Question about RCA HD50LPW42 50" Rear Projection HDTV
TV turns itself off and then back on when I watch HD
I have an RCA 50" DLPHDTV. I had some issues with the lamp so I replaced that and I also had an issue with the video board and had that replaced as well.  Ever since I got the tv back it's very picky with what HD programming it lets me watch.  Mostly on sporting events or while playing video games in HD the tv will shut itself off and then after about 30 seconds it turns itself back on.  Any ideas??
    Problem Solver:
  • 11 Answers
If it played OK before you replaced the video board and now you have an intermittent problem Suspect the part that was replaced...Does this set have a video board? I can't find one on my parts list. Also there are a lot of ISSUES with aftermarket lamps not working properly on hi bright pictures. I can find out correct part #'s with complete model #.
Posted on Feb 06, 2008
TV turns off while watching it then turns back on after abt 1 min
TV needs new lamp as symptom shows existing lamp is weak and causing repeatedly on-off
Please replace lamp in TV, replacement procedure is written in user manual and it is not difficult.
Always buy Sony original lamp for TV safety.
Let me know if you need further help.
Thanks.
Sep 22, 2009 | Sony Televison & Video
Our RCA high-def 52 inch TV is shutting off on
It has you Posted as a projection TV and Not DLP, if Fan to Lamp stops running set will shut off to protect Lamp,I had a DLP that would play sometimes 30 mins then shut off drove me crazy trying to firgure it out and it turn out to be Fan would stop running I replaced Fan TV working fine . When you remove back engage toggler switch to up position put a piece of tape on it to hold it is a safty switch ,then turn tv on watch to see if all fans are running also if when tv trys to come on is there a spark coming from Ballast Board if so your new Lamp is defective it does happen if not your ballast board maybe Bad it is what turns on Lamp.If all fans are running Ballast Board.
Sep 22, 2009 | RCA HD52W56 52" Rear Projection HDTV
My Sony HD-TV KDF-50E2000 blinks 15 times pwr button then turns on. After about 2 hrs turns itself off and blinks 40 times then turns itself back on. shorter and shorter on time thoughout the day. No led...
Symptom shows Lamp is getting weak and its time for new Lamp in TV.
Lamp replacement procedure is written in user manual.
Please buy Sony original lamp for TV safety.
Thanks.
Jul 03, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
50v710 turns off by itself then on
Have you check the power supply,that's what it seems to me.
Jun 29, 2009 | Hitachi 50V710 50" Rear Projection...
Tv turns off
Its the lamp that needs replacing. It will run for a couple of seconds and then it would dim or turn off.
May 27, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
RCA HDLP50W151 keeps turning off
I had a set with a similar issue--at first the tv would suddenly turn itself off, sit for a moment while flashing the power button, then "reset" itself and continue running.
Then one day it quit starting up all together. I couldn't get a picture at all. I was hoping it just needed a new lamp (which is what I was able to gather from reading various troubleshooting forums).
I took it to a repair shop for a definitive opinion, and when they took a look at the TV it actually started smoking and the issue was definately the light engine, not the lamp.  Unfortunately, a light engine repair costs around $950.  If you try to do it yourself, the part costs about $700, if it is in stock (and it turns out that it often is NOT in stock).
Instead of putting that much money into this TV, I'm going to have to bite the bullet and get a new TV.  It just doesn't seem a good use of nearly a grand when new HDTVs can be had for around $1300.  Sorry for bad news.
If you can, try to replace the light first. You can get just the lamp for less than $200, although it may be a larger issue like mine.
Dec 22, 2007 | RCA HDLP50W151 50" Rear Projection HDTV
No picture
Assuming that the replacement lamp is good, you could be looking at a bad ballast (lamp power supply) or the switch on the lamp door itself could be causing the issue. The light engine also could cause an issue like that. I would have a technician look at it as this is beyond consumer repair.
Nov 25, 2007 | RCA Scenium HDLP61W151 61 in. HD-Ready...
RCA HD50LPW42 50" Rear Projection HDTV Logo
119 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
