Question about Pioneer DV410V DVD Player
Freeze picture, audio still works then permanent freeze no audio.
Same as above, but I have to turn off the power at the mains to get the dvd player working again.
  • gfranze Jul 19, 2009
    what should I clean the lense whith and where to buy the lense cleaner and is it easy to get to the lense.
    thanks
  • 57 Answers
Need to clean lens or replace
Posted on Jul 17, 2009
I hook my farenheit dvd player up every thing comes on but no sounds comes out of it what could i have wrong
It looks like a stand alone dvd player from the picture and there is no sound power so to speak for those units just a left and right audio signal ( Red and White ) Yellow is for video of course. Make sure you have the red and white audio OUT going into the INPUT of your power ( your main radio ) and as long as your radio is working correctly you should have sound. Some of those stand alone units come with a 3.5 mm or 1/8 jack and you have to make sure which is audio and which is video and get them to the right inputs of your radio. if that doesn't work check your radio am/fm or cd player and if sound works with them it is probably not getting the audio signal correctly. Good Luck !
Feb 07, 2015 | Farenheit DVD-36 Car DVD Player
No picture when disc inserted in DVD DVD turns on
Please check the connections , check the leads from the DVD to the TV, use the line out from DVD to the line in the TV using the video and audio inputs. If this wont work then in most cases when the CD does not play it is possible that the optical head is a suspect. Sometimes it might pick up ordinary audio CD but will not play other formats. This indicates that the optical head is weak and so there is no detection or scanning of the CD . If the optical is working the tracks will be read immediately but with no scanning the laser head can be defective.
The main motor will not work in some cases as unless the tracks are read the drive motor will not work with signal from the processor.
Sometimes certain cleaner disks will not be tracked to run for cleaning as it will not be read and so will reject. Hence it is ideal to manually clean the laser head eye using a cleaning swap /cotton bud with gentle pressure on the lens eye.
If there is no result then watch if the CD spins or tries to spin. If so the board seems to work unless a test is taken on the main board but the possibility of a defective optical head can be the suspected fault.
If any of the above seems otherwise we must recheck with possibilities of a malfunction of the main processor board
Jul 14, 2011 | Philips DVDR3320 DVD Recorder/VCR
Got new tv Westinghouse LTV-32W1 32 Inch Widescreen LCD TV LTV-32W1 in need of help! do not have the remote and trying to progam it to turn on but blue light turns green and picture turns blank
in this case i have to know if your tuner is working fine or not. First of all i like you to connect any external player Exp. DVD or blue-ray player if that works with audio then it is inverter board. if audio doesn't work then its main board. Also you will find out that if dvd is working fine on your tv than your tv setting is wrong or the tunes is dead. either way if tuner is gone then you have to change the main board. Either way let me know what went wrong i can provide you more information about what part need and where can you get it from.
Please let me know if you have any further questions or concerns. Also rate me if you like this post.
Thanks.
May 11, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
DVD picture freezes, first for a couple of secs then will freeze for longer period then permanently on Sharp DV-NC60H model
Test the resistance of the spindle motor. It should be 8R5. If OK replace the lazer mech or pick-up.
Aug 31, 2009 | Televison & Video
Pioneer dvd player 410v freezes when I play avi files, then I have to turn it off at the main power to get the player running again.
I Guess your DVD Player doesn't support the avi format.
If doso, then with some limited audio/vedio rates.
You could read this CNET Review Here about the support.
Jul 19, 2009 | Pioneer DV410V DVD Player
DUAL XDVD9101 PARKING BRAKE BYPASS
STEP ONE. Ground the E-Brake wire.
No matter which method you use, you must ground the brake detection wire. I suggest you tap it into the ground wire on your wiring harness (ensures a good ground).
FACTORY RESET METHOD (not permanent)
1 Go to the Menu
2 Get to the Settings Menu
3 Select <yes> to Reset to Factory Settings.
Have recently heard complaints of this method not being permanent, as this is needed whenever they want to watch a DVD. Also, radio and screen angle presets are lost.
METHOD 2
AUDIO CD METHOD (Permanent)
1 Insert Audio CD
2 Press PLAY
3 Press STOP twice on remote
4 Enter 26604 on remote
5 Press ENTER
6 Take out Audio CD and Insert a DVD
METHOD 3
DVD METHOD (Permanent)
** Insert a DVD
** Let it play until you hear sound
** Press STOP twice on remote
** Enter 26604
** Press ENTER
The blue warning screen should immediately go away after pressing the last digit of "26604." Still press ENTER as a precaution.
The 3rd method seems to work with most of the duals
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 18, 2009 | XO Vision XOD1742BT Car DVD Player
Samsung dvd player
Sounds like the spindle motor is not running up to par. Possibly the lens needs cleaning as well.
May 03, 2008 | Samsung DVD-R130 DVD Recorder
Panasonic SC-HT500
Not really an option to modify cable.Connections inside subwoofer and main unit are difficult to work with.Common problems with dvd are laser/traverse deck failure and dvd tray ailgnment.You can run a seperate Dvd player by using the Tv or Tape audio input in the receiver and run the Video cable direct to TV.
Apr 01, 2008 | Panasonic SC-HT500 System
Kenwood DVR - 7000
Hi, same thing happened to my one of the above. I bought a cheap dvd player to view movies and run the audio through the kenwood to use the surround speakers.
Feb 21, 2007 | Kenwood DVR-505 DVD Player
Philips dvdr 3320v picture freezing
Be sure there is plenty of space around the DVD player. I place mine on top of the cabinet without anything on top if it. Being enclosed seem to affect some DVD players. Also, dust frequently...
Jan 09, 2007 | Philips DVDR3320 DVD Recorder/VCR
Pioneer DV410V DVD Player Logo
186 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
