Check with ur BIOS, n POWER ON/OFF switch might be damaged.
or there must be damaged to ur operationg system, maybe damaged to the system's DLL files must be damaged r missing, it will done by a virus, or any illegal [programs.
try using a better anti-virus software.
n for ur problem, during next reboot, plz insert the valid OS cd/dvd into the drive, n
in the BIOS select BOOT from the CD.
then follow the instructions n then go to fixing of th OS.
hope u'll be definity fixed with it.
else try reinstalling the operationg system, b4 that create a valid backup of all the important documents in the system, in a separate external memory device, like pendrivve or a external harddisk,..thank u!!
Remove the battery from its compartment on the side of your Dell Inspiron laptop computer.
Remove the power adapter from its plug on the side of the Dell Inspiron (if your laptop is currently plugged into a wall outlet).
Press down and hold the "Power" button on the laptop for one to two minutes. This will dispel the excess electrical current that is built up inside the laptop.
Put the battery back inside the compartment of your Dell Inspiron.
Plug your power adapter back into the side of the Dell Inspiron. Press "Power." Your laptop computer will now turn on.
hope this helps
