Question about Refrigerators
Water is leaking from freezer door. may have put holes in something, putting locks on door. locks are on left side of unit(facing unit).4 holes in door,about half way up door. four more across from them... Frigidaire model #FRT21LRGW2
    Scholar:
  • 78 Answers
Good evening sir.
well about ur problem, plz check it out in a near service center, as ur freezer is fragile part, connecting directly with compressor, any slight damage r rough handling may result in leakage of Coolent !! which is sometimes quite toxic.
or else, if u can manage then try fixing it a rubber washer of reqired size. this will definetly stop the leaking of water..
thank u
Posted on Jul 17, 2009
Freezer leaking
open the freezer panel in back. unclog drain hole where water collects. defrost unit first. put a towel in front of unit for some water
Feb 25, 2010 | Refrigerators
Leaking water and ice build-up in freezer
There's a drain hole in the freezer side behind the bottom drawer in the back wall that must be clogh ; put hot water into it untill melted the ice and keep pouring water to clean the drain (don't worry , the water goes to an evaporative tray) .Keep the drain clean by putting every 3/4 months half a cup of clorox or bleach.
Sep 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water leaking out the front freezer door... the bottom of freezer unit has water pooled in it frozen... melts and runs out the door
The defrost drain hole in the bottom rear portion of the freezer is frozen shut. Turn off the fridge,use a hair dryer to defrost the drain hole. Pour a 1/4 cup bleach into the hole after is is cleared out. Turn the fridge back on.
Aug 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Got water leaking from bottom of fridge/freezer on the front left side,also ice build up inside of freezer at the bottom.dont no if these are linked
If you take all the drawers out of the freezer - you will find 8 screws with 'bolt type' heads - 2 top, 4 at sides and 2 to the bottom.
Turn the power off. Undo all these screws and remove the rear panel. You will notice the 'gubbins' of the freezer. At the bottom you should notice there is a shaped plate with some piping running around and then up into the cooling 'radiator'. Towards the middle left of the plate there should be a hole - this is the drain hole. Is it blocked with a 'slug' of ice! Yes is my guess. This needs defrosting as will the rear panel you took out by any guess.
I did ours this morning as the fridge freezer was making a heck of a racket. Took about 30 minutes with the wife's hairdryer - and I'm no expert.
I just enjoy the fact I'd probably saved £50 plus on a callout.
Jun 13, 2009 | Hotpoint FFA90 Bottom Freezer Refrigerator
Leaking by freezer door in bottom
your drain line is clogged remove back wall and trow hot water in hole please unplug unit
Apr 05, 2009 | Kenmore 57029 Side by Side Refrigerator
GE side by side by side,water drips from bottom freezer door
I have the same problem. Just talked to a friend that's a great appliance repairman. he said I have to remove the panel in the back inside of freezer and there is a drain that gets clogged up, a little hole or tube.
clean that and should work fine and stop leaking. I haven't had time yet, but this weekend I'll do the deed. Hopes this helps ya!
Jan 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water Leaking from the bottom of the Refrigerator
is the floor of the freezer a sheet of ice? if so the defrost drain hole is clogged.
Feb 11, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
143 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
