SOURCE: I have spent MANY hours
Here You can find a free mpeg converter for any type of files. What kind of file do You have? If it's .avi, probably Roxio creator cannot burn it because it is too big, and if You nave the menus on Your future DVD, I'm sure the reason is the size. On Mac it's easy. With toast titanium, You can select an option fit-to-DVD, and the video fits on standard DVD. Probably, the default compression options in Roxio aren´t sufficient. Try to search in advanced options compression level, or, You can convert with the MPEG Streamclip the video to mpeg video, by selecting a different level of compression, and then You can offer this file to Roxio. Try this. If it not helps, drop me a message.
SOURCE: In Roxio Creator 10, I attempt to burn a disk of a
Generally, defragmenting your hard disk will resolve this issue. To defragment your computer:
If defragmentation doesn't resolve the issue, burn your project as a data file, and then burn your project as a data disc using Disc Copier or Creator Classic. To create a disc image/data file:
SOURCE: roxio easy burn error code 8004520c
use this http://www.poweriso.com/ its free and easy to use
mikee ^^,.
