Question about Frigidaire ATF6000ES Front Load Washer
Frigidaire Front Loader
Final Cycle use to sound like a jet taking off now it doesn't go as fast and clothes are still wet when opening the washer
  • 76 Answers
Re: Frigidaire Front Loader
Try checking the filter, it may not be emptying the water quick enough.
Posted on Nov 18, 2007
0 characters
3 Points
My front loader works fine and will spin BUT it will not do the fast final spin cycle in the end to draw water out of the clothes. It shows that it has 11 min. left, does a slow spin right, a slow sp
Hey friend, thanks for your post!
I see that your Frigidaire washer will not spin on the final cycle. You could be having an issue with your motor or control panel. It is possible that the control panel is not sending the required information to your motor in order to process the spin cycle. Or it could be that the motor is not receiving the signal from your control panel to spin.
I would recommend performing a reset on your appliance which you can do by unplugging the power cord or flipping the circuit breaker for ten minutes. I hope this information is helpful. -Matt
Oct 08, 2014 | Frigidaire Washing Machines
The clothes are soaking wet after final spin in our Frigidaire GLFT2940ES1 front load washer
Good Morning Todd, thank you for your inquiry!
Often when clothing continues to stay wet, it is because your washer may not be reaching full speed during spinning cycle or not spinning long enough. Let's try resetting your washer by either unplugging it or flipping the household circuit breaker to the off position. Please wait roughly ten minutes and then turn your washer on. Select a normal cycle, allow cycle to complete and if resetting the power does not correct the issue you may wish to reach out to a professional who is best equipped to pinpoint the exact problem, which can often save you funds and a headache.
Nov 02, 2013 | Frigidaire GLTF2940ES Front Load Washer
I have a Fridgidaire front loader. It completes the regular wash cycle, but clothes are soaking wet- it's not doing the final fast spin. When I select the drain/spin option, it drains and eventually...
Either an off balance load (unlikely if it happens all the time), a bad door switch, or a bad motor control board. Easiest repair is to try replacing the door switch, failing that, i'd call someone in to test the speed board.
Apr 05, 2010 | Frigidaire ATF6000ES Front Load Washer
Frigidaire front loader wont final spin timer stops at 7 min.
its_me_ac You probably have a faulty timer switch.
You can buy parts at this site , v
Please give me a good rating
Dec 05, 2008 | Frigidaire ATF6000ES Front Load Washer
Washer won't final spin
After charging me $275 to change the water pump, the repairman said I needed a new computer board for another $160. I went & bought a new washer - this time a regular top loader mechanical washer with no computer. The repairman said computerized washers & front loaders in particular have lots of problems. He said top loader Whirlpools have the least problems.
Nov 13, 2008 | Frigidaire ATF6000ES Front Load Washer
Front load Frigidaire Gallery washer
You are having a door switch problem change it out and you will have a new washing machine.
Dec 14, 2007 | Frigidaire GLTR1670A Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
Top Frigidaire Washing Machines Experts
Richard Roth
Richard Roth
Dan Webster
Dan Webster
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
