Question about Dell Inspiron 630M Notebook
On power on the display can sometimes take up to 1 hour to startup. Other times it will start straight away.
Can any one help m please, I have a Konica minolta bizhub C450 and i have a malfunction code C152, can any one tell me how to fix it please as soon as possibl thanks to all
i found this after a brief search
Straight from the service manual....just use the last 4 digits when doing a search, makes it easier to find the specific code as not all manuals are the same in how the code is displayed.
CC152 ROM contents error upon startup (Scanner)
• A fault is detected in a sequence of ROM contents check of the PWB-C during starting.
16.5.79 CC151: ROM contents error upon startup (MSC)
16.5.80 CC152: ROM contents error upon startup (Scanner)
16.5.81 CC153: ROM contents error upon startup (PRT)
16.5.82 CC154: ROM contents error upon startup (PH)
1 Check the ROM version. - -
2 Rewrite the firmware. - -
3 Replace the appropriate board.
TSB entry
Description
C-C152 at power up, the counters display as 0 and the operation panel display is in Japanese.
Solution
CAUSE: Main body firmware is corrupt.
SOLUTION: Flash or re-flash the firmware to the latest level.
As for the 2152 code,
16.5.6 C2152: Transfer belt pressure welding alienation
Dec 04, 2014 | Konica Minolta bizhub Office Equipment &...
Samsung startup problem
serial number on 6.17.8.1
Sep 21, 2013 | Televison & Video
My 2010 rr phantom does not start somethimes even with new batteries but start after maybe half an hour after I let it rest .
Sounds like an electrical short. Check all hot and moving surfaces to see if they are coming in contact with wires.
Jan 05, 2012 | Rolls Royce Phantom Cars & Trucks
I have a Logik Set Top Box L2STB09. It turns it'self after 1 hour.
I have the same model and had to return it to Currys 5 times for replacements because it had the same symptoms. Sometimes the screen would go blank after a few minutes, sometimes after an hour. Other times the box would just spontaneously restart, display the startup screen then return to the programme. I have persevered with this but it I've had it with this brand now. They obviously have a batch of faulty processors.
May 20, 2010 | Televison & Video
Starting problems triumph sprint st 1050 2007 model
Did they check the plug wirers? How about the gas? Drian the tank to remove any sediment, OR, Put in an additive that has dry gas in it to remove any condensation. Change the fuel filter,
Apr 10, 2010 | 2007 Triumph Sprint ST
Wot do i do after entering my code on a 5000 rds
Radio should start straight away.
If it is the same as the 3000 series , the numbers are entered as numbers of times you push sequential keys. ie: code 1579 , push number 1 once, push number 2 five times, push number 3 seven times and push number 4 nine times.
If the display is flashing " ERR " you will need to leave the ignition on until it stops flashing and the display reads " CODE" . ( it can take up to an hour)
Hope this helps.
Apr 08, 2010 | 2000 Ford Focus
My bmw does not start sometimes , when i turn the engine
Thats a solinoid problem you have on the starter motor have it checked out.
Nov 17, 2009 | BMW 525 Cars & Trucks
Tv doesnt always come on straight away
Need more input, what model, what brand, do it turn on if you hit the side.
Regards
What About Bob
Feb 19, 2008 | Televison & Video
Screen not appearing straight away
It could be your LCD backlight giving you problems till it warms up. Turn you computer on and while the monitor is displaying black and the power LED is green shine a flashlight in the lower left hand corner of your screen. Look for the ?Start? button, if your backlight is not working you?ll see a faint ?start? button if you look closely. A 15" LCD monitor is probably not an economically repairable problem unless you have access to really cheap parts and have the skills and tools to do the repair yourself.
Jul 29, 2007 | AOpen F55PS (Black, Silver) 15 in. Flat...
Dell Inspiron 630M Notebook Logo
mukhtar21 shaikh
mukhtar21 shaikh
