Question about Dishwashers
Candy dishwasher cd623
Water leaking underneath - nothing obvious when looking at it.
  • 76 Answers
Re: candy dishwasher cd623
Chances are its the wash pump, when you tip it back are you able to see the workings underneath the Dishwasher, if so you will see a largest looking Motor (wash pump) look to see if there is any water marks or rust on it, if there is then this is probably your problem, if thats the case a new wash pump would cost around 100 pound.
Posted on Nov 18, 2007
0 characters
3 Points
My dishwasher has leaked a smal amount of water from underneath
Jackie, It is probably a seal(gasket) leaking, you may want a service tech. to have a look.
Mar 09, 2016 | Hotpoint 24 in. FDW60 Free-standing...
Instructions or Manual required
Actually every dishwasher I've worked on had one water inlet and it was always for hot water. Approximately 3 gallons per cycle.
Mar 25, 2014 | Candy 24 in. CD623 Free-standing...
Candy CD242
Try this link & check that model number. They had a 252 but no 242:
Water is not being taken in on our candy Aquaviva CD 623 dishwasher
First check and see if there is plenty of water coming into the machine by examining the fill hose inself.
You likely will have to disconnect that hose, not at the machine end, the sink end.
Then, find a way to test the wires to the fill valve, should likely be 110 volts when the machine starts, allowing the fill valve to open.
A volt-ohm meter will tell you, set it to over 110 volts on the A.C. setting.
If no power to the fill valve, you may be facing a new timer.
Be blessed.
Jan 24, 2013 | Candy 24 in. CD623 Free-standing...
I need the operating instructions for a candy aquaviva cd623 dishwasher. Can anyone help with a pdf version I can download?
I am sorry to hear that you have problems with a candy dishwasher. I have had two or three pieces they just died of old age.
But seriously on line there is this
You will most certainly find your candy manual there for downloading free.
Mar 24, 2012 | Candy 24 in. CD623 Free-standing...
Pump keeps running, does not take in water and program does not move forward.
It sounds like the flood protection system has been activated. This is most likely due to water in the bottom of the dishwasher (under the washing compartment) or it could be due to a faulty float or float switch.
The first thing to do is check the float inside the dishwasher. It's the dome/mushroom shape plastic part in the bottom of the wash compartment. Have a feel around under the dome and check there isn't anything trapped underneath it (maybe cutlery or a build up of waste). If something is stuck in there, simply removing it should be enough to get you running again.
If it's clean underneath try pushing the dome down gently in case it's just stuck in the up position. If it pushes down, lift it up and down a few more times, clean underneath it and make sure it drops down on it's own when you lift it and let go. If it falls freely, you're good to go.
If there's nothing under the float and it moves up and down freely, next check for water in the bottom of the washer. To do this, tilt the washer forwards then backwards to about 20 degrees. Obviously, if it's under-counter you'll need to pull it right out before doing this. If you see a pool of water on the floor then you have water leaking into the bottom of the washer!
There are several possible causes of this - some are simple and easy to correct - but you should do these checks first, then post back here for further assistance.
Please rate my solution if you find this helpful. Thanks.
Oct 13, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Leaking from the front
I had same problem but different model #.
The part under the spray arm came lose and the gasket was hanging out. Causing it to squirt water right at the bottom of the door and leaking out. I took it apart put the gasket back in the groove, screwed it back down and is working great.
May 25, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
My dishwasher leaks from the door, but the seal is not broken
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
Aug 29, 2009 | Candy 24 in. CD623 Free-standing...
Dishwashers Logo
304 people viewed this question
Top Dishwashers Experts
Mike Cairns
Mike Cairns
