Question about RCA TH1602 MP3 Player
Cant find the firmware version that was on it it
Cant find the firmware version fw utility v1.2.5.0 exe, that was on it it originally. it is frozen and computer wont recognize it tried replacing battery downloading latest firmware and it says unable to write to disc
  • 2,335 Answers
When my computer wouldn't recognize my Pearl, these are the steps I followed after downloading the firmware upgrade from http://voxrightnow.custhelp.com/app/answers/detail/a_id/2243/related/1.
This program installed firmware v1.2.5.0
remove the battery,
start the program,
hold the play button while plugging into usb,
release the play button when the term "initializing" replaces "searching",
click the start button to replace the firmware.
You might want to try leaving the "format data" box unchecked the first time. If that doesn't work and allow you to backup your music, bite the bullet and format the data area.
After I did this, my pearl started normally, and my computer recognized it again. It also fixed my aac-error problem after I did it a second time and allowed it to format.
Posted on Sep 18, 2009
Cowon iaudio 10 frozen
Hi. I had problem like this, now resolved. My device is iAudio 9+ otherwise it's not matter.
You can find some solutions on the web but... maybe you can not do proper result first or second time. It comes because of some differences for so lot of devices.
I used this method.
How To Recover your Bricked J3 using Tcctool iAudiophile net Forums
Only one way working for me.
1. Prepare drivers and firmwares. Tcctool and Windows drivers for USB flashmode. Latest FW for your iAudio from Cowon Korea site. Unpack all files/folders into special directory in root of your Hard Drive (c:\COWON for example).
2. Boot your PC in compatibility with non-authorised hardware mode. Press F8 button when PC loading and choose Drivers signature disabled mode.
3. Turn off your iAudio with reset button. Press both M(enu) and VolUp buttons and boot on power. Screen doesn't fire but device standing up in flashmode. Connect USB cable to device, then to PC. On Windows Device Manager you must find new Unknown Device. Install drivers manually from your specific directory.
4. Run on PC new task CMD, e.g. terminal window. Change work directory to your specific, f.e. cd c:\COWON
Run execution tcctool.exe -d cowons9 "name of your FW file"(without quotes).bin
Attention, your FW file (iaudio9P_fw.bin for me) must be in same directory with executable tcctool!
5. After flashing your iAudio must be connected to PC immediately as USB flash device. So you must copy all firmware files (named *.bin) to root of your Cowon device memory. Then reboot, your player must updating firmware and working fine. If still no, try use tcctool to boot on once more, then reboot normally. Copying FW files again doesn't required.
Hey you don't give up!
Mar 31, 2014 | Cowon Iaudio 10 16gb White
After update firmware on a Bizhub C350 the machine working but the panel is dead. I thing is need NVRAM reset. but how?
you cannot reset nvram, you need to check your firmware. if you got the wrong fw it will do that. you can get into service mode by holding down the utility/counter button while bootup press the reset button and then press sequence for service mode initialize nvm and it will need correct fw then you good
Sep 09, 2011 | Konica Minolta bizhub C351 All-In-One...
My Olympus FE 340 Camera firmware is crashed.Hardware is ok.Menu functions are OK.but when Im taking photo Screen is only dark black and shoting photos are same.I cant upgrade the firmware as My camera has...
I have a similar problem in the same camera: all hardware is ok but it doesn't focus. I've taked out the focus motor and it works, and all the pieces works too, they're not damaged, in fact wth the motor out I can focus manualy the picture. So I think it could be a firmware problem, but the OLYMPUS software doesn't leave me to write the same version of firmware, and there's no new versions, so is there any way to rewrite the same version of fw????? any service program?
Aug 26, 2011 | Olympus FE-340 Digital Camera
I have bought a acer 5742 i3 processor , but i am not able to get the bluetooth version in it kindly advice
What you said made no sense use proper grammar. Buletooth and CPUs don't work that way ****....
Mar 05, 2011 | Acer Computers & Internet
Will this burner work on dual layer discs?
Pioneer has released Firmware for the DVR-107D DVD Writer and DVR-A07XLA & XLB DVD Writer. This release # is 1.18.
http://www.pioneeraus.com.au/computer/firmware.html
(a ZIP file download, but uncompresses to an .EXE, as does theflashman.rpc1.org site download. I can't uncompress the EXEs with Stuffit (standard) Expander v7.0x here, but Scott said he used version 8.0.2 )
Looks like we are getting closer to Dual Layer Support:
(although some have flashed NEC ND-2500A drives to DL 2510 model firmware, I doubt that Pioneer will release an official firmware update for the 107D to add dual-layer burning. Like other mfrs, I suspect they'll sell a new drive model with DL burning support.)
    For Models DVR-107D FW Version 1.18
  • DVD-R Writability Improvement
  • +R Writability Improvement
  • DVD-RAM Playability Improvement
  • CD Playability Improvement
  • +R DL DoubleLayer Playback Implemented (NOT Record)
    For Models DVR-A07XLA, DVR-A07XLB, DVR-107AXL & DVR-107BXL FW Version 1.18
May 23, 2010 | Pioneer DVR-107D DVD±RW Burner
Can i unloceked my iphone
That depends on the firmware and modem firmware version on the phone. On the iphone press the settings button, then go to General, then press About. It will have a firmware version and a modem version further down. if the version is 3.1.2 or lower, and the modem is not 05.12 or higher, you can. If you have FW 3.1.3 or version 05.12 you cannot currently unlock your phone. Take a look over at remondpie.com for unlocking instructions and programs.
Jan 30, 2010 | Apple iPhone 3G Black Smartphone
Unable to upgrade Zebra TLP 2844-Z printers firmware
What is the problem if this works?
May be there is a problem on the boot rom!
Jun 24, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Calibrating fw 412050g123d0
does it indicate low toner? fw:412050g123d0 is the firmware version.
try to reset it.
Dec 10, 2007 | Minolta magicolor 2200 DeskLaser Printer
Storage problame
I Would Suggest Using iTunes To Reformat It. iTunes 7 Includes Reformat Software For Every iPod Model.
Sep 08, 2007 | Apple iPod MA446LL/A MP3 Player
RCA TH1602  MP3 Player Logo
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
