimes the switch is loose, or wires are not firmly pushed in the socket. If the power line wiring is loose, and by opening door looses contact with socket, it can touch metal housing inside, cause short, electric shock, serious even mortal injury and fire. This is dangerous high voltage switch, and to access it one must open oven from the back and take off the cover. I do not recommend doing it by your self.
Rem: Replacement micro switch is couple dollars.
Oct 24, 2014 | Microwave Ovens
Elctrolux dishwasher won't start, display won't light. Any suggestions?
Good Morning Friend,
I understand your Electrolux dishwasher, model# EWDW6505GS, seems like it is not receiving power to the control panel. I suggest resetting your appliance, by either unplugging your appliance or shutting the power off at your home's circuit breaker, for 20-30 minutes. Restore power and try any cycle. If you are still not receiving any lights, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine what is causing your control panel to not have power.. Hope this is helpful.
-Best Regards-
WP
Jul 04, 2014 | Electrolux EWDW6505GS Fully Integrated...
Saeco Philips coffee machine display screen doesn't light up? I can still use it and I can see the options but with no colours.
I can still use it and I can barely see the options but display screen doesn't light up
I'm having it sent back for repairs, is there a quick fix for this issue so I do not have to send it back
Apr 11, 2013 | Saeco Intelia Focus Automatic Espresso...
Kenmore hood microwave door was slammed shut, now it won't power on. Fuse is good, door switches don't look damaged or dislodged. I haven't ohm'd the switches. They should not be the problem as the...
While the door was slammed it is possible that the connection to the main board was disconnected. so since there is no display I recommend that you check the power to the processor board, check if the LT circuit is working , if the board fuse has failed or if the power supply here is faulty.
Only if the display comes back will it confirm the working o the processor.
Apr 01, 2011 | Kenmore Microwave Ovens
Hinari microwave doesn't cook
hello mam
i am having the solution for this problem check the lock terminals for loose connection and if its working and check the magnetron which produses the heat inside the microwave.
Sep 25, 2009 | Microwave Ovens
Microwave won't shut off
The door switches are what tells the microwave that the door is opened or closed. If they play up they could be causing your microwave to act strangely.
Mar 25, 2009 | GE Microwave Ovens
Replace Control Board?
control board sounds like alikly source, been known to have problems with their display boards as well though.does your unit have a display board on the front maybe 2in.x 3in. square inlay? or is ti just kinda all part of the push button leds
Feb 22, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
16 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
