Andy, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Zoom 42 mower deck belt routing diagram Google Search
http://apache.ariens.com/manuals/00173200.pdf
How to Replace the PTO belt on an Ariens Zoom Zero Turn
Ariens Zoom 42 Owners Manual
SOURCE: i need belt diagram for 42 in deck
You can go to the Sears website an download a free owners manual that shows what you need.
SOURCE: need to replace belt on deck of john deere riding mower
does the belt on a 42" scotts lawnmower go behind the tenisoner or in front of it?
SOURCE: Swisher 60 deck belt breaks after mowing about 15 minutes.
Even though the routing is correct, have you checked that every spindle and idler pulley turns freely? These bearings can freeze up or bind because debris builds up in them. Also, if the bushings on the idler pulleys can wear, causing them to misalign. Keep checking. Also - is the belt snapping clean, or do you see a burnt, worn spot?
Testimonial: "Thank you for your help. The belt is snapping clean. You are correct in your assessment to what the problem might be. We checked all the above and did not correct problem. We put three washers on top of small idler pulley to bring it down and better align routing. Bought heavier belt at auto parts. Believe the bolt head was touching belt where it routed throught to larger idler pulley."
SOURCE: need to put deck belt on rally 42
YOU CAN GO TO SEARS.COM TO GET A MANUAL OR THEY HAVE THE BREAKDOWN ON LINE
