I have a asus ptgd-la motherboard
I have a hp pavilion a818n asus ptgd-la motherboard Goldfish-GL8E thatb i need to put into a new case need the wiwihg diagram for front firewire, usb1, usb2 and audio
  • 107 Answers
Just go to the asus website and download the manual for your board
Posted on Jul 17, 2009
Tip
Why choose HP Pegatron M2N78-LA ASUS OEM Violet6-GL8E??
Things to be considered in choosing HP Pegatron M2N78-LA ASUS OEM Violet6-GL8E
1. Processor and Memory upgraded
3. I/O Ports and Network
5. Clearing BIOS password
For details you can visit web site www.hpparts.us
on Apr 02, 2014 | HEWLETT-PACKARD HP Pegatron M2N78-LA ASUS...
HP Pegatron M2N78-LA having trouble finding a replacement for my motherboard with the same part number, would i be able to put a HP Pegatron M2N78-LA with a different part number into my machine
Before you give up check on ebay. If you do replace just make sure that the physical size is the same and that the replacement uses the same cpu and memory you have now. Otherwise you will be spending much more dinero.
Apr 01, 2014 | HEWLETT-PACKARD HP Pegatron M2N78-LA ASUS...
Had to change out my case when power button broke new case has different wiring need help new case is a enermax (ostroge)
You will have to look at the motherboard manual to find out where each cable needs to go. I assume you are referring to the power button, reset button etc. cabling. There are generally a set of pins on the motherboard that run next to each other and are for all of the button on the case and LEDs etc. In order to find out this information you need to get your exact motherboard model number and look for its manual online. it will tell you the details of each pin and where the cabling goes.
Oct 20, 2013 | HP Pavilion a1220n (A1220NED904AA) PC...
I Have a HP Pavilion a6110in PC. Procesor AMD Athlon 64x2 3600+. Its motherboard have problem.I want to buy a motherboard for it. Request suitable motherboard and price at Visakhapatnam (India)
i believe what you need is this p/n CG781-69002, Motherboard (system board) Narra2 GL8E - This is a micro-ATX form factor, Asus M2N68-LA, Socket AM2 (Athlon 64, Athlon 64 X2 with Dual-Core and Sempron) CPU supported
is your computer p/n GG781AA ?
Oct 19, 2010 | HP Computers & Internet
I need a new motherboard for my computer. currently it has a ASUS PTGD-LA motherboard. does it matter what kind i replace it with?? I have an hp pavilion a1020n desktop
Information about the stock motherboard is here if you want to compare it to possible replacements. It doesn't matter what board you get as long as it fits (micro-ATX style) and can support the drives you have (enough IDE and SATA connectors). Also, if you want to keep your current memory and processor, you'll need to find a replacement that supports them. Finally you need to make sure that you stay within the ratings of the system power supply, unless you plan to upgrade it.
Hope this helps. Thanks for using Fixya!
Mar 04, 2010 | HP Pavilion a1020n (PS583AA) PC Desktop
Need front panel connection diagram power switch lrf connectipns on 9 pin connector on motherboard
Hi u can easily solve this problem.
open your computer cover and and see the motherboard front panel connectors. a use of screw driver touch any two front panel connectors if any led or switch working this condition you can note this and connect successfully. one by one touch all penal connections and u will be solve ur problem thanks mukesh kumar
mukesh_ibm@yahoo.com
May 12, 2009 | ASUS Computers & Internet
Ram Upgrade
Max speed supported for your mobo is: DDR2-533
You will have to buy (4) 1gb sticks (2gb sticks not supported)
To use all four gigs of ram you need a 64 bit os.32 bit only supports 3gb of ram. Hope this helps!
Here is the specs :
ASUS A8M2N-LA (NODUS-GL8E) (DDR2-533MHz) Memory Maximum Memory 4GB Memory Slots 4 (4 banks of 1) non-removable base memory 0MB Machine name: ASUS A8M2N-LA (Nodus-GL8E) Motherboard
CPU options: Supports AMD Athlon 64, Athlon 64 X2 and Sempron processors.
Chipset: Nvidia GeForce 6150 LE Chipset
HD Bus:
Front Side Bus options:
Memory Speed options: PC2-4200 DDR2-533 240pin SDRAM DIMM
Special notes:
- Motherboard manufacturer's name: ASUS A8M2N-LA
- HP/Compaq name: Nodus-GL8E
NOTE: *Actual available memory may be less w/o 64 bit os
Dec 24, 2008 | Computers & Internet
Computers & Internet Logo
448 people viewed this question
David Payne
David Payne
