Question about Garden
Hi Guys, Have a Murray ride-on with both rear axle seals leaking oil. Date 0634. Model 38702X20B. Type 12ic/38. Parklands s/no 2531. Peerless transmission ident tag reads,,930012 Peerless 40473516. Need info on how to replace the axle seals (plus maybe the bearings). An exploded diagram with parts listing would be most helpful as well as the grade of oil used. Your assistance is greatly appreciated. Thanks,Ted
  • ejhanns Jul 18, 2009
    Thanks for your help. Just where under murray riding mower.com does one look ?? Regards Ted
  • 130 Answers
You can fine this information on the internet under murray riding mower.com in most cast
use 90 w oil in the gear boxs
Posted on Jul 18, 2009
How do I install seal in the transaxle?
Require splitting the case if your trying to replace axle seals. Case is sealed with Permatex Ultra Grey sealant
Oct 16, 2014 | Craftsman Garden
Axle seal
There is a plug about halfway up in the transaxle, fill till lube runs out. You will need a new seal in the unit eventually, but if leakage is not real bad you can just add the oil recommended by the manufacturer. Hope this helps, plese post solved on fixya.com. So I get credit for a solved problem if it does. If not, check back and give me more info.
Apr 14, 2014 | Ariens Garden
Leaking rear axle seal
If has a Peerless transaxle you need a oil seal 780088A. Its where axle comes out housing. Just pry it out and replaced.
Aug 05, 2013 | Craftsman Garden
HOW DO I GHANGE THE DRIVE BELT ON A MURRAY RIDING MOWER
http://www.ereplacementparts.com/ type in your model number all the diags you need, yours Henry
Oct 16, 2010 | Murray 38 Lawn Mower Blade Belt '90'96...
Need diagram to replace murray 42 inch cut belt
http://www.ereplacementparts.com/ type in model number of your mower ie 40560x50c All parts and diags ypu need ,Yours Henry
Aug 07, 2010 | Murray 38 Lawn Mower Blade Belt '90'96...
Leaking oil seals rear axil
hi , make sure its not the brake cyl. leaking, if its rear seal leaking remove brake shoes, then remove axle bolts, replace new seal, then check rear end fluid
Jun 16, 2010 | 1996 Isuzu Trooper
1994 buick roadmaster, oil leaking out of right rear axle, checked brake fluid is full, could it be differential oil leak @ end of axle??
If what you see leaking is very oily and does not evaporate, likely it is an axle seal. If there are no leaks in the brake system, that's the only thing back there that can leak. If the axle bearing is going away, it can damage the seal so make sure you look for small shiny metal flakes behind the seal when you replace it or you will be doing the job again very soon. Can't remember...that IS rear wheel drive right?
Dec 01, 2009 | 1994 Buick Roadmaster
Transmission is locked up.
Make sure all attachments are off the outside of the unit. If all bolts are out then if you have not try a chisel all the way around the case very carefully as it is usually stuck by the sealant that seals the unit.lol.donnyb60
Mar 23, 2009 | Mtd Garden
Garden Logo
635 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
