A/B switch How do I get the speakers that are connected to the B terminal to come on by themselves with no other speakers? I have the amp assigned to 7.1 channel. Thanks Tom
    President:
  • 1,348 Answers
You can't.they are wired in series so that it is 16 ohms.if you parallel 2 sets of 8 ohm speakers,it makes 4ohms and that is much harder on the amp,so alot of new ones,a and b are in series
Posted on Jul 17, 2009
Staticy in one channel
This is a loose connection and it could be the voice coil in the speaker, the terminals on the speaker, the connection at the terminals on the speaker, the wire going to the speaker, the connection at the amp, the internal connection in the amp, the actual parts on the circuit board of the amp, change the speaker connection at the amp
(switch right and left to see if it is outside the amp)
If not then you are looking at the amp being the problem.
Apr 15, 2016 | Car Audio & Video
Message volume fixed
Zone 2 Setup on the RX-V773 using the ZONE2/PRESENCE Extra Speakers The RX-V773 extra speaker terminals can power one set of speakers for Zone 2 or Presence speakers. If the extra speaker terminals are utilized then the RX-V773 cannot be set for Bi Amp (Surround Back/BI-AMP terminals). Setting the Extra Speaker Terminals Note: The RX-V773 remote control will be used to access the On Screen Menu of receiver. 1. Press the On Screen button on the remote control to enter the On Screen Menu. 2. The On Screen display should be displayed on the TV/Monitor. 3. Press the Arrow Down button on the remote until Setup comes up in the screen. 4. Press the Enter Button on the remote control. 5. The Setup Menu will come up across the TV/Monitor screen. 6. Use the Arrow Left & Right buttons on the remote to navigate to Speaker. 7. Press the Arrow Down button on the remote to select Manual Setup. 8. Press the Enter Button on the remote control to enter Speaker Manual Setup menu. 9. Speaker Manual Setup menu with Power Amp Assign highlighted will come up. 10. Press the Enter Button on the remote control to enter Power Amp Assign menu. 11. Speaker Manual Setup, Power Amp Assign menu will come up with Basic highlighted. 12. Press the Arrow Down button on the remote to select 7ch+1ZONE. 13. Press the Enter button on the remote to select 7ch+1ZONE. 14. Press the On Screen button to exit the on screen menu. To control Zone 2 using the RX-V773 remote, the switch at the upper left side (above the BD/DVD Scene button) of the remote must be set to Zone 2. To see the operations on the front of the Yamaha receiver you must press the Zone Control button on the front of the receiver. Note: Only analog signals can be sent to Zone 2. If you want to output the sound from Zone 2, connect an external component to USB Thumb drive, USB iPhone/iPod, Network, AV 5-6 or Audio 1-2 by analog connection. For AM/FM radio the antennas must be attached.
Aug 19, 2012 | Yamaha RX-V773
I cant remember how to hook up the speakers to the system
Speakers use a cable that consist of 2 insulated wires. The two wires are identified by one or more ways: 1) one wire may be golden colored and the other white or silver colored, 2) the insulation on one of the wires may have a raised ridge, or 3) the insulation on one wire may have some marking along the surface where the other will not
The terminals on speakers and terminals for the speakers on the amplifier will both have a (-) and (+) symbol for each cable (one for each wire). I like to assign the (+) terminal to the golden colored wire or the insulation with the rib or marking on it, and the (-) terminal to the white or silver colored wire or on the smooth or unmarked insulation. It does not matter which wire you assign to which terminal - as long as the (+) and (-) terminals of the speaker connects to the (+) and (-) terminals on the speakers of the amplifier (you should see to it that they do not get crossed so that the (+) of the speaker is connected to (-) terminal for the speakers on the amplifier).
Connect each speaker location to the corresponding speaker terminal on the amplifier (the front right speaker to connect to the front right speaker terminals on the amplifier - continue until all speakers are connected). Failure to connect correctly will make fading front to back and balance left and right work unexpectedly.
I hope this helps and good luck! Please rate my reply. Thank you.
Apr 09, 2011 | Audio Players & Recorders
What is the proper way of connecting my two speakers to my PIONEER M-90 Amplifier?
As with any amplifier...
Typically:
Connecting the speakers
Each speaker connection on the receiver comprises a positive (+) and negative (-) terminal. Make sure to
match these up with the terminals on the speakers themselves.
Make sure that all the bare speaker wire is twisted together and inserted fully into the speaker terminal.
If any of the bare speaker wire touches the back panel it may cause the power to cut off as a safety measure.
Feb 06, 2011 | Audio Players & Recorders
Rear speakers on 7.1 not working
Most likely you have wrong setup- two rear speakers are assigned for zone 2. Press setup on a remote controller go to OPTION SETUP and assign POWER AMP to S.BACK.
Apr 04, 2009 | Audio Players & Recorders
Itunes assigned to CD stereo outputs to zone 1 but not zone 2
Ron Digital audio will only reproduce in the surround area you will have to connect using analog connections in order to get that sound in the 2nd zone
Dec 14, 2008 | Denon AVR-2807 Receiver
Zone 2 problem for AVR 3808
It doesnt down convert to zone 2 via hdmi.... must use analog audio or something else.
Jul 14, 2008 | Denon AVR 3808Ci Receiver
No sound back two speakers
After using the method of last resort (RTFM) I discovered that Yamaha 7.1 amps assign an order of priority to the speakers. The surround speakers have higher priority than the surround-back speakers. I had connected the rear speakers (in a 5.1 configuration) to the surround-back speaker terminals and since nothing was connected to the surround terminals the E-6 error happed on auto-setup.
I eventually fixed this by connecting the rear speakers to the Surround L/R terminals and then, via the manual setup menu, set rear surround = NONE. This causes the amp to route the rear-surround signals to the Surround L/R terminals. The auto-configure then completed successfully.
May 18, 2008 | Yamaha RX-V661 Receiver
Need help in wiring speakers to amp.
The right speaker will connect to the R+ and R- terminals and the left speaker will connect to the L+ and L- terminals. Only one speaker per connection. If both speakers are not exactly the same brand, part number,size, etc. then they may NOT sound the same. Be sure to watch the polarity of the speakers so they don't interfere with each other. I.E. speaker + to amp + etc. Good luck.
May 11, 2007 | Koiiler XM-7676W Car Audio Amplifier
41 people viewed this question
 Grubhead
Grubhead
