Question about Toshiba TN61X81 61" Rear Projection Television
Same Problem I was watching the TV and the screen just went off but the sound continued and the Power LED stayed on. Tried other inputs and even tried Demo Button but no response. When I turn the power off, I get a quick horizontal flash in the middle of the screen. I was thinking that perhaps the lamp died. If you can help me troubleshoot this it would be much appreciated
    Problem Solver:
  • 3 Answers
Check the horizontal output transistor and its circuit, High voltage(flyback transformer,Hv block). Check for cold solder on deflection board. Same problem with mine come on and off every day. Still checking...
Posted on Jul 21, 2009
  • 100 Answers
Check for loose solder
Posted on Jul 17, 2009
What's wrong with my LG 55LV9500 LED TV? Power on, black screen.
Hello, either the power supply is failing to power up the LED's or the LED strips in the screen have failed, a common issue with these sets. Power supply part # is EAY62169701. LED strips are only available as a complete screen assembly from LG....thanks
Apr 23, 2017 | LG Televison & Video
I have a un55c9000zfxza it powers up the screen glows but remains dark, I've got sound, controls seem to work, but no menu OSD
Problems can often occur with even relatively new Samsung LCD, LED Television. Some customers report their screen going black shortly after turning on the television, and flickering picture even though the TV's speakers continue to produce sound. You can test and rule out a number of things before concluding that your TV has a hardware defect.
First, check the input settings of your television. Often, users will experience a dark screen when first turning on their television if the selected input corresponds with a turned-off or unplugged input, such as a gaming system or DVD player. If the problem persists, try reconnecting all cables on the back or sides of the television. It's possible that one of your cables has gone dead. If you have access to other cables, try swapping these in and see if the problem persists. Some customers report that turning the television off and unplugging it for an extended period of time, up to 24 hours, can fix the black-screen issue. Samsung TV - Power Supply Issues If you've tried all of these suggestions and problems persist, it's possible that the power supply inside the television is defective or broken. The power supply for most Samsung LCD, LED televisions will cost around $150, with labor costs of around $250. Unless you have a fair amount of TV repair expertise, this is probably not the sort of repair you'd attempt yourself.
May 03, 2015 | Samsung Televison & Video
Blue screen on Samsung LED TV? Is it the power board?
if the TV powers on and stays on.. sounds like you might be on the wrong video stream, (make sure u are using the same input as u are using the output on your cable box, satellite box, etc. if you are using HDMI , use your remote for the TV and find the Source or Input button and try each of the video streams that are listed.
Feb 06, 2015 | Samsung UE40B7020 40 in. LED TV
Why does my Samsung LED TV have sound but no picture?
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts.
Apr 30, 2014 | Samsung Televison & Video
Composite Input Not Receiving Signal
Check the cable connected in between. Replace the cable and check.
Apr 30, 2013 | Vizio E320i-A0 32 Class LED Smart TV
Picture went out on p50hdm Vizio Plazma tv after loud POP
It's either the backlight lamp or backlight inverter is busted due to a power failure or fluctuation. Here's how to determine which is which:
  1. Grab a flashlight.
  2. Turn on the TV.
  3. Shine the flashlight onto the screen.
  4. If you cannot see any display even a faint one, the backlight inverter is dead, else the backlight lamps are busted.
  5. Replace which ever is the culprit.
Sep 26, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Television Went Dead
When you first turn it on dose the LED blink? if it dose then maybe the inverter board went bad if the LED don't blink then maybe power supply
Jul 10, 2008 | TruTech PLV16320 Television
Acer Aspire 3000 pc screen problem
Have u tried re-installing the video drivers?
Nov 27, 2007 | Acer Aspire 3000 Notebook
Open Questions:
Toshiba TN61X81 61" Rear Projection Television Logo
83 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
