My lap top drops the internet connection almost non stop. When I look at the status it says 'local connection only'. I have to disconnect from our network and then reconnect to solve it, however that solution only lasts a few minutes and then I get dropped again.F5D9231-4
This can be resolve by accessing the router setup page and changing the Wireless channel of your router if possible set it to the highest channel that is available on it , but if still the same thing the next thing to do here is to update the firmware of your router , you can get the firmware from the web site of your router's manufacturer....
We have a 3000 sq ft split level house, so range is critical (could we extend range with antennas,...
(More)
We have a 3000 sq ft split level house, so range is critical (could we extend range with antennas, access points)?
Stability and reliability are also critical
We use a comcast cable modem
Must support mixed environment - 2 Macs connecting wirelessly, 2 PCs (1 with a wired connection)
We all want to be able to share a printer (which will connect to router with a wired connection)
Network attached storage, media streaming - I'm not worried about these now, looking for basic connectivity. Though would be great if I could grow into this in the future...
First of really thanks for the support you are providing..
let me come to the point...
(More)
let me come to the point now.
We have two juniper SA2000 and right now one of the box is active, so I would like to do the clustering with the second box, i have their SA2000 manual..but which is something very difficult to understand..
anyway i have few queries that
- In which device i have to enter the secondary IP address?
- If it is in the current active device, should i need to create a virtual IP address for the secondary?
- I have already assigned a IP address for the secondary device. is that enough?
- how do i check that the clustering is working properly?
- what are the basic things have to do in the secondary device?
really appreciate if some one could help me.
I have to do this installation ASAP.
Really thanks,
