Question about RCA L42WD22 42 in. LCD Television
My tv connected to dish box has no volume and color. the dish channels are fine but receiving only black and white and no volume. Can you let me know what could be the problem. Is it a setting on the digibox or fuse or dish problem.. am a total electrical nerd.
  • 108 Answers
SOURCE: RTD 155 - only black and white...no color
Perhaps you have set your DVD player for Progressive Scan Mode while your Television does not support for the same. Go to the setup menu and turn Progressive Scan Off. This will solve your problem.
Posted on Feb 04, 2008
  • 13 Answers
SOURCE: No color on TV when a dvd is played
are you using the correct colour output? change it and see if it works....go to set up, video or display, and look for the colour output option...check that, and if that dont work, try changing ntsc or pal....it wrkd for me
Posted on Jun 30, 2008
abhishek33
  • 1239 Answers
SOURCE: No connection DVD to G25189TK. No external channel set. (3 or 4)
hi you can change the external channel manualy or follow the steps mentioned here . http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=DCP750/37&scy=US&slg=AEN&grp=HOME_ENTERTAINMENT_GR&cat=AUDIO_SYSTEMS_CA&sct=SU00303_SU
if it doesnt work best to buy remote from https://secure.logmein.com/home.asp?lang=en
Posted on Dec 06, 2008
joez47
  • 61 Answers
SOURCE: RCA TV lost Color
It sounds like your grandson found the "monochrome" setting in the menu on your remote. It may be in the "picture settings", "set-up" or "advanced" setting.
Posted on Sep 13, 2009
  • 1039 Answers
SOURCE: I have connected X Box 360 to the back Red,White
Look for av input. You may have to keep changing channel till you get to AV1. look on the remote for input button.
Posted on Dec 06, 2009
Have Sanyo DP50740 Plasma tv and Dish Network receiver. This morning I turned TV on and receiver on and Black screen appeared on TV with floating no signal box with white letters. I do not have the t
Check the TV first by tuning it to an external RF source; ie; on-air program by connecting it to external Ariel and make sure that the TV is OK. If the TV works fine with on-air program, the Dish Network receiver is either fault, of it do not get input signal.
Oct 18, 2014 | Televison & Video
Not sure what channel to put TV on to receive DISH channels
Hey there, Cheri Torres with DISH Network Internet Response Team here. I came across your post and wanted to see if I could help. The channel that you would need to put your TV on would depend on the type of cable you have plugged into your TV and receiver. If the cable you have plugged into the receiver and TV is a coax cable (black cable with silver end) the channel would need to be on 3 or 4. If the cable is a RCA cable (black with red, white and yellow tips) the channel would need to be on an input such as Video 1, input 1, input 2, aux etc. The other cable that it could possible be hooked up with is a HDMI cable (black with a thin flat end) the TV would need to be on a HDMI input. You can find the inputs by pressing the input, TV/video, source or AUX button on the DISH remote or TV remote. I hope this information is useful and if you have any other questions please let me know.
Nov 23, 2011 | iLO IWT3206 TV
NO VOLUME AT ALL - GREAT PICTURE We have Dish
You will want to start by unplugging the receiver for ten aseconds. If this doesn't resolve the issue check the cable from the receiver to the TV if it is a single cable with a flat end then just ensure both ends are firmly connected. If you are using component cables with 5 colored ends (red, green, blue, white, and red) make sure the red and white audio cables are connected on both ends. If this fails to resolve the issue reply to this and I will get back to you!
Daniel Busa
DISH Network
Customer Service
Jun 24, 2011 | Sharp LC-32SB24U 32 in. LCD TV
Every morning when i turn on vizio tv,i have no volume..Have to turn off & on about 10 times...Worked perfectly fine,day before with direct tv box...Dish box,no
In order to best assist you I will need a little more information. Have you tried checking the cables running from the receiver to the TV? Are there any devices connected between the receiver and your TV? Also what type cables are connecting the receiver to the television?
Daniel Busa
DISH Network
Customer Service
Mar 18, 2011 | DISH Network IR Remote Control
Installed a new set top box last night and all the channels are black and white - no colour at all - confused!!
vron63
Check your cables between the receiver and your TV to make sure the colors match. If you are using a component cable (green, blue, red, white, red), not matching colors at both ends will give you what appears to be a black and white picture. I hope this helps.
Ray Calo
DISH Network
Mar 09, 2011 | Televison & Video
My RCA has a black block come up in the bottom of the screen? We have Dish Network Satellite and have programed the remote from the remote code guide. TV volume and channel changer work, but picture is a...
This has hopefully been resolved for you, but if not, here are some steps to go through. The black box that comes on the screen is usually signaling that closed Captioning is activated on the tv. Closed captioning does not run through the DISH Network receivers, so you can turn that feature off in your tv settings. The fuzzy picture could be a few things. You will want to check that all of your cables on the back of the receiver box and tv are tight as possible, and also make sure that the tv is on the correct channel. If you are in the room with the receiver, the tv will need to be on channel 3 or 4, and sometimes an input; usually video 1 or 2. If you are in a number two room, where there is no receiver, than you want to make sure that the tv is on channel 60 or 73. I hope that this helps!!!!!
Becki Barned
DISH Network Customer Service
Sep 11, 2010 | RCA F36650 36" TV
Only one channel going to b/w
Not the tv,it the brocasting incoming signal cable have a slice matalic contacting to that procise prequencies problems for that channel.Take another tv used it,with that incoming signal for that channel for a few days.See,if have a same problems have happen to another tv?Yes,than call the Cables,Dishes or Telicoms compannies,change that section of the incoming of broscasting signal cable line.Not,than take a piece of sand paper about 1000 grits,rub the input metal pin a few times,to have it better contact.
Jul 20, 2010 | Jwin Televison & Video
My 37in insig t.v is messed up the color for the t.v menuse r in color but i cut my dish network on today and its black and white but the t.v meneus r still in color...y is the dish network color black and...
We would be happy to help get that fixed right away. Thefirst thing we want to ensure is that all connected equipment is on. Check whattype of cable is used to connect the TV to the receiver. If you are using a coax cable to connect the receiver toTV1, check the receiver's back panel for the output name. If your receiver hasa "TV CH 3/4 out":Tune TV to channel 3 or channel 4, if it is labeled "Home Distribution": TuneTV to channel 62 or 75. If using non-Coax (RCA, Component, or HDMI) to connect receiver to TV1,cycle through the inputs until picture appears; Most TVs have a "TV/Video", "Input", or"Source" button. We also want to ensure that the TV and thereceiver are connected properly, please visit this link to for moreinformation: http://www.dishnetwork.com/SupportSection/setup-receiver-totv.Once we have made sure everything is connected properly, unplug receiver for 10seconds then plug it back in, this will reset the receiver. If we are still notgetting a picture connect another component (VCR, DVD Player, etc.) to the sameTV, using same cable, same input, and same channel to see if it works. If youget a picture with the other component give us a call at 1-800-333-DISH (3474)for some additional troubleshooting. If it doesn't work with the othercomponent then replace the cable that was used.
We hope these steps get the color back on your DISH Network programming. We want to thank you for being a valuedDISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
Feb 14, 2010 | Insignia 37" LCD Flat-Panel HDTV
Black and White Channel
Check the fine tuning for that channel.Adjust + or - accordingly, see what happens?
Oct 02, 2009 | Apex Digital AT2708S 27" TV
Xbox and dish network problem
if you have like a dvd player then try hooking the xbox up to it in the front where the video is for the 3 plugs then try to plug dish network in the back of the dvd where the ant in plug is at then take the cord from the dvd player and plug it in the back of the tv if this dont work let me know
Aug 08, 2009 | Microsoft Xbox 360 Console
RCA L42WD22 42 in. LCD Television Logo
221 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
