Question about HP Officejet Pro L7580 All-In-One InkJet Printer
Out of paper while paper is there
Paper in tray but showing out of paper mesg
    Problem Solver:
  • 14 Answers
Check the paper tray and make sure the sliders are in the correct position. If you're using A4 paper and the tray is set for Legal it may show a no paper error as it is looking for a different size. Also check that the lever in the back of the tray is not stuck.
Posted on Jul 17, 2009
Kkonika minoltaprinter 363 paper not detected prperly
size detection assy stays back side of Tray.
if their tension plate moves out of position , then such issue happens.
Apr 12, 2017 | Konica Minolta Office Equipment & Supplies
Canon iP4500
Looks like either a roller/feeder problem. Since it is under warranty, the best solution would be to simply replace it , instead of trying various fixes..
Jun 02, 2008 | Canon i80 InkJet Printer
Can't get it to make copies. I need it to show "letter" size when choosing the size parer...it shows A4.
You may have a piece of paper jammed behind the paper tray? I would take the paper trays out of the copier and look inside to see if there is paper jammed toward the rear of the copier..... There are switch's that till the copier what size paper is in the tray. It can also be a small tab on the back of the paper tray is not adjusted correctly? Good Luck
Apr 05, 2011 | Canon NP 6230 Copier
Printer error shows paper jam at paper tray and printer stops after printing 3 or 4 pages. I open and close the top access and printing resumes for 3 or 4 more pages...stops and shows paper jam at feed...
Try two things:
Fan the paper before placing in the tray.
Raise the humidity in the room to at least 40% to avoid electrostatic sticking of the paper. Store paper in 40% humidity area.
Dec 16, 2009 | Konica Minolta magicolor 2400 Laser...
My toshiba 2060 copier starts knocking when warming up and then show the trays are empty , do you know what it could be?
the lift motor for the paper trays is faulty or if yu pull the trays out and look behind the tray there are som connection there check there aint no paper stuck there.. if you put the trays back in on at a time you should find the one causing the problem.. my money is on the lift motor as this lifts the tray up to the paper sensor to show paper in trays..
Aug 03, 2009 | Toshiba 2060 Copier
Hi In our office Konica Minolta C250 ,it show message mulfunction. error:- c0206
C-0206 relates to tray 3.
With the copier turned on do the following
Open paper tray 3, remove paper, close tray, open then shut front door, load paper into tray 3 - hey presto!!
If the fault comes back you could have paper stuck behind the tray or have a defective lift up motor.
Regards
Taminol
May 13, 2009 | Konica Minolta bizhub C250 All-In-One...
Shows error code CO900
A C0900 is a paper tray problem. Try to check your paper trays and make sure that there is not any paper in the paper tray wrong or doubled up in the paper tray, it may hender the paper tray from liftting in time.
Jan 23, 2009 | Minolta Di3510f Bizhub Copier
Printer Trays
I have the same problem. Tray 2 shows "!" and doesn not print. PLEASE HELP!
Jul 02, 2008 | Lexmark T632 Laser Printer
HP Officejet Pro L7580 All-In-One InkJet Printer Logo
121 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
