Question about General Electric G.E. - INDUSTRIAL SYSTEMS TPL412R 125 AMP OUTDOOR MAIN LUG LOAD CENTER
We have 2000 hp motor on our main line pumps, when we disconnect from the pump and run it axail movement doesnt stop could please help
  • xerxen1953 Jul 23, 2009
    GE motor 2000 hp model no 5K26355FSI when we disconnect the motor from the pump and run it to check the magnetic centre the axial movement does not stop , the bearing are with in spec , not sure what the problem is thanking you in advance .
    President:
  • 1,714 Answers
Water is flowing back against the pump and turning it. There should be a check valve to prevent this.
Posted on Jul 23, 2009
  • Craig Butler
    Craig Butler Jul 23, 2009
    I'm not sure I understand what it is you're doing or trying to accomplish. Can you explain in more detail what the problem is and what you are doing to the motor. What do you mean when you say 'trying to find magnetic center'. I have 30 years of experience with large motors and generators and I can help you if you can be more specific.
My gould well water pump would not stop so is bought a new pressure switch which i installed and same thing. can you help me please
Sounds like the foot valve may be loosing it's prime. I would let it pump for a few minutes and then shut it off. Then after a few minutes disconnect the line going into the well. If the line has water in it and the water level is going down, you have either a bad foot valve or a leak in the lines going down into the well. It could be as simple as a loose connection. Hope this helps. I use to sale well pumps and have seen this many times. If you let the problem continue and the pump continues running it will throw the overload or will burn the pump motor up.
Dec 13, 2016 | Plumbing
I have a 1978 merc 85 hp outboard with a bad pump i purchased a used one that works mine has 4 hoses
Mercury Outboard Fuel Pump - Mercury Outboard Forums
forums.iboats.com/Mercury-Outboards/Fuel-Pump
5, 2004 Mercury 225 four-stroke EFI no power to Low Pressure fuel pump. Why please help · Mercury & Mariner Outboards. 13, Mercury 850 (85hp) - Gas pumps through the top carb - Failed fuel pump? ... 1, 1969 7.5 H.P. Mercury (Bad fuel Pump)? ... 1971 · 1972 · 1973 · 1974 · 1975 · 1976 · 1977 · 1978 · 1979 · 1980 · 1981 ...
Fuel Pump Diaphragm replacement Mercury outboard 110 ...
? 4:18
https://www.youtube.com/watch?v=vufekxTVZd8
Jun 22, 2012 - Uploaded by Brad Clark
My last test run of this motor lead me to believe I had fuel pumpissues...so in ... Mercury 9.8 h.p. 110 Outboard Motor WaterPump Repair and ...
How to remove the lower unit on a Mercury outboard motor ...
Dec 01, 2015 | Boating
F250 4+4 Vacuum
Sounds like you have a vacuum leak. The pump will run continuously when its not building vacuum. The vacuum seals at the hubs are a common failure on those i would start there by disconnecting the lines right at the hub and applying vacuum directly to the sealed hub unit. I believe it should hold 15-20 in hg
Mar 19, 2013 | 2000 Ford F250 Super Duty Crew Cabs
Fisher and Paykel DW920 dishwasher pump wont stop
This means the flood circuit is triggered. There is a leak in the dishwasher causing water to collect in the motor chamber. The leak is usually through the door seals or broken hose. Disconnect mains electric and water connections and pull dishwasher out from under kitchen bench. Tilt it from side to side to get the water out from under the base. Wait a little for water to dry up. Reconnect mains power and turn on to see if pump stops running. As mentioned source of leak needs to be fixed.
Mar 15, 2013 | Fisher and Paykel Dishwashers
200 Honda Passport ABS pump wont stop running...
There should be a 50amp fuse marked number 18 in the box near the battery that should power the pump.
You may be able to pull that fuse and kill the pump until you can get it fixed. You may also be able to unplug the pump at the wiring connector.
Feb 10, 2013 | 2000 Honda Passport
My creepy sucks for a while and then stops
There are several things that you need to check if these pool cleaners stop working or lose suction. Check for debris or obstructions in the flapper. If you have something making your flapper lose its seal or prevent flapper movement, your water flow can be restricted. Make sure that you filter and pump are not becoming clogged with debris. Make sure that the main drain and all suction lines are closed except for the line you are using to run the pool cleaner.
Oct 12, 2010 | Universal Kreepy Krauly In-Ground Pool...
Spa keeps tripping breaker shows pr
two main reasons breaker trips is the pump motor jammed [not turning]or the heater shorted out --disconnect power open access panel disconnect the lines to the heater turn on power if breaker trips than motor /pump problem if doesnt trip than heater problem can order heater replacement online or pool spa store--if motor pump check pump for debris and motor for lube if u can turn shaft or impeller oil motor and work it into bearings if still not turning possible need to replace motor unit
Apr 26, 2010 | Heritage Pool & Spa
Water still not draining
theres a motor thast circulates the water, and a seperate drain motor, niether change direction. possible that the drain motor is burnt out. leave it disconnected from machine and press the cancel/drain button and observethe pump action, is it rotating or just energizing with no movement,
Mar 13, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
General Electric G.E. - INDUSTRIAL SYSTEMS TPL412R 125 AMP OUTDOOR MAIN LUG LOAD CENTER Logo
306 people viewed this question
Top General Electric Electrical Supplies Experts
hpgwva
Rob Bridges
Level 1 Expert
ken skalski
Are you a General Electric Electrical Supply Expert? Answer questions, earn points and help others
